Ted's LightSpace CMS Calibration Disk - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 165Likes
post #541 of 682 Old 04-01-2015, 02:01 PM
PlasmaPZ80U's Avatar
Quoted: 1994 Post(s)
Liked: 568
Why would clipping well past digital 235 affect profiling at 100% stim? Those patterns go well past 235 but clipping above 235 should not affect 100% patches.
PlasmaPZ80U is online now
post #542 of 682 Old 04-01-2015, 03:33 PM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1220 Post(s)
Liked: 1724
Hi, It has to check for clipping @ 235 and to steps before 235 level, but up to 237 will be safer.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #543 of 682 Old 04-01-2015, 07:42 PM
Pres2play's Avatar
Quoted: 478 Post(s)
Liked: 264
Originally Posted by ConnecTEDDD View Post
From my testing with JETI/i1PRO/i1PRO2, this time is enough, but when the time is not enough, you can count 9 sec. when you see each patch and press pause....and un-pause when you got the reading.
Also you can pause when you see each patch, un-pause when it's measured and use 'next chapter button' of your player to display you the next patch.
For example with JETI 1211 using it from JETI's LiVal softwre, once I have scanned for panel's refreshing rate using a White patch, I can take about 10 readings for each color in 10 seconds time, and LiVal will display the average. (with 100% Amplitude Patterns)
Thanks for explaining, Ted. I'll check those clipping patterns before profiling at 100% Amp next time. Good to know I can pause playback without harming the reading.
Is scanning for the panel's refreshing rate the same thing as sync detection which is also done with a white patch?
Pres2play is offline
post #544 of 682 Old 04-01-2015, 10:48 PM - Thread Starter
Liked: 1724
Hi, Yes, It's the same thing.
transendance likes this.
post #545 of 682 Old 04-02-2015, 12:44 AM
Pres2play's Avatar
Quoted: 478 Post(s)
Liked: 264
Can the sync rate affect the reading speed of the meter? Sounds like the sync rate must match the display precisely.
Edit: just opened the Colorimeter Utility application and found the CR250 has a Slow, Normal, Fast and Two Times Faster mode.
Name:	CR250 sync features.PNG
post #546 of 682 Old 04-02-2015, 12:54 AM - Thread Starter
Liked: 1724
I don't know about your CR-250, but if it's syncing every time before meter read, it will need more time to measure. If it has initial syncing and later it's only measuring it will have less time.
Without sync probably it will take more time to read without so good repeatability.
post #547 of 682 Old 04-02-2015, 01:08 AM
Pres2play's Avatar
Quoted: 478 Post(s)
Liked: 264
Thanks, Ted. I'll give the 2x faster mode a try this weekend.
Name:	2X faster.PNG
post #548 of 682 Old 04-02-2015, 03:18 AM - Thread Starter
Liked: 1724
DVDO's AVLab TPG 4K Reference Pattern Generator with firmware 01.03.769 has added a very useful feature that is called 'Color Checker'. Using that feature it can provide real-time analysis of digital value for selected pixel from it's HDMI Input.
Here is an example, the 8dr means "8 bit, decimal, RGB" then the values are the RGB values of the pixel that the cursor is pointing to.
Professional & Enthusiast calibrators has find this feature very valuable, to check the accuracy of any player output, testing various colorspace output options etc. using Ted's LightSpace CMS Calibration Disk as a reference to detect digital errors that wrong player settings can introduce.
To help them out checking some patterns of my calibration disk, I will start by giving out the 8bit RGB Triplets of some Color Reproductions Patterns to help them reduce the time it will be required for this test.
I will start with the RGB Triplets of the Advanced Black & White Flashing Bars Pattern, others will follow soon.
Here is a small preview of the Advanced Black & White Flashing Bars Pattern with RGB Triplets per color:
Here is a zoomed version:
Because the RGB Triplets are looking very small in a 1920x1080 picture, I have re-designed it at 3840x2160 resolution, you can download it from here: Advanced Black & White Flashing Bars Pattern (2160p)
The issue I has thinking about was how to accurately calculate the dE between two RGB Triplet values, to evaluate any digital error.
