Ted's LightSpace CMS Calibration Disk - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 163Likes
post #631 of 667 Old 03-04-2016, 09:24 AM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1053 Post(s)
Liked: 1518
Originally Posted by Pres2play View Post
Ok Ted, I have it working now. In the Display Characterization window I had the Time Per Frame set at 2.5 seconds. I changed that to 1.5 seconds, to match the 1.5 seconds per Patch DIP Mode.
Also changed the Max Exposure time to 400ms.
Ted's Disk users can found here the full instructions about how to find the proper DIP mode Chapter to use for their setup.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #632 of 667 Old 03-04-2016, 10:45 AM
I have TED's CMS Calibration Disk Free Version but I can't get it to work, I open one of the batch files like these on the image and this menus appears, I choose some number and nothing happens
Helder Carvalho is offline
post #633 of 667 Old 03-04-2016, 11:00 AM - Thread Starter
Liked: 1518
Hi, Free Version contains ColorChecker Classic Chapter only, so you have to select the '9' from the available options you see when you run the Batch file.
You need CalMAN 5 opened behind the Batch window and to have enabled the keyboard commands from CalMAN Setttings, and when you will see the Info Screen that the Batch file will tell you, you have to press a key for the Automated measurement procedure to start.
Here are the complete instructions, there useful examples with pictures here:
CalMAN 5 has some keyboard shortcuts for quick meter or slider actions.
For example, the F5 keyboard button takes a single measurement and with the AutoAdvance option enabled from your Source Settings in CalMAN the slider will select the next color automatically after each measurement.
We are using a Batch file that you have to run and initially select what Chapter you want to use.
For example, to select ColorChecker SG (96 Color Patches) you have to input “10” and hit the Enter Button and after you see on your display the first patch.
You have only to press a keyboard key and that Batch file will send all the required timed commands without any other user prompt.
Now you will be able to use long measurement runs like 10-Step Saturation or ColorChecker SG automatically.
Using Ted’s LightSpace CMS Calibration Disk 1.1 you need only select the Chapter you want to measure using your Player Remote and when you see the first patch to your display to press a key from the batch utility.
All the required measurements will be automated.
That Batch file contains a series of DOS commands that do the required tasks for this automated procedure.
We are using the WinSendKeys utility to send the keyboard shortcut commands.
This is the list of the Batch files that are included:
NOTE: Don't rename that 6 Batch files because they will not work later. You can change the folder name or create shortcuts with custom names of you like.
Pre-Automated Procedure Testing
Before using any Automated Batch file you have to measure the Chapter in which you are interested to see which Chapter of 2/6/10 sec. patch display time works without problems with your current display/meter setup.
Try to take the measurements the semi-automated way as you were doing previously.
For example, use the 6 sec per patch chapter to see if any measurement takes more than 6 sec. time to return results.
If this is happening with your current meter settings, it will break the sync of the automated measurements.
Try to reduce the exposure setting and this will reduce the required time your meter will need to read each patch.
For SpectraCAL C6 users It’s recommended to use a fixed exposure time setting and not x Sample setting because low luminance patches will require more time and will break the sequence when you read a Black Patch or generally dark patches like 5/10% Gray or 5/10/15% Luminance etc.
In some cases the C6 will take about 15/20 sec to read black etc.
If you want to skip the black patch reading from the automated measurement procedure, we have created batch files to skip from all available chapters the Black patch measurement in case you want to manually enter your Black level luminance (cd/m2) into CalMAN’s Workflow Advanced Options or in case you take this measurement manually.
X-Rite i1Display PRO (i1d3) / SpectraCAL C6, i1PRO1/2 or Discus meters will be able to use the 6 or 10 sec. per color patch Chapter & Batch file.
Klein users will have no problem using the 2 sec. per color patch Chapter & Batch file.
CalMAN Pre-Automated Procedure Setup
Open CalMAN’s Settings Panel and check that you have enabled the Keyboard Shortcuts.
It’s optimum to set the pattern delay 0, or 0.5 sec.
