Calibrate for 0-255 or 16-235? - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1 of 70 Old 01-22-2013, 01:30 PM - Thread Starter
BartMan01's Avatar
My new primary display (projector) can be set to expect either 0-255 or 16-235. Video sources are:
HTPC (ATI Graphics): TV/DVD/BluRay/HDDVD playback.
PS3: Games, streaming video, 3D content.
XBox 360: Games, streaming video.
From everything I am reading, it appears that with the HTPC being the primary 'critical content' display device I would be better off calibrating and setting everything to use the 0-255 RGB color space. Is that correct?
Projector also has an 'auto' mode (0-255 or 16-235), but I am thinking it woudl be better to pick one color space and explicitly set everything to use that.
BartMan01 is offline
post #2 of 70 Old 01-22-2013, 03:15 PM
rahzel's Avatar
Liked: 148
IMO, yes. Since video cards output RGB 0-255, it makes more sense to output this and avoid additional conversions. As long as every other connected device can output 0-255 and your display supports 0-255, that's what I'd recommend.
Be careful with 'Auto' settings... some displays don't correctly identify the input range (my ST50 for example). I would force 0-255.
rahzel is offline
post #3 of 70 Old 01-22-2013, 06:51 PM
ttnuagmada's Avatar
Quoted: 136 Post(s)
Liked: 133
The projector may accept 0-255, but I would imagine that it converts to 16-235.
The best way to do things from my understanding with your HTPC is:
GPU: 0-255
video player: 16-235
projector:16-235
This should prevent any video level conversion. However, you'll have to set the projector brightness according to your video player, and since it's set to 16-235, this means that anything else you do on your HTPC is going to have crushed blacks.
ttnuagmada is offline
post #4 of 70 Old 01-22-2013, 07:41 PM
rahzel's Avatar
Liked: 148
That method allows you to view blacker than black and whiter than white information in videos. But as you said, it will clip detail in the desktop because the levels aren't matched. My config sets everything the same so the levels are all matched, but you can't see BTB/WTW detail. If you have no regards for the desktop, then that setup is ideal, yes. Most detail above 235 are from ringing artifacts (see this post) and detail below 16 won't be visible because you won't be able to see it on a set with a properly set brightness. So it's a matter of compromises.
rahzel is offline
post #5 of 70 Old 01-23-2013, 01:35 AM
alamagar's Avatar
Rahzel, when you say my config sets everything the same levels, you mean 16-235 for GPU, video player and display. is that true?
Then the only diffence between your sets and the one commented by ttnuagmada is that in this last option we are crushing other than video player in the htpc?
alamagar is offline
post #6 of 70 Old 01-23-2013, 02:34 AM
rahzel's Avatar
Liked: 148
No, I mean 0-255 for the GPU, video player and display. But setting everything to 16-235 will be essentially the same. I'm against setting everything to 16-235 because then there's extra conversions. AFAIK, there aren't any GPUs that can output native 16-235 and 16-235 will always get expanded to 0-255 regardless, so setting everything to 16-235 will cause the GPU to scale up to 0-255, then back down to 16-235. Setting the player to output 0-255 will avoid this extra step. The only benefit to ttnuagmada's setup, is that you can see BTB/WTW detail, but the downside is that you clip levels below 16 and above 235 in the desktop.
Setup 1 (my setup):
GPU outputs 0-255
Video player outputs 0-255
Display expects 0-255
Desktop and videos have matched levels where 0 is black and 255 is white, and the display is expecting this range. Videos get expanded from 16-235 to 0-255 once. The desktop gets no conversion because the GPU is outputting native 0-255.
Setup 2:
GPU outputs 16-235
Video player outputs 16-235
Display expects 16-235
Again, desktop and videos have matched levels and the display is expecting a range of 16-235 where 16 is black and 235 is white. Videos get expanded from 16-235 to 0-255, then back down to 16-235. The GPU converts 0-255 to 16-235 for the desktop. Result looks essentially the same as setup 1, but with more conversions.
Setup 3 (ttnuagmada's setup):
GPU outputs 0-255
Now the display expects a range of 16-235, but the desktop is outputting 0-255. So videos will look right, but the desktop will clip levels below 16 and above 235. Again, this is the only way to be able to see WTW/BTB detail on a computer.
alamagar likes this.
rahzel is offline
post #7 of 70 Old 01-23-2013, 10:12 AM
alamagar's Avatar
Thank you very much Rahzel for the clear explanation.
This used to be a confusing issue.
alamagar is offline
post #8 of 70 Old 01-23-2013, 10:42 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
I use option 2, because it matches all my other video components.
