Data from c6 / i1pro, is it off? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-30-2012, 02:16 PM - Thread Starter
Calby's Avatar
Quoted: 13 Post(s)
Hi,
I have just measured my c6 and my i1pro at CMS with CalMan V5 at my LG plasma.
Is the results very different or is it OK?
Do you think one of the meters is off standard?
The meters is not at the exact same spot at the TV, but I tried to have it one the same spot but it's difficult as you know to have it exactly.
I did not profile any of the meters it's just out of box.
I measured it with 75%.
100W at 100IRE
White at 75IRE
c6:
i1pro:
I hope you understand, my english is not so good.
Thanks for your help.
Calby is offline
post #2 of 4 Old 12-30-2012, 02:43 PM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2439
Hi Calby. That looks normal. Now profile the C6 from the i1Pro and check to see that the measurements from the newly profiled C6 closely match those of the i1Pro. Once checked, use the profiled C6 and put the spectro back in the box.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #3 of 4 Old 12-30-2012, 02:44 PM - Thread Starter
Calby's Avatar
Quoted: 13 Post(s)
Perfect,
I use to profile my c6 against the i1pro and then calibrate greyscale and then use the i1pro to CMS
Calby is offline
post #4 of 4 Old 12-30-2012, 02:45 PM
buzzard767's Avatar
Liked: 2439
Originally Posted by Calby View Post
Perfect,
Buzz
Reply Display Calibration
