Colorimeter / Spectro Combos - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 11-27-2012, 07:42 AM - Thread Starter
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
Hi All,
I currently have an i1D3 and an i1pro, which I use to profile the i1D3.
I'm looking into buying a better colorimeter: I want to improve in repeatability and low light handling.
As examples, basICColor Discus or the Klein K-10 A appear to be great solutions, although the Klein is very expensive.
Theoretically, if I purchase the Klein, would it still benefit from being profiled to the i1Pro ? Does ANY colorimeter - no matter which price class - benefit from profiling to a spectro ?
In my understanding yes, the i1pro reading at 10nm still sees much more data, but I'm wondering whether it would be less accurate on a display type, where the filters of the Klein are very accurate - maybe more accurate than the data the i1Pro reads...
On top of that, one does never know how accurate a spectro actually is, since it is used as the reference and has no reference itself...
Any input on this and recommendations regarding a better colorimeter than the i1D3 are welcome !
- M
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
post #2 of 19 Old 11-27-2012, 09:16 AM
BobL's Avatar
Liked: 56
I'd consider a spectro like the jeti specbos 1211 for not too much more money over the Klein. All colorimeters benefit from profiling and at this price range I'd spend a little more and get a reference spectro like the Jeti. Unless you can find the Klein at a steep discount.
BobL is offline
post #3 of 19 Old 11-27-2012, 09:34 AM
Chad B's Avatar
Quoted: 493 Post(s)
Liked: 1179
I can verify that the Jeti 1211 has excellent/superb repeatability, as long as the sync settings are right.
It can read anything from 5% on up with flat panels (and sometimes black, if the display has a high black level).
With front PJs it can read everything from 10% on up with ease, and some times 5%, all with great repeatability. Response is slow at the very lowest levels, though.
Chad B is online now
post #4 of 19 Old 11-27-2012, 09:54 AM
Quoted: 1393 Post(s)
Liked: 587
Keep in mind that you'll probably have to upgrade your calibration software license and the additional cost that involved.
JimP is offline
post #5 of 19 Old 11-27-2012, 11:40 AM
turbe's Avatar
Liked: 95
you may want to pm buzzard767, he has a Klein K-10 and i1Pro which I believe he profiles against on each display..
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #6 of 19 Old 11-27-2012, 02:24 PM
<^..^>Smokey Joe's Avatar
Quoted: 61 Post(s)
Liked: 91
I have the Jeti 1211, and also have noticed similar to Chad's observations. You get similar results with the Photo research aswell, Models like the PR655,670 are of similar standard. The Jeti arguallby sits between the 655 and 670 in both performance and price, although the jeti has some features which are better than the PR670 and conversly the PR670 has some features which are better than the Jeti.
The Klein probes are by all accounts very good (never used one myself), but then again the i1D3 is also very good for the price point, of course the Klien can detect a couple of decimals lower. Although there is a caution with detection verse meaningful rersult.
You can make a colourmeter report very accurate results if the light source and meter are calibrated as a pair. This is the catch, to calibrate accurately you need a device to describe the source(light), hence the profiling with an i1pro. So although a Klein can detect far lower than a i1pro or the majority of any field spectro(radio)meters such as the jeti1211, PR655, PR670, in the end to improve the accuracy you need a more accurate spectro device.
However, the Klein is by all accounts very accurate and arguablly the best colourmeter in the market, and don't forget Spectracal create light source tables for their colourmeters they sell, created by the CS2000 spectroradiometer. In this case field profiling with an i1pro could cause inaccuracy due to i1pro device variability and limits.
Notes:
The Jeti1211 is a Spectroradiometer because it can measure from 350nm~1000nm, it uses a 2024 CCD pixel array,
The PR655,PR670,PR680 are Spectrometers because they measure 380nm~780nm, the 655 is a128 diode device the others 256 diodes.
Each type has it's pro's, cons and limits and special use application.
Spectros of this level are calibrated to a NIST traceable light source, which means they can measure all light if detectable within their measurement range and are independant of light sources such as DTV's.
Key meter difference, Spectros describe light, colourmeters report XYZ and luminance only based upon the colour matching function used, their key limitation is accuracy of their RGB filters.
Finally, I'd have to question the value for money of a home user purchasing high end meters, either the Klein or Spectrometers. The performance return verse cost is in reality hard to justify unless you have an absolute requirement for it and hence why devices like these are for professionals only. For the home user, it would be more logical and cost effective to hire a pro with a hi end device to confirm/improve on your readings than to purchase hi end equipment.
FWIW the i1D3 and i1pro are a powerful combination already, where the i1D3 is such a step up on what was available to the home user from a few years ago.
Masterpiece Calibration Ltd
Christchurch NZ
<^..^>Smokey Joe is offline
post #7 of 19 Old 11-27-2012, 11:49 PM
SierraMikeBravo's Avatar
Quoted: 335 Post(s)
Liked: 214
You may wish to consider the C6 from Spectracal. While it shares the same body as its brethren, my understanding is that is completely different internally. For the home user, a C6 profiled to an i1 pro it is just fine. Not many pros have made the leap into high end meters. Very expensive and expensive to maintain. I use the CS200...a spectro in its own right (although classified as a colorimeter...it really isn't in operation). Cost to calibrate the unit...about a thousand bucks. Ouch!!
