What Calman bundle to buy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-25-2013, 04:29 AM - Thread Starter
keeefan's Avatar
Dear Friends,
I am about to update my calibration equipment. As I today run Calman 4 with the X2 meter (basically an eye one display 2 with tables for newer backlight standards) and feel comfortable with this system would like to remain as a Calman user.
My budget is limited, perhaps I can spend some $1000-1400 ex freight. The question is what I should go for… The tools will not be used very often, perhaps once a month but when used it needs it to be pretty reliable. The products I work with are all LCD/LED and currently does not have any auto calibration interface. The pattern source I use today is a WD TV Live media player with AVS HD patterns. (I also have a PS3 available).
The options I consider are listed below. Of course I do not want to spend more money than necessary, but as they have different functions/options I need your help to give me a push to the best choice for my needs. Please also comment if you have any other suggestion or any more information needed.
CalMAN 5 Control with i1 Pro 2 995:-
X-Rite i1Pro 2 Enhanced + CalMAN 5 Control 1290:-
X-Rite i1Pro 2 Enhanced + CalMAN 5 Enthusiast 1390:-
CalMAN 5 Enthusiast with SpectraCal C6 and DPG-2000 Bundle 1399:-
keeefan is offline
post #2 of 9 Old 01-25-2013, 04:39 AM
visca blaugrana's Avatar
I would go with the enthusiast and the i1 pro option that is a really good combo, on top of that you could in the future if you want add a i1 pro display. But as a bundle that is a killer package.
visca blaugrana is offline
post #3 of 9 Old 01-27-2013, 08:24 AM
knmlee's Avatar
I'm also interested in a Calman bundle and would appreciate your suggestions. I'm new to this, having only done manual adjustments with DVE in the past. I will be calibrating a Panasonic VT50 and a JVC X3 projector. I tend to upgrade one of these every year. My VT50 is connected to my network, so I'd like to be able to create the ISF day and night configurations. Which bundle would you recommend?
Thanks in advance.
Mark
knmlee is offline
post #4 of 9 Old 01-27-2013, 09:23 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Thanks in advance.
Mark
To use our AutoCal Features you'll need CalMAN Control or CalMAN Enthusiast. CalMAN enthusiast adds design mode which lets you customize the workflows and also the ability to calibrate a 3D LUT in the radiance or colorbox.
As for the meter you'd want, the OEM i1 Display Pro is a great value
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #5 of 9 Old 01-27-2013, 01:55 PM
Thunderduck's Avatar
Quoted: 54 Post(s)
Liked: 25
Does this meter require yearly calibration?
Tks,
Steve
Thunderduck is offline
post #6 of 9 Old 01-27-2013, 02:11 PM
derekjsmith's Avatar
Liked: 116
Tks,
Steve
No the D3/C6 are very stable. You would only need to send one of them back in for NIST re-cert if you needed a current NIST cert.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #7 of 9 Old 01-27-2013, 02:32 PM
turbe's Avatar
Liked: 95
Just to be clear, the only recert service available on the SpectraCal site is for the C6, there is no recert option for the OEM or Retail i1D3..
+1
As far as meters, I always recommend a i1Pro 1/2 Spectrometer..
Why a Spectro? See why here:
http://www.avsforum.com/t/1373556/i1-pro-or-d3-if-you-could-only-have-one-meter
http://www.tlvexp.ca/2012/04/do-calibration-tables-really-work-for-tri-stim-devices/
And Read this Thread:
http://www.avsforum.com/t/1449310/eye-one-pro-or-display-3-pro
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #8 of 9 Old 01-27-2013, 04:47 PM
Quoted: 54 Post(s)
Liked: 25
Thank you Derek and Turbe.
Steve
post #9 of 9 Old 01-29-2013, 12:49 AM - Thread Starter
keeefan's Avatar
Dear All,
Tks for your advices.
/ Keeef
keeefan is offline
Reply Display Calibration
