Chad B's custom test patterns - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 166 Old 03-14-2013, 03:36 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Originally Posted by PeterLewis View Post
I just burned the iso,are you saying the levels are off and the said iso is not proper for calibration?
No, the ISO should be correct. He was saying that someone else converted the png files to mp4 which were then used to make the ISO file.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #92 of 166 Old 03-14-2013, 03:54 PM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
No, the iso is fine. I need mp4 files like DrFaxe posted to author another. I do not have the software to create mp4's from png's. Chad posts his pattens in png format.
vega509 is offline
post #93 of 166 Old 03-14-2013, 03:58 PM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 124
Oh ok....Thanks little buddy for sharing the iso along with ChadB,drfaxe and airscapes.smile.gif
Sony OLED XBR-65A1E| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #94 of 166 Old 03-14-2013, 04:22 PM
chunon's Avatar
Quoted: 2494 Post(s)
Liked: 2231
Thank you so much I will be using this disc to cal my VT50 very soon, looks great smile.gif
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #95 of 166 Old 03-14-2013, 08:35 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Just a little updated.. The ISO does not play on my Panasonic 210 BRP but it does play on my Samsung but not all that well, skips through very fast have to pause it..
Doug
post #96 of 166 Old 03-14-2013, 09:45 PM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
It plays perfectly on my Panasonic BD655, Sony 360, and my Denon 1800BD, both DVD+R and DVD+RW discs. Maybe I should upload the folders and files, the ISO may have been corrupted somehow. Each pattern should play for 5 minutes. The iso can be tested on your pc if you have powererdvd, expand the iso to your hard drive and select the folder. If it plays correctly there is a problem with the media,or the burning speed. I've had some dvd's that had problems with burn speeds over 4x even though they were rated 16x.
Let me know.........
vega509 is offline
post #97 of 166 Old 03-15-2013, 02:10 AM
chunon's Avatar
Liked: 2231
No problems playing on my sony
Sony 75XBR940E
post #98 of 166 Old 03-15-2013, 04:16 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
The avs709 does the fast skip thing in the Samsung as well, always did. I will burn another copy and try the Panasonic again, maybe check firmware but I always fear updating it as who know what can happen to the out accuracy afterwards.
Doug
post #99 of 166 Old 03-15-2013, 08:22 AM
JukeBox360's Avatar
Liked: 53
Same here. Working very well.
JukeBox360 is offline
post #100 of 166 Old 03-15-2013, 09:17 AM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 124
Iso works fine on my PS3 but no worky,worky on my panny bdt310...
post #101 of 166 Old 03-15-2013, 09:25 AM
JukeBox360's Avatar
Liked: 53
Are you suppose to use these with limited or full RGB?
post #102 of 166 Old 03-15-2013, 04:25 PM
PlasmaPZ80U's Avatar
Quoted: 2315 Post(s)
Liked: 716
Originally Posted by Chad B View Post
Here's some test patterns I made on my Quantum Data pattern generator. I converted them to .PNG format and double checked the windows against CalMAN RGB tripletts. They are all generated with video levels, with black at 16. If playing on a media server, RGB PC levels should be used. Also, the .PNG format makes them ideal for use with the VideoForge pattern generator, which is how I use them now.
First are some normal (non APL) very small windows. They are approximately 4% size. normal 4% windows with pluge.zip 116k .zip file
Second are the same window sizes but in APL flavor loosely based on inspiration I got from the AVS 709 APL windows- thanks Alluringreality! They are in between the AVS 709 large and small APL size. apl 4% windows with pluge.zip 523k .zip file
Third is some miscellaneous patterns. custom test patterns.zip 97k .zip file
The gamma pattern is especially useful for checking 10 point white balance control mistracking. Example: with settings at default, take the blue (or whatever color you want to check) control at, say, 80% and turn it all the way down. Then display the gamma pattern. Run the contrast control up and down and observe if the discolored square remains at 80% or if it moves up to, say, 90%.
The color pattern can be used with the color filters for a quick meterless check of color decoder nonlinearities, as it has matching levels at 50, 75, and 100%. If red, for example, blends in with the gray surround at 50% (bottom horizontal row) and 75% (middle row) but is darker than the surround at 100% (top row), you know your color decoding is nonlinear and you can take steps to correct it (lower contrast, change panel brightness, etc).
The aspect pattern is handy for adjusting anamorphic lenses or lens memories on front PJs.
NEW!
AVCHD ISO image thanks to Vega509
75% Saturation / 75% Level APL Gamut patterns
aplReducedSaturation.zip 105k .zip file
75% Saturation / 75% Level normal approx 4% windows
standardReducedSat.zip 21k .zip file
does the iso in the above link include the two new pattern types below and are the levels all verified to be correct (RGB triplets or whatever their called)?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is online now
post #103 of 166 Old 03-15-2013, 04:35 PM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
Originally Posted by PlasmaPZ80U View Post
[/COLOR]
the iso was made previous to these last updates from Chad. The patterns were tested against the avchd patterns and checked ok.
vega509 is offline
post #104 of 166 Old 03-15-2013, 04:55 PM - Thread Starter
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
These new reduced saturation patterns I made sure had the same RGB tripletts as what CalMAN asked for for each respective color. Wouldn't hurt to have a second verification, though.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is online now
post #105 of 166 Old 03-15-2013, 05:48 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Update, burned iso at 4x still won't play in Panasonic 210.. anyone else with this player able to verify?
