LightSpace 3D LUT Home Cinema Calibration Software - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 41Likes
post #241 of 263 Unread 11-17-2015, 05:10 AM
ConnecTEDDD's Avatar
Quoted: 580 Post(s)
Liked: 956
There is a bug that slipped through in the latest LightSpace build release.
It was fixed, but reappeared in the release build.
When looking at a profile via the ‘Manage Colour Space’ library, and ‘Display’, the Min/Max Luma values are wrong!
They are correct within the measurement data file (.bcs), but displayed incorrectly.
LightSpace dev. team is fixing that issue now, and a new version will be release very soon.
alex_t likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #242 of 263 Unread 11-17-2015, 03:05 PM
zoyd's Avatar
Quoted: 1131 Post(s)
Liked: 886
Originally Posted by ConnecTEDDD View Post
Seems that GIMP made some changes to earlier versions after the instructions written. I have just uploaded an older version of GIMP which saves properly.
It's fine to use the new version and just rename the raw export from file.data to file.raw
ConnecTEDDD and W3Rman like this.
zoyd is online now
post #243 of 263 Unread 11-18-2015, 12:38 AM
Quoted: 580 Post(s)
Liked: 956
Thanks for confirming that it works with a simple file rename, using the latest GIMP release.
post #244 of 263 Unread 11-18-2015, 07:12 AM
Light Illusion's Avatar
Quoted: 140 Post(s)
Liked: 386
New release just uploaded.
Fixes the Luma display value issue, and adds Append/Prepend to the 'Maths' functions.
(If you have the LUT manipulation option within your LightSpace version have a play with the Maths tools - they are very, very powerful!)
Steve
alex_t likes this.
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #245 of 263 Unread 11-18-2015, 07:27 AM
Quoted: 580 Post(s)
Liked: 956
LightSpace CMS 7.1.1.2304 (17 November 2015) has just released.
Changes
-- Fixed 'Ftl' Luma graph value display issues introduced in 7.1.0 and first 7.1.1 release.
-- Corrected PDF Report Luma values, also introduced in 7.1.0 and first 7.1.1 release.
-- Added Prepend/Append capability to 'Maths' function.
Download Link
alex_t and W3Rman like this.
post #246 of 263 Unread 11-20-2015, 02:46 AM
Quoted: 580 Post(s)
Liked: 956
LightSpace CMS 7.1.1.2305 (19 November 2015) has just released.
Changes
-- Corrected RGB Bars Widget display
Download Link
alex_t likes this.
post #247 of 263 Unread 11-20-2015, 04:28 AM
Quoted: 140 Post(s)
Liked: 386
Changes
Download Link
I actually think there is still something wrong with the RGB Widget Bars...
We are still looking into it!
Steve
alex_t and ConnecTEDDD like this.
Steve Shaw
LIGHT ILLUSION
post #248 of 263 Unread 11-20-2015, 06:01 PM
Pres2play's Avatar
Quoted: 402 Post(s)
Liked: 242
I changed the file name from Test.data to ct2_d65.raw (for preset 2) and then pasted in ee, and it works. Thanks!
W3Rman likes this.
Pres2play is offline
post #249 of 263 Unread 11-22-2015, 04:52 AM
Quoted: 580 Post(s)
Liked: 956
LightSpace CMS 7.1.1.2307 (19 November 2015) has just released.
Changes
-- Fixed RGB Bars Widget display
Download Link
Pres2play likes this.
post #250 of 263 Unread 11-23-2015, 02:28 AM
Pres2play's Avatar
Quoted: 402 Post(s)
Liked: 242
Originally Posted by Pres2play View Post
Oops! Had the wrong resolution on the Samsung HDTV in Extended mode. Instead of 1920 x 1080 it was the same rez as the laptop, 1366 x 768. Fixed it and now the color box is the correct size for the display and smaller than before.
Also just discovered the TV was in 16x9 mode instead of Screen Fit after popping in Ted's disc. Overscan enlarges the patch size as well.
post #251 of 263 Unread 01-09-2016, 10:49 AM
Quoted: 580 Post(s)
Liked: 956
Light Illussion has released a Closed Alpha Version of LightSpace CMS that supports ST2084 HDR and BBC HLG (Peak & Surround for BBC HLG etc.)
If there are users working with HDR/HLG want to test the Alpha version, I can provide them a download link via a simple PM.
LightSpace CMS - 7.1.2 Changes:
-- Added BBC HLG Gamma profiles for Rec709, Rec2020, and P3
-- Added graphing for ST2084 and BBC HLG standards
-- Apply Probe Offset data when setting display Min/Max Y in Options
-- Corrected Manual Measure values when using BT1886 as Target colour space
-- Added new LUT formats
-- PR-680 added to Discoverable Probes
-- Corrected measured Luma values with Ftl set
-- Added image extension to ‘Save As’ from LUT preview function
-- Further correction ACES Gamut plot triangle
-- Corrected occasional RGB Bars graph error
alex_t likes this.
post #252 of 263 Unread 01-10-2016, 12:39 AM
Pres2play's Avatar
Quoted: 402 Post(s)
Liked: 242
^^^ the occasional RGB Bars graph error? Is this the same as the RGB Bars Widget display error that was supposedly fixed?
post #253 of 263 Unread 01-10-2016, 04:31 AM
Quoted: 140 Post(s)
Liked: 386
No, there can be occasions when the RGB bars extend beyond the 'Widget Box'.
