need help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-28-2012, 12:30 AM - Thread Starter
drummer22's Avatar
I just bought a samsung pn51e530 51" plasma 1080p 600hz anyone help me to set for best picture thanks
drummer22 is offline
post #2 of 7 Old 11-28-2012, 11:28 AM - Thread Starter
drummer22's Avatar
can anyone help me with picture settings?
post #3 of 7 Old 11-28-2012, 11:45 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Just use the movie mode on the TV. It's the best you can do with out using test discs. (Which BTW, can be essentially free.) Follow the instructions ... should take 15 minutes or so. Now, if you can't be bothered to do that though ... well ...
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #4 of 7 Old 11-28-2012, 01:17 PM
GeorgeAB's Avatar
Quoted: 136 Post(s)
Liked: 240
http://www.avsforum.com/avs-vb/showthread.php?t=1055906
http://forums.hdtvtest.co.uk/index.php?topic=7202.0
GeorgeAB is offline
post #5 of 7 Old 11-28-2012, 02:15 PM - Thread Starter
drummer22's Avatar
so my best bet is to calibrate my tv should i do it or have someone else do it? (I've never done it before) what calibration disc to use? should i do i now or wait i just got the tv and set it up. also anything i need to do for breaking my tv in?
post #6 of 7 Old 11-28-2012, 02:19 PM
infuriatedrain's Avatar
infuriatedrain is offline
post #7 of 7 Old 11-28-2012, 02:48 PM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
Get the free AVSHD disc and the patterns manual here - http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration
Your TV might be also be much further improved with grayscale color balancing but it takes a meter and software to do that.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
Reply Display Calibration
