Advice on entry level display meter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-03-2012, 09:47 AM - Thread Starter
slippery44's Avatar
Quoted: 25 Post(s)
Liked: 24
Hello, I am interested in buying some entry level calibration for home use. After researching it seems I have a couple options in my price range (around ~250 dollars).
I can either go with a SpectraCal C3 meter bundle for around 150ish,
http://store.spectracal.com/c3.html
or go with the EyeOne Display 3 (i1 Display Pro) meter and use free software such as HCRF and then perhaps purchasing software at a later date.
Would you recommend going with the more expensive EyeOne Display 3 (i1 Display Pro) meter over the SpectraCal C3? Is it the superior meter for 100 dollars more? I will only be calibrating Plasma TVs with it, no projectors if that matters. I understand at some point I may want to get spectrograph to use in conjunction, but that's out of my budget at the moment.
slippery44 is offline
post #2 of 12 Old 12-03-2012, 09:58 AM
Light Illusion's Avatar
Quoted: 320 Post(s)
Liked: 627
I would suggest the i1 Display Pro OEM probe, and then you have all options available for any software...
I would not go for the Retail version, as that will limit your choices.
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #3 of 12 Old 12-03-2012, 10:14 AM - Thread Starter
slippery44's Avatar
Quoted: 25 Post(s)
Liked: 24
Ahh i didn't realize, that was the difference in the Retail version, thanks for your reply. So the i1 Display Pro OEM is worth the price increase over the SpectraCal C3? I was struggling finding a lot of detail around the C3
post #4 of 12 Old 12-03-2012, 10:39 AM
Quoted: 320 Post(s)
Liked: 627
Yep - I think it is worth a bit more as you will have a lot more flexibility.
The C3 is an older contact only probe, based on the old i1 Display 2.
Steve
Steve Shaw
LIGHT ILLUSION
post #5 of 12 Old 12-03-2012, 10:42 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
The C3 is based on the colormunki smile.
The tech specs for the meter are here at the bottom:
http://store.spectracal.com/consumer/meters/c3.html
The C3 is a very good meter compared to spyders, i1 Display 2, or even an old chroma5. But it isn't as good as the i1 Display Pro. The i1 Display Pro has optics, sealed filters, and better sensors (better lowlight sensitivity).
That said, you can get the C3 with tutorial license for $150 and it's $350 for the i1 Display Pro with a basic license. Apples to Apples it's $250 for a C3 with the basic license.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #6 of 12 Old 12-03-2012, 10:43 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Steve
No it isn't.
That is not correct.
Joel Barsotti
SpectraCal
sotti is offline
post #7 of 12 Old 12-03-2012, 01:40 PM
rpconrad's Avatar
Steve
Why does the retail version limit choices?
rpconrad is offline
post #8 of 12 Old 12-03-2012, 01:52 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Here is a list of all the versions and what works with what. The reason has to do with license agreements and how Xrite makes money..
http://www.avsforum.com/t/1342422/x-rites-revolutionary-new-colorimeter/1100_100#post_21528740
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #9 of 12 Old 12-03-2012, 02:02 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
It's also about support costs and warranty.
Joel Barsotti
SpectraCal
sotti is offline
post #10 of 12 Old 12-03-2012, 03:26 PM
derekjsmith's Avatar
Liked: 116
I guess it comes down to spend $149 for a complete package with the C3 or $249 for a D3 OEM and try to figure out how to use it with HCFR or a software bundle with a D3 for much more.
Also as Joel pointed out the C3 is not a rebadged D2. The D2 has been out of production for sometime. Yes the C3 looks like a D2 but that is all its has in common. The C3 has more in common with the Chroma5 than any other meter. Which in it's day the Chroma5 was the go to meter before the D3 or C6 came out.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #11 of 12 Old 12-04-2012, 10:40 AM
dschlic1's Avatar
Quoted: 73 Post(s)
Liked: 27
The i1Display Pro retail will work with the newer versions of HCFR.
LG OLED65B6P TV, Yamaha RX-V665 AV receiver, Sony BDP_S1700 Player, Klipsch F-30 speaker system
dschlic1 is offline
post #12 of 12 Old 12-05-2012, 07:27 AM - Thread Starter
slippery44's Avatar
Quoted: 25 Post(s)
Liked: 24
Thank you to everybody who took the time to reply to my post. As always everyone on this board is great and a ton of help. You've definitely given me enough information to help me decide which I'm going to go with.
Reply Display Calibration