Also the video isn't really getting scaled and re-scaled. The video driver gets the dxva input and then formats when it does the final write into the buffer.
sotti is offline
post #9 of 70 Old 01-23-2013, 07:17 PM
ttnuagmada's Avatar
Quoted: 136 Post(s)
Liked: 133
So would there be no difference in video quality between option 2 and 3? I've always run option 3, because I was under the impression that it was the only way to do things without any level conversion.
post #10 of 70 Old 01-23-2013, 09:46 PM
rahzel's Avatar
Liked: 148
There's really no difference in any of the options when it comes to video. But option 1 or 2 make the most sense to me.
rahzel is offline
post #11 of 70 Old 01-23-2013, 10:03 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
I use option 2!
pokekevin is offline
post #12 of 70 Old 01-23-2013, 10:58 PM - Thread Starter
BartMan01's Avatar
I'm trying to do option 1, but the computer is fighting me. Here is what I did:
Set projector to HDMI full
Set PS3 to RGB full superwhite = off
Set Xbox to full
Set computer in ATI control panel to pixel format of RGB 4:4:4 full, video to 0-255.
Set black and white point with Disney WOW disk in the PS3 (I figure this is the 'best' device for bluray playback that I know is outputting the color space I told it to).
Video on PS3 looks fine.
XBox looks correct from a quick glance.
PC has crushed blacks/whites. If I switch to a different projector preset calibrated for 16-235, PC looks correct.
What am I missing here?
post #13 of 70 Old 01-23-2013, 11:00 PM
ttnuagmada's Avatar
Quoted: 136 Post(s)
Liked: 133
I agree that 2 makes the most sense in general, I just figured that 3 would be the optimal choice if video was the only concern.
post #14 of 70 Old 01-24-2013, 08:07 AM
Chronoptimist's Avatar
Liked: 543
Never output anything other than RGB 0-255 from a PC source unless you have no other option. Everything other than video is rendered natively in the 0-255 range, so you are compressing levels to achieve a 16-235 output. Most video cards do not do this with especially high precision and will introduce banding into the image.
If you use a high quality video renderer (e.g. madVR) there will be no difference in video quality from the levels expansion from 16-235 to 0-255. You will "lose" below black and above white information, but those are not valid ranges for video, and should only be seen on test discs, not commercially released content.
holdemphil likes this.
Chronoptimist is offline
post #15 of 70 Old 01-24-2013, 08:25 AM
praz's Avatar
Liked: 26
I do the same. The only purpose of my HTPC is for stored movies/TV shows. What this does to the desktop or other non-video content is irrelevant in this usage scenario.
praz is offline
post #16 of 70 Old 01-24-2013, 10:30 AM
rahzel's Avatar
Liked: 148
I agree 100%. I would only output 16-235 if you have to (ie your other components can't output 0-255, like sotti's case). Anyone who cares about quality should be using madVR, too.
rahzel is offline
post #17 of 70 Old 01-24-2013, 10:01 PM - Thread Starter
BartMan01's Avatar
Looks like for the moment, option 2 is best choice for me. I have been unable to get a consistent calibration (brightness and contrast setting wise) across all devices using 0-255, but it looks like can get that with everything set to 16-235. Based on all of the feedback, if I can get 0-255 working I would be better off with that (for games/pictures/etc) so when I have enough time to spend several hours I may re-try to get 0-255 working.
post #18 of 70 Old 01-24-2013, 10:27 PM
ttnuagmada's Avatar
Quoted: 136 Post(s)
Liked: 133
In my situation (option 3), my other components are fine, because i calibrate brightness and contrast to MPC/MadVR (16-235) and not the desktop. Unless I'm missing something, if video playback was the only concern with an HTPC, option 3 would be the best option, even if you have other video components, because you avoid any video level conversions, while still having your TV brightness set correctly for a cable box/Blu-ray player.
I've checked brightness against my PS3 and they match up perfectly, everything seems fine on my cable box as well.
post #19 of 70 Old 01-25-2013, 09:50 AM
Liked: 543
0-255 output from the PC, and 0-255 from madVR will look better because it has more bits to work with to do the YCC>RGB conversion, colorspace conversions, gamma/3DLUT processing etc.
post #20 of 70 Old 01-25-2013, 12:03 PM
ttnuagmada's Avatar
Quoted: 136 Post(s)
Liked: 133
Won't that all be negated by my TV having to convert it to 16-235? I was under the impression that having the TV do a level conversion is what you want to avoid most.
post #21 of 70 Old 01-25-2013, 12:09 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Your TV processes at much higher bit depth, and as it processes the signal, it will eventually be turning into a full range signal at some point in the processing.
sotti is offline
post #22 of 70 Old 01-25-2013, 12:20 PM
ttnuagmada's Avatar
Quoted: 136 Post(s)
Liked: 133
I guess I've been going about this the wrong way then. Will my calibration still be good if I make those changes, or will I need to touch it up?
post #23 of 70 Old 01-25-2013, 01:18 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
When ever you change anything touching up is a good idea.