It has to do with each display and needs some testing to find which delay works better in your setup.
If you will use Ted’s CalMAN’s 5 Verify Calibration Tools Workflow or any other, open the Source Settings Panel and check that the Auto Advance is checked.
Using Virtual Meter you can check if your Keyboard F5 button is taking measurements.
Simply select a color from your CalMAN slider and press F5 to see if it’s measuring and if it is going to the next color slider.
If by pressing F5 nothing happens the automated procedure will not work and you need to re-check your settings.
Start Automated Procedure Batch File
Once you have decided and tested manually which sec. per color chapter you can use with your current display/meter setup settings, locate the Batch files folder and double click to run the batch file or your selection.
When you double click the Batch file for the first time, a Security Warning will pop-up. You can un-tick the radio button if you want this warning to not be displayed in the future.
This is the Batch File Main Screen.
Here you can input your number for the chapter you want to use and press the ‘Enter’ key to continue.
The Batch file will now wait...
Navigate the disk menu or locate the media file... Using your Player Remote, select the Chapter from the CalMAN Session of the disk you want to measure...
Check that you have CalMAN Window Opened on your desktop and it’s not minimized on your taskbar.
Select from the CalMAN Slider the color patch that the Batch file is asking for before continuing.
After selecting the required Chapter from Ted’s LightSpace CMS Calibration Disk -> From CalMAN Session, you will see the initial Chapter Info Screen... after that screen when you will see the first color patch info screen to your display press a key from your keyboard... and let it flow...
After the end of the measurements, the Batch file it will return to it's main menu for you to select a new measurement if you like.
If you do all the steps correctly and the automated procedure measurements hasn’t started, re-run the Batch file and by right clicking select ‘Run as administrator’ command.
post #634 of 667 Old 03-08-2016, 12:51 PM - Thread Starter
Liked: 1518
Originally Posted by drparker151 View Post
I just got a Samsung K8500 UHD player.
Hi, one Ted's LightSpace CMS Calibration Disk user with DVDO AVLab TPG tested the accuracy of the player output using the DVDO's ColorChecker function where it displays the digital level of any pixel of the signal.
Here are the results:
Color Space YCbCr 4:4:4
Color Space RGB Limited
It seems the most correct color space is YCbCr 4:4:4 mode. And picture mode at K8500 should be Standard instead of movie because movie mode alters the YCbCr or RGB values of the source signal even if YCbCr 4:4:4 is chosen.
If you want to ask him something, contact him from here: Official Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player Owner's Thread
post #635 of 667 Old 04-12-2016, 04:28 PM
mo949's Avatar
Liked: 1113
Ted,
I got to play with your disc and I think its incredibly easy/powerful! Great job. I'm still learning what's what in it, but I was able to do quite a few things quite easily.
My only question at this point:
When doing the chromapure 4 pt saturation, do I select that in HFCR somewhere, or are the targets the same as HFCR default 4pt saturation points?
mo949 is offline
post #636 of 667 Old 04-12-2016, 04:47 PM - Thread Starter
Liked: 1518
Originally Posted by mo949 View Post
Ted,
Hi,
Thank you for your good words
For HCFR users, the ChromaPure 4-Point Saturation run don't need any change of HCFR preferences but if you want to run the CalMAN 4-Point Saturation run then you have to select it from the list available @ ''HCFR's Preferences -> ''References'' Tab -> ''Color Checker Patterns''.
HCFR 3.2.0 or later follows the same pattern order with Ted’s LightSpace CMS Calibration Disk Chapters for any of the above measurement options and the HCFR’s 8-bit RGB Triplets for each pattern are matching exactly the RGB Triplets that the Ted’s LightSpace CMS Calibration disk has been encoded.
Below you can find the updated list of the total CalMAN and ChromaPure Chapters that any HCFR user can use to take measurements. These Disk Chapters are accurate and match the HCFR's Color Engine Calculations:
Instructions for x-Point Grayscale ChromaPure's Chapters Measurements
Uncheck ''use round down levels" that is located to HCFR ''Preferences'' -> ''General'' Tab. This is affecting only Grayscale measurements.