I asked from Tom Huffman to help me about this (the creator of ChromaPure Calibration Software) and Tom some hours later came with a Tool that you can download it for free, for dE Analysis.
It's the ''Combination Color Format Converter and ΔE Analysis'' Excel Spreadsheet and you can download it from here.
Thanks Tom for your time providing this free tool so quickly after my request for help, while I know that you are so busy to finish ChromaPure 3.0. Thanks.
post #549 of 682 Old 04-12-2015, 12:57 PM - Thread Starter
Liked: 1724
Dear disk users,
HCFR 3.2.0 (free open source calibration software) has been released and it's adding a lot of extra measurement options for Ted's LightSpace CMS Calibration Disk users. For full HCFR release notes look here.
Using HCFR 3.2.0 with Ted’s LightSpace CMS Calibration Disk you will be able to measure now all the CalMAN Session of the disk Chapters, here is the complete list of the supported chapters:
For Ted’s LightSpace CMS Calibration Disk (Free Version) users:
CalMAN’s Color Checker Classic (24 Colors)
For Ted’s LightSpace CMS Calibration Disk (Full Version) users:
ChromaPure's 2/3-Point Grayscale
ChromaPure's 11/21-Point Grayscale
ChromaPure's Color Gamut (100% Saturation w/ 100% or 75% Intensity, 75% Saturation w/ 100% or 75% Intensity)
ChromaPure's 4-Point Saturation with 100% or 75% Intensity (25 Colors)
CalMAN's 4-Point Saturation with 100% or 75% Stimulus Level (25 Colors)
CalMAN's 5-Point Saturation with 100% or 75% Stimulus Level (31 Colors)
CalMAN's 10-Point Saturation with 100% or 75% Stimulus Level (61 Colors)
CalMAN's 4-Point Luminance (28 Colors)
CalMAN's 5-Point Luminance (35 Colors)
CalMAN's 10-Point Luminance (70 Colors)
6-Point Near Black (added support for 0.5% Gray patch measurement)
Dynamic Range Clipping (90/95/98/99%/100%)
CalMAN’s Color Checker SG (96 Colors)
CalMAN’s Color Checker SG Fleshtones (19 Colors)
ChromaPure’s Color Checker (25 Colors)
ChromaPure’s Color Checker Skin Tones (19 Colors)
HCFR 3.2.0 follows the same pattern order with Ted’s LightSpace CMS Calibration Disk Chapters for any of the above measurement options and the HCFR’s 8-bit RGB Triplets for each pattern are matching exactly the RGB Triplets that the Ted’s LightSpace CMS Calibration disk has been encoded.
Below you can find the updated list of the total CalMAN and ChromaPure Chapters that any HCFR user can use to take measurements. These Disk Chapters are accurate and match the HCFR's Color Engine Calculations:
Instructions for x-Point Grayscale ChromaPure's Chapters Measurements
Uncheck ''use round down levels" that is located to HCFR ''Preferences'' -> ''General'' Tab. This is affecting only Grayscale measurements.
Instructions for Color Checker Chapters Measurements
Before starting the measurements you have to select from HCFR's Preferences -> ''References'' Tab -> ''Color Checker Patterns'' drop down menu list the selection of the measurement run you want to perform.
Select ''GCD'' if you want to measure using ChromaPure’s Color Checker Chapter.
Select ''ChromaPure skin tones'' if you want to measure using ChromaPure’s Color Checker Skin Tones Chapter.
Select ''CalMAN Classic'' if you want to measure using CalMAN’s Color Checker Classic Chapter.
Select ''CalMAN SG'' if you want to measure using CalMAN’s Color Checker SG Chapter.
Select ''CalMAN SG skin tones'' if you want to measure using CalMAN’s Color Checker SG Flesh Tones Chapter.
Instructions for CalMAN's x-Point Saturation/Luminance Chapters Measurements
To enable these measurements the users have to download the usercolors_pak.zip of HCFR.
By extracting the files of the HCFR's usercolor_pak, below are the Ted's LightSpace CMS Calibration Disk Pattern Sequences of the CalMAN's Session you can use with HCFR 3.2.0:
CM 4-Point Saturation (100AMP).cvs file for CalMAN's 4-Point Saturation (100% Stimulus Level) Chapter.