It is this that has been fixed.
The previous fix is different, and is valid, not supposed.
However, we are looking at changing the bars operation for compound colours, as some users don't understand the present operation... we're still thinking about that.
Steve
Steve Shaw
LIGHT ILLUSION
post #254 of 263 Unread 01-10-2016, 05:06 AM
alex_t's Avatar
Liked: 40
Steve
Steve,
Current RGB bars widget is very accurate and helpful.
alex_t is offline
post #255 of 263 Unread 01-11-2016, 01:10 AM
Pres2play's Avatar
Quoted: 402 Post(s)
Liked: 242
Oh, man, David Bowie just passed away. Very sad.
post #256 of 263 Unread 01-11-2016, 01:33 AM
Pres2play's Avatar
Quoted: 402 Post(s)
Liked: 242
Steve
Thank you Steve. I agree with Alex and find it helpful also.
post #257 of 263 Unread 01-11-2016, 01:52 AM
erkq's Avatar
Quoted: 183 Post(s)
Liked: 191
Yep... a shock. Didn't even know he was battling cancer.
erkq is offline
post #258 of 263 Unread 01-11-2016, 04:24 AM
Quoted: 140 Post(s)
Liked: 386
I know this is way off topic, but I have always seen Bowie as something of a hero - I grew-up with his career progression, and found each and every change of direction he made awesome!
The world is a little poorer today.
Steve
Steve Shaw
LIGHT ILLUSION
post #259 of 263 Unread 01-11-2016, 04:00 PM
Pres2play's Avatar
Quoted: 402 Post(s)
Liked: 242
Just last month I picked up a Denon turntable for my daughter and PinUp was one of the albums we both picked out and listened to that day. Those songs brought back some memories, and listening to it on vinyl was fun. I will miss him.
post #260 of 263 Unread 01-14-2016, 04:57 PM
Quoted: 580 Post(s)
Liked: 956
LightSpace CMS 7.1.2.2341 (14 January 2016) has just released.
Changes
-- Corrected various FtL value display errors
-- Added image extension to 'Save As' from LUT preview function
-- Increased Cube Size for ACES CTL export
Download Link
post #261 of 263 Unread 01-21-2016, 06:09 PM
sillysally's Avatar
Quoted: 668 Post(s)
Liked: 696
Ran a 14x3 profile for my Lumagen 2041 9x3, used the Lumagen to output 4:4:4 triplets.
Used a Black background, K10-A (off-screen), 6% window using Lightspaces anti ASBL for the LG OLED 65EF9500.
Made 2.2, 2.36 and BT1886 3DLUTs from the profile changing the active CMS memory in the Lumagen.
Also just to test out Lightspace's anti ASBL I used the low light delay for my meter.
Results are very good, there seemed to be NP with ASBL.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #262 of 263 Unread 01-28-2016, 08:32 AM
Surfdrifter's Avatar
Quoted: 58 Post(s)
Liked: 27
I have the HTL version of the program and I'd like to ask a few things. I'm using a Lumagen 2143 and i have i1 Pro and I1 Display 3
1) I have read that when going for a large LUT, that I should check 3D Lut only, and if I go for a small LUT like a 5x5x5, I should choose 1D+3D lut.
Can you explain me why isn't a 1D+3D Lut better than a 3DLUT. I'm talking about a 17x17x17 Lut
2) I understand that regardless of how many points I measure, the 3D lut uploaded to the Radiance will always be 17x17x17 and I cannot choose the cube size to upload. This means that if i take 125 points, Lightspace will use algorithms to create a 17^3 cube. What happens when I measure exactly 4913 points? Also, would it be beneficial to measure 21^3 points, even though the cube would be in the end a 17^3 one?
3) This is more generic question, not related directly with Lightspace. If I use the same projector and the same screen, do I need to profile my Id3 everytime I calibrate, or I can use the saved profiles from a previous session?
Surfdrifter is offline
post #263 of 263 Unread 01-28-2016, 02:09 PM
Quoted: 140 Post(s)
Liked: 386
Remember that when profiling you are not using a LUT, you are using a set of patches.
The inbuilt patch sequences within LightSpace are based on a cube configuration, to offer the best colour coverage (the best granularity).
With a small cube based set of patches the 'Hybrid 1D+3D Cube' option adds more patches into the grey scale, to help with grey scale balance calibration.
So you can use a 17^3 cube based profile, with the Hybrid mode.
There are also different patch sets that can be downloaded here: http://www.lightillusion.com/downloads.html
Select the 'Optimised Patch Sequences'.
Regardless of the number of patches you actually use for any profile, including the Quick Profile options (excluding Sat Sweeps and Mem Colours, which LUTs cannot be generated from) LightSpace always generates the calibration LUT in a much higher resolution (higher that 17^3, or 21^3...). From this very large LUT size the 'uploaded' or exported LUT is generated at the required size and format.
And yes, using a cube size for profiling that is larger than the final LUT will always be of some benefit - the larger number of measurements allows LightSpace CMS to calculate the needed corrections more accurately.
With a projector I would suggest profiling the i1D3 to a spectro every time.
Projectors do tend to alter their output a fair bit...
Steve
Surfdrifter likes this.
Steve Shaw
LIGHT ILLUSION
Reply Display Calibration