Instructions for Instructions for Color Checker/Saturation/Luminance/Dynamic Range/Near Black Chapters Measurements
Before starting the measurements you have to select from HCFR's Preferences -> ''References'' Tab -> ''Color Checker Patterns'' drop down menu list the selection of the measurement run you want to perform.
Select ''GCD'' if you want to measure using ChromaPure’s Color Checker Chapter.
Select ''ChromaPure skin tones'' if you want to measure using ChromaPure’s Color Checker Skin Tones Chapter.
Select ''CalMAN Classic'' if you want to measure using CalMAN’s Color Checker Classic Chapter.
Select ''CalMAN SG'' if you want to measure using CalMAN’s Color Checker SG Chapter.
Select ''CalMAN SG skin tones'' if you want to measure using CalMAN’s Color Checker SG Flesh Tones Chapter.
Select ''CM 4-Point Saturation (100AMP)'' if you want to measure using CalMAN's 4-Point Saturation (100% Stimulus Level) Chapter.
Select ''CM 4-Point Saturation (75AMP)'' if you want to measure using CalMAN's 4-Point Saturation (75% Stimulus Level) Chapter.
Select ''CM 5-Point Saturation (100AMP)'' if you want to measure using CalMAN's 5-Point Saturation (100% Stimulus Level) Chapter.
Select ''CM 5-Point Saturation (75AMP)'' if you want to measure using CalMAN's 5-Point Saturation (75% Stimulus Level) Chapter.
Select ''CM 10-Point Saturation (100AMP)'' if you want to measure using CalMAN's 10-Point Saturation (100% Stimulus Level) Chapter.
Select ''CM 10-Point Saturation (75AMP)'' if you want to measure using CalMAN's 10-Point Saturation (75% Stimulus Level) Chapter.
Select ''CM 6-Point Near Black'' if you want to measure using CalMAN's 6-Point Near Black Chapter.
Select ''CM Dynamic Range (Clipping)'' if you want to measure using CalMAN's Dynamic Range (Clipping) Chapter.
Select ''CM 4-Point Luminance'' if you want to measure using CalMAN's 4-Point Luminance Chapter.
Select ''CM 5-Point Luminance'' if you want to measure using CalMAN's 5-Point Luminance Chapter.
Select ''CM 10-Point Luminance'' if you want to measure using CalMAN's 10-Point Luminance Chapter.
Note: The pattern sequence of CalMAN's 10-Point Luminance is identical to the Color Checker Selection ''RGB Luminance Axis'', so it can be selected from the drop-down menu available @ HCFR's Preferences -> ''References'' Tab.
mo949 likes this.
post #637 of 667 Old 04-12-2016, 04:55 PM
mo949's Avatar
Liked: 1113
Thanks Ted!
ConnecTEDDD likes this.
mo949 is offline
post #638 of 667 Old 04-19-2016, 05:26 AM
Icaro's Avatar
Quoted: 50 Post(s)
Liked: 25
WOW !!!
Finally now, thanks to Ted's Disk, I can automatically calibrate any player (software or stand alone),
with this Disk (in coupled to Lightspace CMS), I can finally calibrate my favorite player software:
Arcsoft Total Media Theatre.
I sets only the white point,
a click, and everything is automatically calibrated.
When finished, it creates a 3DLUT and load in Eecolor. It's something magical assist automation between Ted Disk and Lightspace CMS.
Thank you so much Ted,
you're a genius.
You have created the best calibration Disc, existing on the planet !!!!
My Epson laser LS10000 soared !!!
Sorry for my bad English
Icaro is online now
post #639 of 667 Old 05-11-2016, 12:03 PM
-Hitman-'s Avatar
Quoted: 134 Post(s)
Liked: 106
Thank you Ted for the continuing support since purchasing your invaluable disk, a great friend to have and resource of information for us enthusiast calibrators, thank you!!
