Ted's LightSpace CMS Calibration Disk - Page 18 - AVS | Home Theater Discussions And Reviews
post #511 of 526 Old 10-29-2014, 03:01 PM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 193 Post(s)
Liked: 578
CalMAN Color Comparator Comparisons 1.0.1 Workflow for Ted's Lightspace CMS Calibration Disk Users had been released.
I have just send to all Ted's LightSpace CMS Calibration Disk users a new version of CalMAN 5 Color Comparator Comparisons Workflow.
Changes
Fixed a scaling problem of Pre-Calibration Comparator dE numbers datagrid of Grayscale & ColorChecker SG Skintones Comparator Comparisons layout pages where the dE numbers where not displayed correctly only in case where the display performance has dE numbers above 9.99dE.
The contrast ratio data field is now wider to be able to display without problems large contrast ratio numbers.
Notes
The Color Comparator Comparisons Workflow has created to be used mainly for field calibrators/DIYer's to showcase their pre/post calibration results to customers/people with limited calibration experience.
Pre/Post-Calibration dE numbers & CIE Charts are not 'customer friendly' and it's difficult from them to to understand what is really happening by looking at them.
Color Comparator Pre-Post Calibration Comparisons color screens it's a great tool for easier visual notice of the differences using the 8-bit RGB Triplet color differences.
Example of Use
Bellow you can find some pre-post calibration screenshots by using Color Comparator Workflow in action.
The display used for that example was a Samsung 60H7000 using the available internal display controls.
All the required patterns for pre-calibration - post evaluation and measurements came from Ted's LightSpace CMS Calibration Disk.
All the measurement patterns were generated from the disk, using CalMAN's Automated Measurement Utility 1.3. which automatically displays (per 2 seconds) and measures each color patch without user prompt. I used a Klein K-10A profiled from JETI 1211.
I used 75% Saturation with 100% Stimulus patterns for CMS calibration.
Pre-Calibration Reports shows performance of Samsung 60H7000 @ Natural mode, since it has the only mode that was used from the user of this display since now.
Post-Calibration report shows the performance of ISF-Night calibrated memory.
11-Point GrayScale (Pre-Calibration)
11-Point GrayScale (Post-Calibration)
4-Step Saturation (Pre-Calibration)
4-Step Saturation (Post-Calibration)
ColorChecker Classic (Pre-Calibration)
ColorChecker Classic (Post-Calibration)
ColorChecker SG Fleshtones (Pre-Calibration)
ColorChecker SG Fleshtones (Post-Calibration)
...and now the Color Comparator Comparisons Screens ...how dE patch color differences are visible or not using CalMAN's Comparator feature:
11-Point Grayscale Color Comparator Comparison of Pre/Post Calibration
4-Step Saturation Color Comparator Comparison of Pre/Post Calibration
ColorChecker Classic Color Comparator Comparison of Pre/Post Calibration
ColorChecker SG Fleshtones Color Comparator Comparison of Pre/Post Calibration
prsut likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS + CalMAN ColorChecker
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, CalPC, ControlCAL
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #512 of 526 Old 10-31-2014, 09:16 AM
PlasmaPZ80U's Avatar
Quoted: 255 Post(s)
Liked: 234
Originally Posted by ConnecTEDDD View Post
Hi, with the current version of Batch Files, no, it's not compatible with this Color Comparator Comparisons Workflow.
There is a new version of Batch Files (v1.3) that adds support for this workflow measurements.
Here is a screenshot:
The new version of Batch Files v1.3, It will be emailed to all disk users at the end of this week.
Basically the Color Comparator workflow works with custom color sets that I created based to exact RGB Triplets of my disk for Saturation and Luminance, so I'm not using the Saturation or Luminance Sliders of CalMAN.
This means that every selection you may change to CalMAN settings, it will not interact to these pages because they are ColorChecker Custom Sets.
That Color Comparator Workflow has been configured to work without any required user change of any CalMAN setting.
For Saturation Runs or 4/5-Step (75%/100% Stimulus Level), there is no Black measurement to these workflow pages, so by using the Automated CalMAN Measuring Procedure (for more instructions look the Measurement Solutions webpage for picture examples) you will have to skip the Black measurement and start from 100% White.
There instructions when you will run the Batch file, here is an example for 4-Step Saturation by using Color Comparator Comparisons Workflow:
Batch Files Version 1.3 for CalMAN 5 Automated Measurements has been released today.
