Grayscale variances - different patterns, plasma calibration - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #301 of 323 Old 10-11-2013, 04:02 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
zoyd is offline
post #302 of 323 Old 11-15-2013, 01:54 AM
Speeder82's Avatar
A stupid question .. the background level in models of APL is fixed irrespective of the gray level of the window or it changes? I'm talking about GCD patterns.
Speeder82 is offline
post #303 of 323 Old 11-15-2013, 05:22 AM
zoyd's Avatar
Liked: 1064
On the GCD disk the background is adjusted so that average video level is 22%. This results in an average luminance level that varies between something like 4% and 15%.
zoyd is offline
post #304 of 323 Old 11-15-2013, 09:18 AM
cadett's Avatar
Quoted: 43 Post(s)
Liked: 102
So as we increase in patterns the background decrease in luminance?
cadett is offline
post #305 of 323 Old 11-15-2013, 09:52 AM
zoyd's Avatar
Liked: 1064
zoyd is offline
post #306 of 323 Old 11-15-2013, 09:45 PM
Andrei_VVB's Avatar
Quoted: 82 Post(s)
Liked: 29
How it will perform in terms of grayscale and gama the constant energy windows patterns on these plasmas? They will give better results? As far as I know are imune to abl.
Andrei_VVB is offline
post #307 of 323 Old 11-16-2013, 04:49 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 353
No they won't give better results on every plasma TV. They will give DIFFERENT results. It is not possible to tell if the results will be better than using "normal" patterns until you try both methods then spend time viewing a LOT of content to decide which method produced the best final result. In many cases, you won't be able to decide which result is better because they will each have things that look better and things that look worse. But the results will be DIFFERENT -- a little different. It won't be a dramatic difference.
The problem is this... ABL will ALWAYS be present. You cannot turn it off. Other things that you CAN turn off should be turned off for calibration so you get the best result. An automatic iris is a little bit like ABL EXCEPT you are changing the amount of light AFTER the images are made so the entire image gets darker or brighter and gamma and other parameters really donot change relationships (the numbers may calculate differently, the image appearance will be consistent with an auto iris. With ABL, you are also getting non-linearities in the design of the TV included as brightness is limited in high-luminance images. You cannot stop that, it will always happen. If you calibrate WITHOUT ANY ABL, your calibration will not include any of the non-linearities. Which is why I advocate using standard window patterns where the window covers 10%-12% of the screen area with a black background. That allows for SOME ABL but not all of it. So you will at least be calibrating to eliminate SOME of the errors inherent in the TV. When you completely bypass ABL, you aren't getting ANY compensation within the calibration for those non-linearities. That's why you'll get DIFFERENT results with non-APL patterns and APL patterns. Most plasma TVs calibrate fine with standard 10%-12% windows. The few models that have problems are likely to STILL have problems with constant-APL patterns vs. non-constant-APL patterns. But it will likely take different measurements (than traditional measurements) to see those problems... and those problems may or may not be obvious just from viewing images, much depends on the acuity and training of the person as well as the type and size of the errors.
I would not expect any sort of "OMG!" reaction to calibration with different patterns though, you're likely to be disappointed that the results weren't more obvious.
cadett and tbaudoin like this.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #308 of 323 Old 11-17-2013, 11:57 AM
Andrei_VVB's Avatar
Quoted: 82 Post(s)
Liked: 29
Thank you for your elaborate answer. I know I won't see dramatic changes regarding pattern types because I've calibrated with every pattern that I've found and, although there are some differences, there's nothing too obvious.
post #309 of 323 Old 05-18-2014, 07:23 PM
buttonsw's Avatar
Quoted: 41 Post(s)
Sorry to bring up an old thread but Doug is absolutely correct, ABL is always going to be there so you have to calibrate with it in mind.
I have a Pro Panny PF50 and tried the small windowed patterns and APL Patterns and although they looked great in HCFR with straight gamma lines and good White Balance as soon as you start watching real world material the calibration looks wrong. With Plasma calibration looking at the image with your eyes is just as important as looking at charts and graphs with -1 de errors!!
I found that the AVS Standard Window patterns are the best for the PF50 (I think they are 14%) with the ABL definitely kicking in a bit and the real world picture looks excellent. For an example, I tried the 6.5% windowed patterns which looked great in HCFR and I set my colour luminance to -1 in the menu as that what was measured when the ABL was not activating but in real world content when the ABL was kicking in resulted in over bright colours on skin tones etc. With the AVS standard windows I set colour to -4 as measured and the real world content looks superb.
If anyone is getting hung up on what pattern size and type to use I would not worry about it too much if you have a Plasma, I reckon a standard window between 10% to 15% would result in a good calibration.
Don't take any of this as gospel, but after trying loads of patterns on my PF50 this is the result I came up with and it produces the best real world picture.