-Hitman- is offline
post #640 of 667 Old 05-29-2016, 02:57 PM
SeanyP321's Avatar
A quick review of Ted's calibration disk
Ted's disk is an brilliantly designed and well thought out calibration solution. The disk includes everything you need to carry calibrations from basic greyscale correction right on through to full 3D LUT tables. Everything is in a sensible, straightforward and easy to understand order and when used in conjunction with LightSpace, the disk becomes a powerful and automatic solution to building advanced 3D LUTs.
But the truth is that the disk itself pales in comparison to the font of knowledge that is Ted himself. A disc, which costs me more than a trip to my local cinema, gave me access to the man behind the disc - and as a new comer to calibration, Ted helped me every step of the way, working with me to get my home theatre calibrated to the highest possible standard. No question was too stupid for him, and believe me, I had some stupid questions. Ted always had time for me.
I couldn't rate Ted and his Calibration Disk highly enough. Buy it, you will not regret it!!! Thanks Ted.
SeanyP321 is offline
post #641 of 667 Old 06-01-2016, 07:38 AM
OMARDRIS's Avatar
Quoted: 24 Post(s)
Hi,
I use Ted's Light Space CMS Calibration disc since December 2014 with CalMAN5 Enthusiast, HCFR and Xrite i1Pro2 and I am extremely satisfied.
Meanwhile, I have ordered Light Space HTL and am looking forward to use the disc in order.
Even if you are using a pattern generator, Ted's Light Space CMS Calibration Disk is very important in order to subsequently verify the entire signal path from the Blu-ray player to the display.
Perhaps there is one day a Ted's Light Space CMS Calibration Ultra HD Blu-ray.
PF
OMARDRIS is offline
post #642 of 667 Old 06-02-2016, 01:05 PM
Icaro's Avatar
Quoted: 50 Post(s)
Liked: 25
I agree fully.
Ted you are working on pattern greyscale 10pts. 20pts. for the Quikprofile in Dip mode, with the LightSpace is true?
Thanks again !
Massimo
Icaro is online now
post #643 of 667 Old 06-02-2016, 04:20 PM - Thread Starter
Liked: 1518
Originally Posted by Icaro View Post
I agree fully.
Thanks again !
Massimo
Hi Massimo,
When a newer version of the disk will be released it will contain all changes that are available in current versions of LightSpace/CalMAN/ChromaPure/HCFR.
There is no timeline, when I will have it ready I will inform the disk users/threads etc.
post #644 of 667 Old 08-31-2016, 05:28 AM
Quoted: 26 Post(s)
Liked: 3
Hey Ted,
i just wanted to thank you for your outstanding support I will probably come to you more often as i am about to calibrate my Oled TV.. i will use your media files as well while doing that.
So there will be more questions... i am sure about that !
RoninF is offline
post #645 of 667 Old 09-05-2016, 02:41 PM - Thread Starter
Liked: 1518
Originally Posted by RoninF View Post
Hey Ted,
Hi,
Just remember to use the patterns (Media Files or Blu-Ray Disk) from your actual movie playback device.
So if you have for example a Media Player (use the Blu-ray ISO or the Media Files), if you have blu-ray player then use the Blu-Ray ISO. If you playback movies from your Blu-Ray Media files, check if it's match the output from the HDMI also.
There sometimes where the USB Input of a Blu-Ray Player handles differently and has different output vs. it's HDMI.
There also players with 2 HDMI output which picture don't match because it's HDMI is controlled by different chipset or has different pipeline internally.
There a lot of times where users are contacting me to report no good calibration results using software pattern generators etc....
Example, think the scenario that you I send for free a Quantum Data 780C ($6.500) Reference pattern generator to use for Patch generation.
Think that you have 2 players in your video chain, one OPPO for Blu-Ray and one Dune for movie playback of media files.
It happened to measure these 2 players by connecting my DVD AVLab TPG using the colorchecker feature where it display the digital level of the specific pixel you have selected, so I connected OPPO -> eeColor (with UNITY videoscaled) -> DVDO -> Display and later Dune -> eeColor (with UNITY videoscaled) -> DVDO -> Display.