Version 1.3 adds support for the required measurements using the CalMAN 5 Color Comparator Comparisons Workflow for Ted's LightSpace CMS Calibration for Disk Users.
These are the new Automated Measurement options:
4-Point Saturation (for Color Comparator Comparisons Workflow)
5-Point Saturation (for Color Comparator Comparisons Workflow)
4-Point Luminance (for Color Comparator Comparisons Workflow)
5-Point Luminance (for Color Comparator Comparisons Workflow)
For ColorChecker Classic / SG / SG Fleshtones measurements, you can use the 13,14,15 selections for Color Comparator Comparisons or Verify Calibration Tools Workflow also.
Ted's LightSpace CMS Calibration Disk users have automatically received the email with download link and instructions before some minutes.
was the early link you gave me to v1.3 the same as the latter release?
UN46EH6030 Calibration/Settings
Display: Samsung UN46EH6030 LED-LCD TV; Sound: Yamaha HTR-3066 AVR/AMP, Sony Core Bookshelves (Sony SS-CS5) and Center (Sony SS-CS8) as fronts, Yamaha NS-AP2600S Satellites as surrounds, Dayton Audio SUB-1200 as subwoofer; Sources: PS4 (doubles as primary BD player), Xbox One, PS3, Xbox 360, Motorola RNG150N (Cable Box)
PlasmaPZ80U is offline
post #513 of 526 Old 10-31-2014, 09:20 AM - Thread Starter
Quoted: 193 Post(s)
Liked: 578
Yes, it was the same version.
post #514 of 526 Old 11-03-2014, 03:40 PM
MCaugusto's Avatar
Quoted: 73 Post(s)
Liked: 53
ConnecTEDDD >>> I just ordered a X-Rite i1 Display Pro which i want to use to calibrate my Runco LED front projector and i wonder how your blu-ray disc would work paired with the i1 Display Pro.
I am a novice and want to start slowly on how to use a colorimeter for calibration and although i have a pretty good idea of what CMS, gray-scale tracking and gamma curves are i don't want to get any video testing equipment/procedure that would be too time consuming and difficult to interpret.
If i get the disk and play it on my Oppo 103 blu-ray player to show test pattern onscreen while the i1 Display Pro is connected to my desktop via USB cable, how do i proceed from there ? Play around with the adjustment controls for CMS, gray-scale and gamma on my projector while checking the results on my computer's screen opened to the i1 Display Pro program ? If i go over or under any optimum parameter with the adjustment controls of my projector would the mistake be pointed out onscreen by the program, at which point i would then re-adjust the appropriate control until the mistake is corrected ?
You mentioned several times the importance of doing calibration based on source input; However, to calibrate any source with the blu-ray disk obviously you need it to have a blu-ray player and so if my computer does not have one the disk would be of no use in such circumstance; I imagine that in such case the user would have to pay another charge to download the same software, so why not offer both for a discount ?
Thanks >>> Marcos
MCaugusto is offline
post #515 of 526 Old 11-04-2014, 02:56 AM - Thread Starter
Quoted: 193 Post(s)
Liked: 578
Hi Marcos, very good choice for a colorimeter.
You will need to spend some hours initially to find out how things work.
If i get the disk and play it on my Oppo 103 blu-ray player to show test pattern onscreen while the i1 Display Pro is connected to my desktop via USB cable, how do i proceed from there?
You will need a calibration software other from that is coming with your i1display pro meter (i1profiler).
There 3 software solutions to use for calibration by using the available internal contols of a display. HCFR (Open Source), CalMAN, ChromaPure.
Ted's LightSpace CMS Calibration Disk supports all the above software solutions and features the required chapters to be able to run any supported measurement type.
There Manual, Semi-Manual or Automated (for CalMAN only) measurement ways, these measurement solution are described here.
You can download the free (open source) HCFR software and start learning how it works as a first step.
Play around with the adjustment controls for CMS, gray-scale and gamma on my projector while checking the results on my computer's screen opened to the i1 Display Pro program ? If i go over or under any optimum parameter with the adjustment controls of my projector would the mistake be pointed out onscreen by the program, at which point i would then re-adjust the appropriate control until the mistake is corrected?
HCFR will populate the Grayscale/Gamma/Gamut Charts, dE reports for your measurements; to be able to do the required changes to your projector calibration controls to fix the inaccuracies.