Doug
post #106 of 166 Old 03-15-2013, 07:14 PM
JukeBox360's Avatar
Liked: 53
Could I use this in my pa3?
post #107 of 166 Old 03-15-2013, 07:51 PM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
do you mean ps3? it probably will not work as the file structure is different for the ps3.
vega509 is offline
post #108 of 166 Old 03-15-2013, 08:02 PM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 124
Yes it works on my Ps3 but not my Panny BDT310...
post #109 of 166 Old 03-15-2013, 10:26 PM
JukeBox360's Avatar
Liked: 53
Y
yup. Stupid typo!
post #110 of 166 Old 03-16-2013, 04:43 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
Chad B
Why pattern 75% Saturation / 75% Level
Blue - 58-58-123 but should be 58-58-126
Yellow- 178-178-88 but should be 180-180-88
Magenta - 156-77-156 but should be 156-80-156
With respect, Andrei.
anta1974 is offline
post #111 of 166 Old 03-16-2013, 05:43 AM - Thread Starter
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
There seems to be a discrepancy between what CalMAN requests from the pattern generator and those "should be" numbers. I just double checked the triplet numbers against CalMAN. More info would be required to see if we can get to the bottom of this.
post #112 of 166 Old 03-16-2013, 06:25 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
Thank you very much
anta1974 is offline
post #113 of 166 Old 03-16-2013, 06:51 AM
DrFaxe's Avatar
Quoted: 24 Post(s)
Liked: 91
If You want to make BD ISO from the patterns, You should use .m2ts files as source to have no conversions that may cause changing the RGB levels. And You should verify by doing back conversion to picture files to see if the RGB levels are correct. We may can make a deal of it. If Chad has finalized his patterns, 8bit targa format appreciated using 8bit RGB as preset in software, I can convert to m2ts and one of You can master the ISO. I noticed some of the patterns I converted for chunon a wrong preset was used and had to be corrected by myself. Making correct BD ISO (with menu) from picture files is not as simple as some might believe.
S/W: LightSpace HCC, Calman 5, DisplayCal/ArgyllCMS
H/W: CR-100, I1Pro2, I1D3, eeColor, RB8 Generator
Tools: ControlCal, Ted's LightSpace CMS Calibration Disk
DrFaxe is offline
post #114 of 166 Old 03-16-2013, 06:56 AM
eghill1125's Avatar
Chad,
I was just looking at the contrast pattern. For me to be able to see all 3 bars in full without losing any of the corners on them, I have to set my contrast at 76 out of 100. On almost all of the calibration sites for my LG TV, places like Cnet and others have contrast at 90.
Am I reading the pattern correct and we are to be able to see the full bar and not lose a corner to the backgraound?
Ed
PSN - eghill1125
eghill1125 is offline
post #115 of 166 Old 03-16-2013, 07:12 AM - Thread Starter
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
It may be the local dimming. LD on may need a lower contrast setting than LD off.
Also, from the way you are wording it I am not sure you're if you are using it correctly. The idea is that with a flat panel (non-CRT) you should adjust the contrast so you can still see the whitest strip in the middle of the bright box. The bright box is at 235 (100%), the whitest strip at 245. Then there are two strips just slightly darker (98%). If the whitest strip becomes compressed or starts to blend into the bright box, that means you are compressing or clipping WTW. Depending on your calibration philosophy, you may want to keep the contrast below the point where that becomes apparent.
If the slightly darker strips (98%) start to blend in as well or disappear, you are clipping actual video white and definitely should back the contrast down.
post #116 of 166 Old 03-16-2013, 08:09 AM
JukeBox360's Avatar
Liked: 53
Sometimes I swear I'm not reading English in here lol.
post #117 of 166 Old 03-16-2013, 08:32 AM
eghill1125's Avatar
Ok.
I will have another look at it. From what i remember when I looked last night, I could turn my contrast up some more and still see the WTW bar, but I do seem to lose the 2 98% bars. Seems like that shouldn't happen in that order though. The LD on the LG does make a big difference on all patterns and measures. I think at this point, I am going to leave it on high the whole way through my next calibration and see what results I get. Turning it off for measures and then back on after has big differences. I think that may be coming into play on these patterns too.
I know from the contrast pattern that I should hit the point right before I lose WTW and still be able to see the 98% bars, but my TV is not playing nice with it for some reason.
Ed
PSN - eghill1125
post #118 of 166 Old 03-16-2013, 10:51 AM
Liked: 716
will there be an update in the near future that includes the two new pattern types too?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #119 of 166 Old 03-16-2013, 11:32 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Would be nice if this could be master by the same person that did the 709 disk as that seems to work in most all players these days.
Doug
post #120 of 166 Old 03-16-2013, 02:33 PM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
did you just burn the iso to a dvd, or did you use imageburn and burn the dvd from the iso image?
when you look at the dvd in explorer, do you see one file "chads.iso" or directories "BDVM" and "HDAVCTN"?
vega509 is offline
Reply Display Calibration