CM 4-Point Saturation (75AMP).cvs file for CalMAN's 4-Point Saturation (75% Stimulus Level) Chapter.
CM 5-Point Saturation (100AMP).cvs file for CalMAN's 5-Point Saturation (100% Stimulus Level) Chapter.
CM 5-Point Saturation (75AMP).cvs file for CalMAN's 5-Point Saturation (75% Stimulus Level) Chapter.
CM 10-Point Saturation (100AMP).cvs file for CalMAN's 10-Point Saturation (100% Stimulus Level) Chapter.
CM 10-Point Saturation (75AMP).cvs file for CalMAN's 10-Point Saturation (75% Stimulus Level) Chapter.
CM 6-Point Near Black.cvs file for CalMAN's 6-Point Near Black Chapter.
CM Dynamic Range (Clipping).cvs file for CalMAN's Dynamic Range (Clipping) Chapter.
CM 4-Point Luminance.cvs file for CalMAN's 4-Point Luminance Chapter.
CM 5-Point Luminance.cvs file for CalMAN's 5-Point Luminance Chapter.
CM 10-Point Luminance.cvs file for CalMAN's 10-Point Luminance Chapter.
Note: The pattern sequence of CalMAN's 10-Point Luminance is identical to the Color Checker Selection ''RGB Luminance Axis'', so it can be selected from the drop-down menu available @ HCFR's Preferences -> ''References'' Tab.
These new measurement selections currently are now available to the HCFR's Color Checker Pattern drop down menu. To enable any of the measurement option the user has to rename the CMxxxxxxx.cvs measurement file want to perform to usercolors.csv and place it to the same folder where the HCFR has installed (where the HCFR's executable is located), and select from the HCFR's Color Checker Pattern list the ''User defined'' option.
This can be performed while the HCFR is running, for example to do one measurement run; and then replace the CVS file to load the new colors set... and hit the delete icon next to the grid.
For being more user friendly, If there much interest from the HCFR users that using Ted's LightSpace CMS Calibration disk; then these measurement options will be probably selectable from the Color Checker's drop down list in a future release of HCFR. You can request this from Zoyd, the current developer of HCFR to this thread.
Note that there differences between the RGB Targets of CalMAN vs. ChromaPure ColorChecker & Skintones or Saturation patterns.
Thanks Zoyd (current developer of HCFR) for adding these new measurement options for Ted's LightSpace CMS users of HCFR.
xvfx and W3Rman like this.
post #550 of 682 Old 04-13-2015, 11:11 AM
Myron_H's Avatar
Quoted: 33 Post(s)
I cant seem to get my Sony BDP-6200 to read the Ted's Lightspace calibration disc. My player reads the AVS disc fine, but not Ted's.
Myron_H is offline
post #551 of 682 Old 04-14-2015, 12:11 PM
Myron_H's Avatar
Quoted: 33 Post(s)
Hi. Update on my problem. It was my fault. I burned to DVD disc instead of Blu-ray disc. It is now working for me.
Can anyone point me to a basic guide to use the disc, with free version of Lightspace and HCFR?
Myron_H is offline
post #552 of 682 Old 04-14-2015, 12:28 PM - Thread Starter
Liked: 1724
Hi, I'm glad that we solved your playback issue. (via email support)
The Free Version of the disk can be used by LightSpace DPS / CalMAN ColorChecker / HCFR to check the display performance by taking measurements. By taking these measurements you quickly check if your display need to be calibrated or if it has drifted from your last calibration you have performed. It can't be used to fully calibrate the display.
To find out how the Disk Sync's with LightSpace, I have posted instructions here.
About measuring the CalMAN’s Color Checker Classic Chapter from HCFR, before starting the measurements you have to select from HCFR's Preferences -> ''References'' Tab -> from the ''Color Checker Patterns'' drop down menu list to select ‘’CalMAN Classic’’ if you want to measure using CalMAN’s Color Checker Classic Chapter.
post #553 of 682 Old 04-24-2015, 10:56 AM - Thread Starter
Liked: 1724
HDTVtest.co.uk UK's leading HDTV news & review website has start using Ted's LightSpace CMS Calibration Disk as a reference to analyze any Blu-Ray HDMI Output signal for digital errors @ bit level using DVDO’s AVLab TPG Signal Generator.