What I meant about always being converted to full range, is that actual light engine for your display will take 0 for off, and a maximum value(255, 1023, 4096, ect..) for max output.
sotti is offline
post #24 of 70 Old 01-25-2013, 06:25 PM
ttnuagmada's Avatar
Quoted: 136 Post(s)
Liked: 133
I appreciate you guys clearing that up for me. I thought I had this all figured out.
post #25 of 70 Old 01-27-2013, 03:21 AM
alamagar's Avatar
OMG, I thought it was clear after Rahzel answer describing the 3 options, but after a dozen of answers now I'm confused again.
Until now I use option 3 with this config:
GPU: Nvidia - Full 0-255. YCbCr
Video Player:
  • player: MPC - option output range 16-235 in renderer settings
  • render: EVR-CP - no specific option other than previous AFAIK
  • decoder: LAV Video decoder: option RGB output levels 16-235 (I'm not sure if this option has any influence)
Display:
  • Plasma: Panasonic PX70E.No specific option. I think it autoadapts.
  • Projector: Mitsubishi HC7000. Input:YCbCr
and I'm glad with the results.
Chronoptimist:
  1. You say not only output 0-255 (I assume from GPU and MPC) but RGB and not YCbCr. Up to now I've read to output YCbCr from computer. Why RGB?
  2. I tried madVR as a renderer. If I set output level to 0-255, I getting the same as EVR-CP with 16-235. But if I set it to 16-235, I can see BTB and WTW. Never get them with EVR-CP but I need to reset brightness and control because with previous EVR-CP settings black is grey and not black. New setting controls are far lower for brightness in order to set clipping patterncorrectly and higher for contrast in order to get same Y value: 35 ftL. Am I going to get the same overall quality and black levels with 0-255 and 16-235 if I set brightness and contrast levels properly?. Is really no difference between them?
Also the video isn't really getting scaled and re-scaled. The video driver gets the dxva input and then formats when it does the final write into the buffer..
Sotti/Rahzel:
What are you saying is that you use option 2 to match bluray or other sources and then you use the same calibration settings for all of them? I've always understood that is better to calibrate each source independently and use its specific settings. Is it reliable to calibrate with HTPC(16-235) or bluray and use these settings for both with the same quality and accuracy?
alamagar is offline
post #26 of 70 Old 01-27-2013, 07:12 PM
Liked: 543
You should switch to MPC-HC, if you aren't already running it.
I would suggest switching to madVR if your system can handle it, as it is much better quality than EVR.
This shouldn't make a difference unless LAV is converting from YCC to RGB. Unless you've disabled all the YCC output formats, it should not be doing that. (you shouldn't disable any formats in LAV Video, leave it at the defaults)
I'm unsure if this is too old to have a full range RGB setting. (often labelled "black level") You will have to try it and see.
PCs are different from stand-alone Blu-ray players, and render everything natively in 0-255 RGB. This means that you have a YCC (the video file) to RGB (the player/renderer) to YCC (video card output) conversion if you output YCbCr, and that last step is often done with poor precision. (by the video card) If you use madVR, the first YCC > RGB conversion will be done with very high quality. (16-bit per channel rather than 8/10bpc)
I also disagree with the sentiment that stand-alone Blu-ray players should be outputting YCC too, but if it's 4:4:4 it shouldn't be too bad. It really depends on whether your display processes as RGB or YCC internally - at the end it's always going to end up as red, green, and blue pixels.
It seems most are now using YCC for processing though, which often means throwing away half the chroma resolution - if they process in YCC, it's typically 4:2:2. But you are better to have the display perform that RGB to YCC conversion than the video card, as it's typically done with much more precision.
madVR does not use the "standard" nomenclature that most video players/renderers on PC use. It uses correct nomenclature, which is basically reversed from most other players/renderers. You should output 0-255 to have it do level expansion and clip below-black and above-white information.
Always calibrate each source independently. In an ideal world, all players will be outputting exactly the same levels but that is often not the case. And most displays should not need recalibrated when switching between 16-235 and 0-255 output, but you will have to check it.
post #27 of 70 Old 01-28-2013, 01:37 AM
alamagar's Avatar
Thank you Chronoptimist.
I'm using MPC-HC.
I'm goint to try this settings today:
  • GPU: RGB, 0-255
  • Renderer: madvr, 0-255
  • Video player: mpc-hc
  • Display: No option for Plasma Panasonic. RGB for Mitsu projector.