I used my disk ColorChecker Classic and Gamut patterns for testing, both player were outputting 8bit, the eeColor makes 8bit input to 10bit output (since the 3D LUT table internally is stored in 10bit). and since I knew the digital RGB triplets of my disk, I generated the following charts by measuring these 2 players. Both Players were sending RGB-Limited to eeColor, eeColor internally is working in RGB space (so there no any colorspace conversion which eeColor involved).
So as you can see even if you will use the Quantum Data as a patch generation, you will still have these errors because you are ignore to fix the player output the player is introducing.
When you are using as PC/Notebook output that you don't have tools to verify it's digital levels to see if it's bit perfect, then your final correction will have ignore to fix the player output errors + the HDMI output of PC/Notebook errors will be added to your signal also.
These all stuff, reminds me 2012, when the 3D LUT was entering to HT market and the calibration solutions are ignoring that stuff, and this forced me design and co-operate with LightIllusion to find a way of providing a 3D LUT solution that will calibrated the whole video chain of any HT system, automated with patterns generated from each source specifically.
mo949 likes this.
post #646 of 667 Old 09-21-2016, 01:24 PM
Eliran.I's Avatar
I wanted to tell you all about my experience with Ted. I came across this thread as I was looking for something that will guide me and help me in calibrating my LG OLED65E6 TV after purchasing i1Display Pro and the Calman Enthusiast software. Before I used Ted's disc, I used the Client 3 as test pattern generator and it was a nightmare. I spent hours on hours trying to figure out whats not working properly with the patterns as I always got different result and wasn't able to perform a steady calibration, although I followed the directions by Spectracal support.
Using Ted's disc on my new Oppo 105D was a breeze! What an amazing work he had done on that disc and using it with the workflow that he created dedicated for Calman users was even easier and was just brilliant!! Moreover, his support and motivation to help is far beyond any expectation and I want to thank you for that Ted! You helped me a lot with all the questions and problems I had with the hardware, software and the procedure! All Ted's answers were detailed, accurate all from his wide and deep experience. He answered in very short time, almost immediately, which is not obvious at all! Keep up the good work my friend!
To everyone that still debating whether to get or not to get his disc, don't think twice. For that price, its really undervalued to what you really get plus the support in every step!
fafrd, ConnecTEDDD and W3Rman like this.
Eliran.I is offline
post #647 of 667 Old 09-24-2016, 11:37 AM
Tom899's Avatar
Quoted: 87 Post(s)
Liked: 25
I've been interested in calibrating my projector. I started searching around for a good calibration disk, I already have a few popular ones but wanted to see what if anything was new. I came across Ted's LightSpace Calibration Disk, and so glad I did! You also instantly get sent an email with links for Workflows and other goodies. I purchased it and started using it right away.
It started out I had a few questions so I emailed Ted. Ted got back to me right away and helped me out tremendously! I'm rather new to calibration software and not familiar with what values to shoot for, or for that matter what some of the values mean. I had recently bought Calman, I sort of wish now that I would have bought Lightspace. But anyway, I started using Ted's Workflows in Calman and my projector is getting dialed in with Ted's help. I learned a tremendous amount in a few days time emailing back and forth, I had many questions. Ted's Workflows are very easy to look at and understand.
Ted's Disk, Workflows, and Support are Top Notch! Highly recommended!
-Tom
Tom899 is offline
post #648 of 667 Old 10-10-2016, 04:13 AM
bankroot's Avatar
Liked: 7
I have been writing about Ted's disc already. That it is the masterpiece, "must have" for all (not only home enthusiast) calibrators.
There is no comparison with all cheap generators like FireStick, Google Chrome or PC.
In my opinion even with one milion dollars professional generator.
Why? Because it allows us to measure ALL video chain. Every video device (BD player, media player or PC) has its own errors which are not fixed, when we use external pattern generators.
I am experienced with those problems, besause I have just finished calibration of my Panasonic GT60 with my DUNE and PS4 players.
I did it with LS software ( Ted's disk works with LS amazingly) and eeColor video processor.
The result is outstanding - no chance to achieve it with 1D LUT table.