You mentioned several times the importance of doing calibration based on source input; However, to calibrate any source with the blu-ray disk obviously you need it to have a blu-ray player and so if my computer does not have one the disk would be of no use in such circumstance; I imagine that in such case the user would have to pay another charge to download the same software, so why not offer both for a discount?
There currently 3 available version formats of Ted's LightSpace CMS Calibration Disk:
Blu-Ray Disk Copy: Worldwide delivery of a Blu-Ray Disk Copy (BD-25GB Single Layer Disk) using First Class Priority International Mail to any destination.
Blu-Ray ISO Digital Download Link: Personal Download Link for the Blu-Ray ISO File via e-mail. The user can burn the ISO File with a PC Blu-Ray Recorder using a Blank BD-25GB Single Layer Disk or playback the ISO File from a Stand-Alone Media Player / PC Software Player that supports Full Blu-Ray Menu.
Media Files Digital Download Link: Personal Download Link for the Media Files via e-mail. All chapters of the Blu-Ray Release are included in MP4+MKV files for a wide device playback support from Stand-Alone Media Players, PC/MAC Software Players, Satellite Tuners, Digital TV Receivers, Video Game Consoles (for movie playback from USB), Tablets/SmartPhones, TV's USB Movie Mode or Stand-Alone Media Players / PC Software Players that don't support playback of Blu-Ray ISO Files with Full-Menus.
You can use the Blu-Ray Copy for your OPPO and the Media Files or Blu-Ray ISO (in case that you will use a software player that support Full Blu-Ray Menus).
There discount anytime you want to move from one version to another, these upgrade options can be found to the Ted's LightSpace CMS Calibration Disk Upgrade Order For Disk Owners Only webpage.
For example if someone has the Blu-Ray Copy and want to move to Media Files, from the drop down menu "Please select the disk version upgrade you want to purchase and select which disk version you own:" you have to select ''Upgrade to Media Files Digital Download Link 1.1 (I own Blu-Ray Disk Copy 1.x)''.
post #516 of 526 Old 11-04-2014, 11:40 AM
MCaugusto's Avatar
Quoted: 73 Post(s)
Liked: 53
Thanks ConecTEDDD for your help answering all my queries.
I will be ordering the blu-ray calibration disc very soon.
post #517 of 526 Old 11-24-2014, 02:16 PM
-Hitman-'s Avatar
Quoted: 48 Post(s)
Liked: 67
Ted, thanks for the useful color comparator workflow, came in very handy after getting a new i1pro2.
"Thumbs up"
ConnecTEDDD likes this.
-Hitman- is offline
post #518 of 526 Old 11-26-2014, 12:34 PM - Thread Starter
Quoted: 193 Post(s)
Liked: 578
"Thumbs up"
Thanks. I will update the other 2 workflows (Pre-Calibration Tools / Verify Calibration Tools) probably next week.
post #519 of 526 Old 12-27-2014, 02:13 PM - Thread Starter
Quoted: 193 Post(s)
Liked: 578
CalMAN 5 Pre-Calibration Tools 1.1.2 Workflow for Ted's Lightspace CMS Calibration Disk Users has just released.
I have just send to all Ted's LightSpace CMS Calibration Disk users a new version of CalMAN 5 Pre-Calibration Tools 1.1.2 Workflow.
This is a free workflow update for Blu-Ray Disk Copy, Blu-Ray ISO Digital Download or Media Files Digital Download users.
Notes
This version adds some info's to layout pages for better display overview for more simple to use calibration time.
Added separate layout pages for Color Gamut Calibration 100% SAT / 100% STIM, 100% SAT / 75% STIM, 75% SAT / 75% STIM, so now it's quick to change and overview the differences very fast by calibrating different Saturation/Stimulus Levels. It doesn't require any change of CalMAN Settings anymore.
As you know, when you want to perform Color Gamut Calibration with 75% Saturation, you have to change the Slider manually to see each color, there 7 selectable sliders for this. I have added all Saturation Colors in one Slider and you can now select any color of interest very quick. This saves some time.
Added Color Checker Classic Layout page, that is helpful to find and select the most accurate initial display mode to start with. Here you can change that Layout Page to ColorCheck SkinTones via CalMAN's Settings for tweaking the Samsung's Skin Tone Setting.