Tom Huffman (the creator of ChromaPure Calibration Software) has updated his Free dE Analysis Tool and can now calculate dE differences between 2 YCbCr values. This is very useful for DVDO’s AVLab TPG Signal Generator that are using the ColorChecker Function.
You can download the Free ''Combination Color Format Converter and ΔE Analysis'' Excel Spreadsheet from here.
Thanks Tom for that update.
post #554 of 682 Old 04-24-2015, 11:02 AM
W3Rman's Avatar
Quoted: 158 Post(s)
Liked: 131
[IMG]
Done...., thanks Tom for the conversion tool and thanks Ted for the heads up!
Oh, and DVDO is sending me a new Remote TeDDD
ConnecTEDDD likes this.
#1 Calibration Disk / Best Support: Ted's LightSpace CMS Calibration Disk
#1 Calibration Software / Best Support: LightSpace CMS - Calibration Comparison
W3Rman is offline
post #555 of 682 Old 04-27-2015, 02:00 PM
starbuck69's Avatar
Liked: 29
Hi !
I just performed my first calibration with an eeColor Box using both LightSpace and Ted's Disk... WOW it's really COOOOOL !!!
I couldn’t expect this result !!
So easy and so fast : 1H and half for a 10-Point Cube (1.000 color patches!).
I’m very impressed by how Ted’s Disk syncs with LightSpace : so Powerful !!!
I really love that way to go straight to the essential and calibrating the whole video chain becomes so obvious !
Well, now, i want more : thinking of performing a 17-Point Cube : 4.913 patches of color !!!!!!!
Thanks Ted for the FUN )))))))
starbuck69 is offline
post #556 of 682 Old 05-04-2015, 09:53 AM
xvfx's Avatar
Quoted: 409 Post(s)
Liked: 231
This is great. I love the way how I can sweep through all in one go now. More so the 5 point saturation points.
xvfx is offline
post #557 of 682 Old 05-04-2015, 11:43 AM
Quoted: 1448 Post(s)
Liked: 601
Still enjoying your calibration disk Ted.
Used it just the other day to verify color clipping.
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is online now
post #558 of 682 Old 05-20-2015, 12:25 PM - Thread Starter
Liked: 1724
Send New Pattern Ideas Form
I have start making plans for the next version of my calibration disk. The release date is unknown.
The idea is to add as many patterns color reproduction patterns as possible, the ones that I have missed until now.
For example I want to add Color Space Evaluation Patterns, 2:35.1 patterns for projector users among with some focus/alignment of projector patterns also.
I will add videos for Plasma users, I'm thinking for Scrolling White Bars like the ones Panasonic or Pioneer Plasmas, Full Field Slides for panel-burn, Random Noise videos, Fast Flashing of Black/White video, Local Dimming Zones Identifier Chapter...Panel Warmup Chapter...
If you have any idea I will be pleased to discuss it with you.
You can send me your pattern ideas and I will try to include them to the next release of the disk.
If you have picture examples you can upload them using the multiple file uploader tool that is available to the webpage form.
By posting your ideas to that form, it will help me managing all your possible ideas.
You can send your ideas here: Send New Pattern Ideas Form
starbuck69 likes this.
post #559 of 682 Old 05-20-2015, 01:07 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
It is necessary to wait for the chromapure 3.
For plasmas need patterns with linear light (40%)or gamma light (area 8% and APL=25%).
Maybe basic patterns for chromapure 2.5.7 with gamma=2.35 for patterns 75 sat 75 luma.
Add rainbow pattern for 3DLUT.
Add gradient 16-bit from
http://forum.doom9.org/showthread.php?t=172128
anta1974 is offline
post #560 of 682 Old 05-21-2015, 01:11 AM - Thread Starter
Liked: 1724
Thanks for the feedback.
Yes, it will fully support ChromaPure 3.x
I will think about it.
ChromaPure 2.x.x calculates the Color Errors based to Gamma 2.22.