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is online now
post #8 of 19 Old 11-28-2012, 03:07 AM - Thread Starter
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
is the C6 the revised i1D3 ? I think they just upload additional tables to meter, I don't think they modify the hardware... or do they ? rolleyes.gif
yeah, it seems from all answers here, best bet is to get a decent colorimeter with great repeatability (--> that's why I thought about the basICColor Discus, 1/4th of the price of the Klein K-10 A and great repeatability) and then get a high-end spectro you use to profile the meter...
the repeatability of the i1D3 is getting on my nerves...
- M
post #9 of 19 Old 11-28-2012, 05:01 AM
BobL's Avatar
Liked: 56
iD3 is OEM = Spectracal C6 = Chromapure Display 3. The latter two have offset tables for those that don't have a spectro. A good option for a home enthusiast that doesn't want to spend the extra for a spectro to profile.
Are you having trouble with the repeatability of the iD3? Just curious as I haven't run into that.
BobL is offline
post #10 of 19 Old 11-28-2012, 05:50 AM
venkatesh_m's Avatar
Quoted: 33 Post(s)
Liked: 26
I use the Jeti 1201 and the Klein K-10 (currently being upgraded to K-10A)
Great combo in my mind. The Jeti 1201 is not as fast as the Jeti 1211 and cannot read as low as the 1211 but its repeatable when given enuf light.
The K-10 is great for low light situations especially for projectors, more so doing 3D cals. The one thing I like and does not get mentioned enuf especially for projector cals is the aiming lights that gives u a clear idea on where u r measuring.
I profile the K-10 to the Jeti nearly all the time, except the rare times that the profile does not match the Jeti.
The K-10 is a step up from the C5 for me as its very repeatable even for low light readings.
But they add up, sending the meters for recert and recal (especially the Jeti), and as I am not a full time pro, hard to justify at times.
venkatesh_m is online now
post #11 of 19 Old 11-28-2012, 06:01 AM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
That meter series sometimes gives bogus readings in the 20-40% luminance range. It's no big deal if you are manually calibrating as the error stands out like a sore thumb and the remedy is simply to remeasure that point. However, if you're doing autocal work with a Radiance or Duo the error probably would never be spotted.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #12 of 19 Old 11-28-2012, 07:41 AM - Thread Starter
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
for whatever reason my i1D3 retail needs some "warm up" time... not sure why... Jim P has the same issue... the display is warmed up but the meter returns different readings until it "settles in"... then, reading the same patch in a continuous loop always returns different results, most of the times pretty close to each other, but still...
IMO every little bit adds up... my spectro (i1Pro, used for profiling) although like new, is not dead on in the first place - then the i1D3 colorimeter (used for all measurements) is somewhat unstable - then the guesswork of (some of) the LUT algorithms out there - this altogether adds up for some inaccuracy...
post #13 of 19 Old 11-28-2012, 12:29 PM
buzzard767's Avatar
Liked: 2393
and then there's..... patterns
Fresh measured today with K10-A through Klein K Colorimeter.exe software
Accupel patterns used for reference only but it's difficult to tell if they are truly reference. The rest of the patterns are Calman, Chromapure, and LightSpace internals, and Lumagen Radiance and DVDO iScan Duo externals.
Red 100%
x deviation
cm .008
cp .005
ls .008
lumagen .006
iScan Duo .007
y deviation
cm.002
cp .001
ls .002
lumagen .001
iScan Duo .003
White 100%
x deviation
cm, cp, & ls all .005
Lumagen .009
iScan Duo -.001
y deviation
cm, cp, & ls all .007
lumagen .002
iScan Duo .001
I think it's fair to say that we can get close but we don't know how close, or how far away as there are too many variables.
Buzz
post #14 of 19 Old 11-28-2012, 12:59 PM
turbe's Avatar
Liked: 95
Originally Posted by buzzard767 View Post
Accupel patterns used for reference only but it's difficult to tell if they are truly reference. .
The Accupel 5000 output is reference and this has been independently verified with the proper test equipment.. I'd put my faith in it over the rest listed above
Greg Rogers (AVS Member gregr), the one behind Accupel has been doing this for along time.
ControlCAL™
turbe is offline
post #15 of 19 Old 11-28-2012, 01:14 PM
Smackrabbit's Avatar
Quoted: 30 Post(s)
Liked: 90
I put the AccuPel 5000 on the QuantumData 882 this month and the values from the AccuPel 5000 are spot on accurate, so don't worry about it being incorrect.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is online now
post #16 of 19 Old 11-28-2012, 01:20 PM
buzzard767's Avatar
Liked: 2393
Thanks guys. I really appreciate your input. I originally bought the 5000 when Tom Huffman started carrying it and use it whenever possible.
Buzz
post #17 of 19 Old 11-28-2012, 05:22 PM - Thread Starter
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
Accupel 5000 doesn't support full range triplets, only 16-235, is that correct ?
post #18 of 19 Old 11-28-2012, 05:26 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Depends on the firmware.
Older firmwares that is true, newer ones work correctly.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #19 of 19 Old 11-28-2012, 06:18 PM
turbe's Avatar
Liked: 95
The Accupel 5000 properly supports full triplets (support both modes - by % (0-109%) and full 10-bit RGB direct entry) - 10-bit direct entry was added about 7-9 months ago I believe.
The 5000's firmware can be upgraded in the field by the user, they recently added user-defined window surrounds...
ControlCAL™
turbe is offline
Reply Display Calibration