I'll share the results.
alamagar is offline
post #28 of 70 Old 02-27-2013, 04:08 PM
Shinyav's Avatar
Just sharing my experience. With an ST30 accepting full range from gpu/madvr I was getting color banding issues in fog and gradients that would be many shades different in the green direction. I seemed also unable to calibrate them away as the shades would shift for only a few %s out of the grey scale. Switching to 16-235 output from madvr and setting my tv to standard input range has eliminated the problem. Is this perhaps a problem with the st30s?
Edit: seems I am still getting some problems. Just at different places than before, so my go to scenes to see this problem were not there.
Shinyav is offline
post #29 of 70 Old 09-23-2014, 05:11 PM
bcec's Avatar
Quoted: 207 Post(s)
Liked: 108
Sorry for resurrecting this old thread. I understand that <16 and >235 (btb, wtw) is pretty much artifacts and don't really contain a valid signal. But still, I don't understand what makes 0-255 superior over setting renderer/player+tv to output&accept 16-235. You certainly don't get wider range by stretching 16-235 to 0-255, in fact, you get incorrect gradient:
As far as I understand, 16-235 to 0-255 is simply a mapping of 16-235 values into 0-255 ones. The result of this mathematical mapping is that you end up with floating point numbers but they will have to be rounded to integer values when sent through HDMI. For instance, 19 will mathematically correspond to 3.49, but will be sent as 3. 20 will correspond to 4.65, but will be sent as 5. You will never have 4, and what's more, due to rounding, you will get a gradient (3 instead of 3.49, 5 instead of 4.65 etc) that is not 100% accurate to the source.
So the best setup for video (if you don't care about crushed blacks on desktop) is option #3
ONDr likes this.
bcec is offline
post #30 of 70 Old 02-01-2016, 06:10 AM
SoulOfUniverse's Avatar
Quoted: 123 Post(s)
Liked: 40
Very interesting thread and its exactly the same problem I've encountered recently. I've noticed that last two years I was missing a lot information from color point of view when watched Videos.
First of all you should understand (newbies to that) when you choose software players - they use different rendering controls, it could be DirectX rendering control, it could be GPU rendering control, could be anything else, and depending on that factor - result will always be different.
High End projectors designed for movies 2d and 3d mainly, so I won't be clarifying here how to calibrate your projector in order to view PC desktop, i.e. different graphics and etc. For me my main task is how to configure correctly your chain in order to display movies as they should be displayed.
I use MPC-HC + madVR (renderrer), madVR renderer is a unique render across all famous renders provided in our days and is the most GPU effective, as their algorithms allow you to reuse GPU element at its 100%, thus upscaling, sharping and other effects - they performed at best quality. The same relates to Output SIGNAL. I would agree to those who said that option 3 is the best, but I would mark one thing as when using MPC-HC + madVR it doesn't rely on the settings you set in your GPU as how the signal is performed, as madVR uses its own algorithm how to process the signal. This effect will take in place only for Windows Media PLayers as its algorithm are reusing GPU directDraw how signal is processed, in that case it is important that in Video settings of your GPU you set it to RGB Full, as by default it is RGB Limited in every GPU.
Now if you load any movie and use my described method MPC-HC + madVR, set in madVR output signal as PC (0-255) readjust your contrast and brightness accordingly using AVCHD test patterns, preferably to use Misc Patterns -> A - Greyscale where it shows all marks how white should be displayed at 235 level and black should be displayed at 16 (to find out more go https://dl.dropboxusercontent.com/u/...rns-Manual.pdf refer A2 Greyscale Steps), choose some scene which has a lot details in deep black area, take photo. Now switch in MadVR output signal as TV (16-235) and readjust your contrast and brightness again accordingly and take a picture. You'll notice a big difference that using TV (16-235) provides much more detail of deep black and gray levels, where PC (0-255) will make everything black however you'll notice from previous screenshot that it should contain more details (shades and more detailed picture of dark object). And its not about BTB or WTW effect, this is how it should be displayed and only that way. The only problem is that when you have that chain
MPC-HC/madVR (16-235) -> GPU (doesn't metter what setting as madVR will always overwrite it, you can test it) -> Projector (Input signal Standard i.e. 16-235) it is a bit more difficult to calibrate your projector's gamma to be consistent as my settings of brightness should be set to -23 and contrast to +9 this cause curve of gamma to be inconsistent and I'm still in process to finalize calibration. Despite that small problem video quality is just superb!
Please don't compare anything other than that, when you feed 4k pattern signal generators or use native JVC generators it will be calibrated for playing videos from Blu Players - not PC so playing it from PC won't be the same calibrated result, even with the method I've described above.
I'll probably release youtube video to close a lot of questions with all different tests and results, the only problem it takes so much time - couple of days ago I've spent around 4 hours for two days and I still need more time to fully understand how it all works.
SoulOfUniverse is offline
Reply Display Calibration