If I create specific patterns Gamut based to 2.35 Gamma, ChromaPure will still calculate the errors based to 2.22.
So this makes no sense to add something like that.
Do you mean a gradient from White to Light Blue? Can you post an example?
I can only add 8-bit (4:2:0) patterns, it's the Blu-Ray specifications.
But I will re-design a similar pattern from that you mentioning for Video Levels @ 8-bit.
anta1974 likes this.
post #561 of 682 Old 05-21-2015, 03:34 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
Hi Ted,
I second the motion for some sort of APL pattern set.
Also, I've just added these color cross-gradients to HCFR - I find the darker ones (0-20%) very useful for spotting quantization errors.
zoyd is offline
post #562 of 682 Old 05-21-2015, 05:50 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Originally Posted by N3W813
Can someone post a link to the gamut coverage video clip to test the 3DLUT for clipping and artifacting?
Florian use a simple granger rainbow to check for artifacting in saturated colors.
hoech.net/files/GrangerRainbow1920.avi.7z
anta1974 is offline
post #563 of 682 Old 05-21-2015, 05:52 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Use this link to test. If the red/blue words are as easy to read as the rest, then its 4:4:4.
http://cdn.avsforum.com/b/b4/b4a4404...tach208609.png
anta1974 is offline
post #564 of 682 Old 05-21-2015, 05:58 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
anta1974 is offline
post #565 of 682 Old 05-21-2015, 11:28 PM - Thread Starter
Liked: 1724
Originally Posted by zoyd View Post
Hi Ted,
Nice, I will add similar 45o gradients, from one primary to another primary, and from one secondary to another secondary.
We will talk about the APL motion pattern once I will start design it.
I'm collecting all the users ideas, thanks for feedback.
post #566 of 682 Old 05-22-2015, 02:59 AM
starbuck69's Avatar
Liked: 29
Hey Ted, what a good news... looks like your Disk will stay number 1 at top best calibration discs charts
I don't know if it's a good idea as it's not a technical pattern, but what about adding 2 or 3 HD real reference pictures such as a variety of human skin tones / hairs or natural landscape colors with low and high details to make a before/after calibration comparison with more common natural world material ?
post #567 of 682 Old 05-22-2015, 11:34 PM - Thread Starter
Liked: 1724
Hi, unfortunately I can't add reference images because I'm not familiar with professional photography, to shoot my own pictures etc.
Because the calibration disk is commercial, I can't use 'other people work' or stills from familiar movies due to copyrights.
Thanks all for the feedback. I'm taking notes for future changes.
post #568 of 682 Old 05-23-2015, 02:21 PM
W3Rman's Avatar
Quoted: 158 Post(s)
Liked: 131
Here is a copy of the New Pattern Idea I have submitted to your site
Screen Uniformity Test
Patch Set: Color Checker Classic / Color Checker SG
Patch Layout: 3x3, 3x5, 3x7, 5x7 (grid)
Patch Size: 1-3%
Patch Timing: 3, 6, 9 (seconds)
Background: 0% / APL: 15%-25%
W3Rman is offline
post #569 of 682 Old 05-25-2015, 12:49 PM
xvfx's Avatar
Quoted: 409 Post(s)
Liked: 231
Throwing ideas here, what about some form of document supplied something very detailed like the… http://www.homecinemaguru.com/checki...-your-display/
Personally I don't think it is detailed enough just like the Sea Biscuit document here. As there is some very fine detailed marks on the windows start of Casino Royale. That according to the Sea Biscuit document for the speckles, one would end up with crushed blacks.
Think this was it. After calibration - Reference movie
Calibration Anomaly on Newest of the New LG OLED!
Unless you choose your own reference film to document. Again, just throwing ideas about…
xvfx is offline
post #570 of 682 Old 05-29-2015, 07:49 AM
Tim1231's Avatar
Ted, I just set up a new projector (Benq W1070) and I have never done calibration before. Would you reccomend just using your free version or would a newbie be able to use your full calibration disk with no prior calibration experience?
Tim1231 is offline
Reply Display Calibration
Pioneer Elite Kuro Pro 1150hd 50 Inch Plasma Hdtv