Changes
Meter Profiling Check Layout Page: Added a datatable with xyY values for WRGB for the Reference / Profiled meter in case that the user want to copy the values and used them to 3rd party software solutions, like ChromaPure, LightSpace, Klein ChromaSurf; to measure with CalMAN and later create a meter correction table with these values using other software; to use the same table everywhere. It's helpful for those who want to create meter correction table for Klein, to quick copy-paste the values of the Reference Meter and paste them to Klein's ChromaSurf. You can copy any x,y,Y number using right mouse click & copy.
x-Point Grayscale + Gamut Layout Page: Added info for Black Level Luminance, added Grayscale's Red/Green/Blue Color Channel Balance (Average) info, added selector for quick change of Grayscale Points that the user want to measure; to quick change from 11 to 21 Point Grayscale very quick without touching the CalMAN's Settings.
x-Point Saturation Layout Page: Added selector for quick change of Saturation Points that the user want to measure; to quick change from 4 to 5 or 10 Point Saturation very quick without touching the CalMAN's Settings.
x-Point RGB Balance Layout Pages: Added button for Read Continuous and Meter Stop, for users that want to perform quick/continuous 2/3/4-Point RGB Balance for displays with DDC or while they are changing values from the OSD menu, for displays where the OSD menu appearance is not affecting calibration measurements.
11/21-Point Grayscale Layout Page: Added info for Black Level Luminance, added Grayscale's Red/Green/Blue Color Channel Balance (Average) info, added selector for quick change of Grayscale Points that the user want to measure; to quick change from 11 to 21 Point Grayscale very quick without touching the CalMAN's Settings.
post #520 of 526 Old 01-08-2015, 05:29 AM - Thread Starter
Quoted: 193 Post(s)
Liked: 578
Tip For CalMAN 5 Users
For the users that are using the Ted's CalMAN 5 Workflows, as you probably have seen, there is not available at any layout page the ReadAll button, since all workflow have been configured to work with Singe Read with AutoAdvance.
For the users that can use the CalMAN Workflow Design feature, there is no need to enter to design mode to add manually a ReadAll button, they can use the CalMAN's Keyboard Shortcut for that.
Before that, the users have to enable the Keyboard Shortcuts feature from CalMAN's Application Preferences and after than they can simply press F10 key which is the keyboard shortcut key for ReadAll at any CalMAN layout page.
This is helpful for users that are using Ted's CalMAN Workflows with External Hardware Pattern Generators or with CalMAN's Internal Pattern Generator.
Manni01 likes this.
post #521 of 526 Old 01-08-2015, 05:38 AM
Manni01's Avatar
Quoted: 489 Post(s)
Liked: 244
Great tip Ted, I was wondering about that. Thanks!
Manni01 is online now
post #522 of 526 Old 01-29-2015, 11:00 AM - Thread Starter
Quoted: 193 Post(s)
Liked: 578
CalMAN's Grayscale vs. ColorCheckerClassic/SG Measuring Tip
I have been questioned by disk users that have calibrated their displays using 11/21-Point Grayscale Chapters of the disk why later during their verification measurement run using ColorCheckerClassic/SG chapters, they see larger dE errors at Gray measurements of ColorChecker Classic/SG while by measuring the same named patches using the x-Point Grayscale Chapter they see lower dE numbers there.
This is not a disk encoding problem, it's happening because the Gray Levels of ColorChecher are not matching the levels of Grayscale patches.
There are the exact levels:
Gray 35 of ColorCheckerClassic / SG means 62% Greyscale.
Gray 50 of ColorCheckerClassic / SG means 73% Greyscale.
Gray 65 of ColorCheckerClassic / SG means 82% Greyscale.
Gray 80 of ColorCheckerClassic / SG means 90% Greyscale.
CalMAN's ColorChecker is based to the names & colors of the Macbeth's ColorChecker which was a printed cart with 24 colors that used for years for many different proposes.
Gray/Neutral patches represent the different lighting conditions at Macbeth's ColorChecker.
SpectraCAL's Developer mapped these targets to RGB space and kept the original names except the grey patches which are named as Neutral 3.5, Neutral 5.0, Neutral 6.5, Neutral 8.0 at original ColorChecker....SpectraCAL's Developer renamed these patches are Gray 35, Gray 50 etc.
So there is nothing to worry about disk accuracy.
Manni01 likes this.
post #523 of 526 Old 02-05-2015, 03:17 PM
maximus74's Avatar
Quoted: 69 Post(s)
Liked: 25
Hi,ConnecTEDDD
It is possible to receive your free calibration disk,as i understand being the best tools to evaluate my new JVC X500.
It is available for download? in media files version?
