Disney WOW Calibration (DVD vs. BluRay) - AVS Forum | Home Theater Discussions And Reviews
Old 12-23-2012, 08:06 AM - Thread Starter
jmiller284's Avatar
I want to calibrate my new Samsung 55 inch LED and someone in another forum mentioned the Disney WOW calibration disc. I do not own a BluRay player, just a standard "upconvert" DVD player. My question is this.. The Disney WOW tool comes in both BluRay format and DVD. Would there be a difference between the two types in terms of calibrating? In other words if I tried to calibrate using the DVD and not BluRay will it mess up my LED display? Anyone try and can feedback? Would it even matter?
jmiller284 is offline
Old 12-23-2012, 10:48 AM
ThePrisoner's Avatar
Quoted: 221 Post(s)
Liked: 149
Your fine using the DVD version since you don't own a blu-ray player.
Dolby Atmos/DTS:X 5.2.4
Samsung 65JS8500 (calibrated by Gregg Loewen); Marantz SR6010 + Onkyo M-5010; Oppo UDP-203; Apple TV (4th Gen); PS4; Definitive Technology BP-8060ST, CS-8060HD, SR-8040BP, Pro-Monitor 800; SVS PC-12NSD (2)
ThePrisoner is offline
Old 12-24-2012, 05:11 AM
colin.p's Avatar
I am in the same situation as you. I don't have a BD player, and won't for the foreseeable future. I bought the DVD version of WOW and used it to calibrate one (DVD) input. I was able to get the picture looking pretty good, however, the audio part wasn't as critical as I had already dialed that in with previously downloaded tools. I then downloaded the AVSHD files, from this site, and will make a BluRay disk when the need arises.
I used the mp4 version of AVHCD for the input of my WDTVLive and even though the settings weren't identical, they were pretty close to the WOW.
colin.p is offline
