Alternative Contrast/Black Level/ Pluge patterns ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-12-2012, 08:09 AM - Thread Starter
spongebob's Avatar
Quoted: 97 Post(s)
Any alternative pluge or brightness patterns that can be downloaded or burned besides the flashing bars on the AVSHD disc? Those don't work at all on my 9G Kuro. What about a near black window instead? 1% 2%?
bob
spongebob is offline
post #2 of 10 Old 12-12-2012, 02:47 PM
hungro's Avatar
Quoted: 170 Post(s)
Liked: 115
bob
Hello, the AVSHD disk has a set of patterns that are under ColorHFCR which has the Near Black window patterns you are looking for .
Tom Huffman suggests the fallowing
Setting Black Level (Brightness)
The typical method for setting black level is to use a pluge pattern that displays just above and just below black information against a black background. You set brightness so that the just-above-black is barely visible and the just-below-black is invisible. The closer the just-above and just-below information is to video black, the more precise the adjustment.
Here's another method that works well. Put up a 0% field on the display. Turn brightness up several ticks. Now slowly start turning it down one click at a time. At some point you will find that lowering the brightness control further will not make the screen any darker. That is the correct setting.
hungro is offline
post #3 of 10 Old 12-12-2012, 05:08 PM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2439
bob
Doesn't work? Check for Video output vs PC. Does it work on other displays? If so there is a problem with your Kuro settings.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #4 of 10 Old 12-14-2012, 04:47 PM - Thread Starter
spongebob's Avatar
Quoted: 97 Post(s)
It works, it's just hard to see the difference in the bars unless I crank the brightness way up or get a few feet away from the screen. I'd prefer to use near black windows but Tom says that's not right?
bob
post #5 of 10 Old 12-26-2012, 01:39 AM
delphiplasma's Avatar
Quoted: 12 Post(s)
Hi,
This is much the same issue that afflicts crts. As black level improves the plugged patterns aren't that good, all three plugged bars show at all black level settings. I guess using 0ire pattern, as described in the previous mail, is the best way?
delphiplasma is offline
post #6 of 10 Old 12-26-2012, 03:06 AM
TheDor's Avatar
bob
1% 2% are near black.
What exactly do you think you need?
TheDor is offline
post #7 of 10 Old 12-26-2012, 07:06 AM - Thread Starter
spongebob's Avatar
Quoted: 97 Post(s)
I need to know what near black pattern should be visible and which one should disappear!
bob
post #8 of 10 Old 12-26-2012, 07:42 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
With a pluge pattern, the black background should not light up above the MLL of the display. The blacker than black bars should not be visible. All above black bars should be visible.
With the AVS pattern, the 16 level bar should not be flashing or changing in intensity. Levels 17 and up should flash/change, though with levels 17-19 you might have to be right up next to the screen to see it.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is offline
post #9 of 10 Old 12-26-2012, 08:05 PM
hungro's Avatar
Quoted: 170 Post(s)
Liked: 115
Tom mentions to focus on 18 instead of black stripe 17, making 18 barely visible .It's not in the bottom quote but he says it would be easir to focus on 18 instead of 17. You can read the posts in the chromapure thread if interested pag 124 i think biggrin.gif
1% above black is more like 18.
8-bit video spans 16-235. That is 219 code values, so there is not a one-to-one relationship between a code value and percent values. 17 is one code value above black, so close in fact that it may be hard to visually distinguish from 16. If you can see 18 but cannot see bars below 16, then that's good. If brightness is set too high, you'll be able to see bars below 16. If it is set too low, 18 will fade into the background and become invisible.
hungro is offline
post #10 of 10 Old 12-26-2012, 08:17 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
I take a third approach, I raise 16 till I can see it, then drop it till it turns blends, obviously if you don't have BTB to adjust with, then focusing on 17 or 18 is the way to do it.
17's visibility depends alot on the display, but 18 should always be visible with the correct setting.
But the brightness's job is to minimize the black level, if 2 or 5% needs to be brighter, that really is something that should be done with a gamma or multi-point control.
sotti is offline
Reply Display Calibration