By the way: Ted is fantastic men, very helpful and patient. I bothered him very often, he has been always ready to give an advice and help. Gold men! Do not forget to donate him my friends, he does great job for us
bankroot is offline
post #649 of 667 Old 11-30-2016, 01:09 PM
Quoted: 1363 Post(s)
Liked: 898
I wanted to mention that I took Tedd's advice and used his meter profiling workflow for calman when I profiled my C6 with my i1Pro2. I ran seven profiles and then compared each of them using the workflow and as he stated, some were better than others. I can't stress how important it is to verify the profile before you start calibrating since if it's off, which happens sometimes for unknown reasons, then you will be calibrating with a profiled meter that not accurate or not as accurate as it can be.
John
LG 55OLEDE6P
55HU9000 / SEK-3500
Marantz 7009
Ohm Walsh Speakers
ISF Level II Certified
jrref is offline
post #650 of 667 Old 12-02-2016, 01:22 PM - Thread Starter
Liked: 1518
Hi, thanks for posting your experience with Meter Profiling Check Procedure using my CalMAN's 5 Workflow, I have described how it works here: CalMan 5 Release Notes and Discussion
This is a very important step for all the users that using their spectro to correct with a 4-Color Matrix Table their colorimeter, but the reality is that most of the users are bypassing that verification, they spend $1.000 for a i1PRO2 (or more for other spectro's) but their meter correction maybe off, away from i1PRO2's readings, so makes no sense to buy your own meters if you skip that step, where when the profile is off, you come back to the performance of an un-profiled meter.
NIST's accepted tolerances are max xy +-0.001 and +-1.5% Luminance difference between the 2 meters (Reference & Profiled).
post #651 of 667 Old 12-02-2016, 01:34 PM
mo949's Avatar
Liked: 1113
This disc is a must have. Thanks again Ted.
mo949 is offline
post #652 of 667 Old 12-04-2016, 10:39 AM
mo949's Avatar
Liked: 1113
I posted my observations/results when comparing a good calibration being played through my bluray player and measured by HFCR here HCFR - Open source projector and display calibration software
Needless to say I am astonished by the truth that your disk has helped me uncover, that my calibration results have always been flawed since they were achieved via pattern generator and not taking into account my player. Next time I buy a player I am going to be asking you TED
Thank you so much for answering my questions in the middle of the night, you saved my sanity and possibly my marriage, at least for this weekend
This and HFCR are amazing products. Thanks!
mo949 is offline
post #653 of 667 Old 12-04-2016, 01:51 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2611
Originally Posted by ConnecTEDDD View Post
Hi Massimo,
Ted,
As you know, your disk is the only pattern reference source I trust. It has helped me find my way out of the calibration weeds on many occasions .
For the time if/when a new version of your disk is released, and through whatever process user requests are considered, I have a pattern request on behalf of all LG OLED owners:
OLEDs require near-black patterns that go beyond the near-black patterns that have been sufficient for lesser displays.
Your 6-pt near black patterns are great because they include 0.5% (video level 17) which is a pattern I use when dialing-in brightness, 2-pt-low, and 5% whitepoint controls all the time, but Ibwould like more.
The entire region below 5% is very critical to OLED calibration and it would be great to have a 27-pt near-black pattern that includes all video levels from 16 (0%) to 27 (5%).
I can do this with the HCFR user patterns generator but do not trust their accuracy...
Believe, OLED owners everywhere will thank you if you can add a complete near-black pattern set to your next release...
fafrd is offline
post #654 of 667 Old 12-06-2016, 05:09 AM - Thread Starter
Liked: 1518
Originally Posted by fafrd View Post
Ted,
Hi, there plans for additions especially for OLED/Projector users, when that time will come.
post #655 of 667 Old 12-07-2016, 07:42 PM
Liked: 898
So the question is, if you create many profiles and they all don't seem "accurate enough", what steps can you take to get a better result?
