How do I know if my calibration is good for my DVR? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-28-2012, 05:46 PM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
I calibrated my TV using the AVSHD blu-ray through my PS3. I use all the same settings for HDTV from Time Warner which comes through my DVR/cable box. I'm wondering how accurate these are? I notice a LOT of inconsistency between HD channels. Some look spectacular, and others just look meh. It would be nice if Time Warner would have an HD test pattern on one of their channels, so at least I could make sure basic things like color, contrast and brightness are reasonable, but I've yet to find one.
So, do I just calibrate my TV with my blu-ray and trust that those settings are good enough for the cable box?confused.gif
milehighou is offline
post #2 of 9 Old 12-28-2012, 05:48 PM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1773
i have time warner also and had a pro cal same experience with channel inconsistency not much you can do really
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #3 of 9 Old 12-29-2012, 01:52 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
There was a channel that broadcast a color bar target periodically but it was a complete waste of time. All it did was calibrate you to that channel... none of the other channels matched exactly (some may have been close, others not so much). Furthermore, every PROGRAM is different so even if you calibrate to one channel, every time they change programs, you might need some fine tuning. So what's the point?
Furthermore, digital video has more or less eliminated variations... the cable box would have to intelligently process the video to CHANGE it. The video data is 1s and 0s that can't be "good" or "bad" they can only be 1 or 0. There is no 1.0007 or .0098... you have either nothing (loss of video) or a combination of 1s and 0s. If the combination of 1s and 0s is not precise, you also lose the video completely since the ORDER of the 1s and 0s has to be very precise.... move them just one "slot" forward or back (in time) and you're likely to lose video altogether. All the box does is transmit the 1s and 0s that it receives from Velocity, CNN, or ABC. The only processing the box does is perhaps to convert 480 to 1080 or 720 to 1080, etc. and that might be messed up... but if your box sends whatever it receives, there's really no point in "calibrating the box" that's just an old concept from the analog video days that really no longer applies. Bottom line... you have 200+ channels running 2000+ shows every day and all of them are just a little different from each other. You can't stop it and you can't compensate for it.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #4 of 9 Old 12-29-2012, 04:08 PM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
Even the same content can be different as they switch from camera to camera. Fox News uses as many as 4 cameras for their studio programs and two of them aren't even close. The bottom line is that for TV programs, calibrate the display, because the programs themselves are a crapshoot.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #5 of 9 Old 12-29-2012, 08:01 PM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
I've found turning up red balances things a bit but harms colors some.When I adjusted colors for a higher than 6500 k number I would get greens in the dark parts of screen on some shows.
Vic12345 is offline
post #6 of 9 Old 12-29-2012, 08:08 PM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
OK, so at least I'm not crazy:cool:...just really anal, I guess, haha. Almost all the HD channels look good in terms of sharpness and resolution, but color seems to vary and picture quality changes. I've also noticed that sometimes on a channel where the PQ is just so-so, a commercial will come on and look spectacular. It seems that a lot of the times, the commercials actually look better than the program I'm watching.
post #7 of 9 Old 12-29-2012, 09:21 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #8 of 9 Old 12-30-2012, 07:06 AM
chunon's Avatar
Liked: 1773
You'll learn to live with it honestly, I see the exact same thing.
65C6 OLED
chunon is offline
post #9 of 9 Old 12-30-2012, 12:39 PM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
Reply Display Calibration
