Anyone has a hdtv that can achieve rec709 color space in terms of calibration? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-22-2012, 06:39 PM - Thread Starter
steelclaw174's Avatar
*title
Does anyone have or know a hdtv that can achieve near perfect rec709 accuracy after calibration.
steelclaw174 is offline
post #2 of 7 Old 12-22-2012, 06:56 PM
Otto Pylot's Avatar
Quoted: 1361 Post(s)
Liked: 853
Originally Posted by steelclaw174 View Post
*title
Every tv is different, even within the same model line, so there really isn't a particular model that can achieve what you want. It all depends on the tv and the calibrator.
Otto Pylot is offline
post #3 of 7 Old 12-22-2012, 07:43 PM - Thread Starter
so no hdtv is specifically design to be close to rec709 standards, i refuse to believe that it is impossible to reach a perfect gamut on current hdtvs
post #4 of 7 Old 12-22-2012, 08:14 PM
Otto Pylot's Avatar
Liked: 853
All current tv's (well, at least most) have the capability of achieving rec.709 standards but it depends on the amount of user controls available, panel type, etc. No mfr, to my knowledge, specifically states that their tv's will meet rec.709 standards out of the box. Source is a big factor. Nothing is perfect and if that's what you are looking for, you have long search ahead. A professional calibration may help.
post #5 of 7 Old 12-22-2012, 08:38 PM - Thread Starter
ok thanks, so can anyone recomend mea tv with a lot of controls for calibration. Is there one with deeper controls than the Samsung models, I couldn't for the life of me get green to the levels i wanted, they always were oversatturated in the colo gamut, resulting in neon greens.
post #6 of 7 Old 12-22-2012, 09:19 PM
MechanicalMan's Avatar
FWIW, buying a TV with the most controls for calibration won't necessarily result in the best color or best overall image quality. For example, you can make lots of adjustments on all of LG's TVs, but the color after calibration might still be worse than on other TVs with fewer controls. Katzmaier noted that in his review of the LG LM7600, saying that color appeared worse on that TV than on others (like the Panasonic ST50) that provide much less control over the image. LG's flagship plasma was given low marks for color accuracy in the 2012 HDTV Shootout. My own LG plasma has "inconsistent" red hue; it is green-ish at 100% saturation and blue-ish at 75%. The TV has a CMS, but it won't correct a problem like that -- all I can do is compromise, making the inaccuracy about even at both points. There are all kinds of similar problems that you may see while calibrating a TV, some of which may not even be measurable; the color may look better or worse to you than it actually measures. I'm not sure which Samsung TV you have, but I believe that Samsung's newest TVs (both plasma and LCD) have the reputation of being some of the most color accurate TVs available. The VT50 also has an excellent reputation for color accuracy, and it has more calibration controls than the cheaper Panasonic models.
MechanicalMan is offline
post #7 of 7 Old 12-22-2012, 09:24 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
There are TVs "that can achieve near perfect rec709 accuracy after calibration." Here is one example from zoyd. It is for a PN51D8000. http://www.avsforum.com/t/1333561/samsung-d7000-d8000-settings-calibration-thread#post_20405730
Here is his gamut:
as shown in the referenced post.
Larry
LarryInRI is offline
Reply Display Calibration