Pioneer KRP-500A | Sony STR-DH810 Receiver | Tannoy HTS101 Speakers
buttonsw is offline
post #310 of 323 Old 05-18-2014, 07:40 PM
Iron Mike's Avatar
Quoted: 71 Post(s)
Liked: 414
Lumagen medium/large patterns: 11.11%
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
post #311 of 323 Old 05-19-2014, 01:25 AM
Andrei_VVB's Avatar
Quoted: 82 Post(s)
Liked: 29
Is there a FREE disc that has those? Usually there are below and over that size. My logic tells me that10% will be the closest. Is that 1.1% difference that important and will I see this in the final result?
post #312 of 323 Old 05-19-2014, 01:28 AM
Iron Mike's Avatar
Quoted: 71 Post(s)
Liked: 414
I think Ted's disk has the Lumagen 11.11% patterns - not free but almost (very cheap) and very, very useful...
if not use 10% if that's what u got...
ConnecTEDDD likes this.
post #313 of 323 Old 05-19-2014, 01:35 AM
Andrei_VVB's Avatar
Quoted: 82 Post(s)
Liked: 29
Thanks Mike. I know about Ted's disk. I will pay gladly for such a good disk but I have 2 (or maybe 3 major problems)
1. it all rely on my not so accurate D3
2.it seems to.my eyes at least, that with 55vt60E the patterns that works best are small APL ones
3. the sony BR player may not be soo good for calibrating the actual panel (for broadcast viewing)
post #314 of 323 Old 05-19-2014, 01:46 AM
Iron Mike's Avatar
Quoted: 71 Post(s)
Liked: 414
you are absolutely correct, on the smaller VT60 models such as 50/55" it is highly recommended to use 5% or 6% APL patterns to counteract "green skin tones"... I'm not sure if Ted's disk contains those...
how are u currently calibrating ur set ? what's ur pattern source ?
xvfx likes this.
post #315 of 323 Old 05-19-2014, 01:56 AM
Andrei_VVB's Avatar
Quoted: 82 Post(s)
Liked: 29
Sony bd380 with Mascior's or GCD. I can tell you for sure that , unlike the two 50vt60s owned, the 55 model is MUCH less sensible to ABL and much moreconstant in readings with APL and no-APL patterns. Except 10-30 IRE's which are a little different the higher IRE's tracks exactly the same.
My real.issue is.with gamma. The shape and values are much more different. Targeting a ITU gamma with APL behaves almost like the natural response of the panel but using normal windows with 2.4 setting implies much more aggressive adjustments in 10p controls.
post #316 of 323 Old 05-19-2014, 02:09 AM
Iron Mike's Avatar
Quoted: 71 Post(s)
Liked: 414
well, the problem is also only being able to use 10pt controls... a LUT is so helpful in that regard... smile.gif
post #317 of 323 Old 05-19-2014, 02:11 AM
Andrei_VVB's Avatar
Quoted: 82 Post(s)
Liked: 29
While I can't argue that, it is not impossible to dial in whatever gamma I want but that implies heavy adjustments and that's something I'm not comfortable with smile.gif
post #318 of 323 Old 05-30-2014, 04:03 AM
Rattlehead86's Avatar
What do you guys think of Equal Energy Windows patterns from Spears&Munsil 2.0 disc?
They are quite big in size, but the measurements usually resemble medium to large-sized APL on these.
I wonder is someone tried these on their plasma and liked the results better.
Rattlehead86 is offline
post #319 of 323 Old 05-30-2014, 02:26 PM
sawfish's Avatar
Quoted: 145 Post(s)
Liked: 145
When I tried the EE patterns on my 50ST60, I ended up with green-tinted flesh tones in low APL scenes like the firelit indoor scenes in Vikings S01E01. This happened with both my original C3 meter and the i1D3 I eventually bought. My best results have been with small windows. I started with 5% but settled on 2% several months ago. It looks great at all APL levels.
Rattlehead86 likes this.
sawfish is offline
post #320 of 323 Old 09-15-2014, 09:07 PM
hungro's Avatar
Quoted: 170 Post(s)
Liked: 115
Does this also affect the St60 smaller size displays?
hungro is offline
post #321 of 323 Old 09-16-2014, 11:18 AM
Andrei_VVB's Avatar
Quoted: 82 Post(s)
Liked: 29
In my experience with one 50st60..Yes!
post #322 of 323 Old 09-16-2014, 12:14 PM
chunon's Avatar
Quoted: 2466 Post(s)
Liked: 2208
Ditto on my 55" ST60
65C6 OLED/65 A1E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #323 of 323 Old 09-16-2014, 12:25 PM
Andrei_VVB's Avatar
Quoted: 82 Post(s)
Liked: 29
Chunon..what patterns you used for 55st60 and how it behave in comparison with 65vt60 in terms of calibration with different patterns size and type? Thanks!
Reply Display Calibration