My source is Dune Base 3D media player.
I also have Lumagen Mini 3D with ChromaPure Standard +Auto-Cal.
maximus74 is offline
post #524 of 526 Old 02-05-2015, 03:38 PM - Thread Starter
Quoted: 193 Post(s)
Liked: 578
Originally Posted by maximus74 View Post
Hi,ConnecTEDDD
Hi Maximus,
Thank you for your interest about my calibration disk. The free version contains some basic patterns for pre-calibration setup/verifying the levels, the CalMAN's ColorCheckerClassic Chapter & the
LightSpace Quick Profiling Chapters to check by taking measurements the performance of your projector/display.
For a complete calibration there is the full version where it contains all the features for more advance visually and measuring evaluation of 1D / 3D LUT performance.
Ted's LightSpace CMS Calibration Disk Free Version is a Lite Version of the Full Disk that works with the following public available free calibration software solutions:
Light Illusion's LightSpace DPS & SpectraCAL's CalMAN ColorChecker.
The Free Version Download Link is including both format versions, Blu-Ray ISO and Media Files Version (MP4+MKV); This gives a wide device playback compatibility.
Ted's LightSpace CMS Calibration Disk Free Version Download Instructions:
Request a Free Download Link from here.
post #525 of 526 Old 02-05-2015, 04:02 PM
maximus74's Avatar
Quoted: 69 Post(s)
Liked: 25
Thank You, ConnecTEDDD
post #526 of 526 Old Today, 04:46 AM - Thread Starter
Quoted: 193 Post(s)
Liked: 578
Dear disk users,
There some interesting new measurement options for HCFR users that using Ted’s LightSpace CMS Calibration Disk.
HCFR 3.1.7 (free open source calibration software) has been released and it's adding some extra measurement options for Ted's LightSpace CMS Calibration Disk of Free Version or Full Version users. For full HCFR release notes look here.
Using HCFR 3.1.7 (or later version) with Ted’s LightSpace CMS Calibration Disk Chapters that are available to the CalMAN/ChromaPure sessions of the disk, you can take measurements for the following Color Checker Patterns:
For Ted’s LightSpace CMS Calibration Disk (Free Version) users:
CalMAN’s Color Checker Classic (24 Colors)
For Ted’s LightSpace CMS Calibration Disk (Full Version) users:
CalMAN’s Color Checker SG (96 Colors)
CalMAN’s Color Checker SG Fleshtones (19 Colors)
ChromaPure’s Color Checker (25 Colors)
ChromaPure’s Color Checker Skin Tones (19 Colors)
HCFR 3.1.7 follows the same pattern order with Ted’s LightSpace CMS Calibration Disk Chapters for any of the above measurement options and the HCFR’s 8-bit RGB Triplets for each pattern are matching exactly the RGB Triplets that the Ted’s LightSpace CMS Calibration disk has been encoded.
Below you can find the updated list of the total CalMAN and ChromaPure Chapters that any HCFR user can use to take measurements. These Disk Chapters are accurate and match the HCFR's Color Engine Calculations.
Instructions for x-Point Grayscale Chapters Measurements
Uncheck ''use round down levels" that is located to HCFR ‘’Preferences’’ -> ‘’General’’ Tab. This is affecting only Grayscale measurements.
Instructions for Color Checker Chapters Measurements
Before starting the measurements you have to select from HCFR's Preferences -> ''General'' Tab -> ''Color Checker Patterns'' drop down menu list the selection of the measurement run you want to perform.
Select ‘’GCD’’ if you want to measure using ChromaPure’s Color Checker Chapter.
Select ‘’ChromaPure skin tones’’ if you want to measure using ChromaPure’s Color Checker Skin Tones Chapter.
Select ‘’CalMAN Classic’’ if you want to measure using CalMAN’s Color Checker Classic Chapter.
Select ‘’CalMAN SG’’ if you want to measure using CalMAN’s Color Checker SG Chapter.
Select ‘’CalMAN SG skin tones’’ if you want to measure using CalMAN’s Color Checker SG Flesh Tones Chapter.
Note that there differences between the RGB Targets of CalMAN vs. ChromaPure ColorChecker & Skintones patterns.
Thanks Zoyd (current developer of HCFR) for adding these new features.
Reply Display Calibration
Pioneer Elite Kuro Pro 1150hd 50 Inch Plasma Hdtv
Gear in this thread - 1150hd by PriceGrabber.com