John
LG 55OLEDE6P
55HU9000 / SEK-3500
Marantz 7009
Ohm Walsh Speakers
jrref is offline
post #656 of 667 Old 12-08-2016, 03:08 AM - Thread Starter
Liked: 1518
Hi, when you are experiencing that issue, you have to check your meter settings to see how you can improve the readings to become more stable; which will give you more accurate meter correction tables.
Since you are using my disk, load the Pre-Calibration Tools Workflow and locate the White Balance layout page:
Display the WRGB patterns and measure them in continuous mode, check various meter exposure times or add multiple samples per read, test refreshing rate options; how all these changes are affecting the readings, until you find the best combination which will give you more stable xyY numbers.
anta1974 and jrref like this.
post #657 of 667 Old 12-08-2016, 05:19 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2611
Your 0.5% near-black pattern (video-level 27) is the best pattern for calibrating Brightness setting on an OLED.
Dark pluge patterns don't work because the small amount of text and the brighter bars throw off the eye's ability to detect a glowing screen.
Once the text dissapears from your 0.5% pattern, it allows both true black to be calibrated (no glowing) while also maximizing the intensity of video level 17 (which is usually crushed into black on OLED calibrations).
As I stated in an earlier post, it would be great to see a full set of near-black video level patterns (video levels 16-27) when you get around to your next release...
I've also seen with OLED the nonlinearities that can be caused in between 21-pt settings, so a 41-pt greyscale sweep would also be useful to check for gamma / greyscale nonlinearities between the typical 21 read points...
fafrd is offline
post #658 of 667 Old 12-09-2016, 11:48 AM
mo949's Avatar
Liked: 1113
Left this feedback on your site:
"This disk is incredibly powerful. It makes it feel like you have a pattern generator that you can feed through your bluray player to ensure ultimate accuracy. I didn't realize how much of an error my bluray player added to the image until having a practical tool like this to use. Thank you Ted for your disk and commitment to supporting your users!''
mo949 is offline
post #659 of 667 Old 12-23-2016, 05:55 PM
trp3383's Avatar
Quoted: 65 Post(s)
Where can I find this particular pattern? Trying to set brightness on my oled. Thanks
trp3383 is offline
post #660 of 667 Old 12-23-2016, 06:04 PM - Thread Starter
Liked: 1518
Hi, this pattern in included inside the 6-Point Near Black Chapter (0.5-1-2-3-4-5%):
It contains the following patches:
0% Black (RGB Triplet: 16.16.16)
0.5% Gray (RGB Triplet: 17.17.17)
1% Gray (RGB Triplet: 18.18.18)
2% Gray (RGB Triplet: 20.20.20)
3% Gray (RGB Triplet: 23.23.23)
4% Gray (RGB Triplet: 25.25.25)
5% Gray (RGB Triplet: 27.27.27)
An alternative way to measure the any of the 16,17,18,19,20...until 25 level you like; is to load the Brightness Flashing Bars Pattern and pause it:
Each bar is large enough to place your meter in contact above to each bar and measure the level you want.
Other patterns you can use for brightness setup (the digital levels for each pattern are shown to that link):
Advanced Brightness Flashing Bars Pattern (Pre-Calibration Tools Page)
Advanced Brightness Black & White Flashing Bars (Pre-Calibration Tools Page)
Black & White Steps (Color Reproduction 1 Page)
Black & White Tunnel (Color Reproduction 1 Page)
Black & White Bars (Color Reproduction 1 Page)
7-Color Low-High (Color Reproduction 1 Page)
Black Level (Color Reproduction 1 Page)
Black Square Tunnel (Color Reproduction 1 Page)
Grayscale Full Steps (Color Reproduction 2 Page)
Black Tunnel (Color Reproduction 1 Page)
For example, about Black Tunnel:
This is a pattern which has flashing boxes. The picture you see here, it doesn't have the original pattern digital levels, I have lift the brightness by 150% using Photoshop to the whole image; for being easier to the users to see all the areas of that pattern at that example.
The things which have to flash is the 17 boxes, the text which say 17 (large letters are the center left top side, left bottom side) or 0.5% (at center right side)
Also at bottom left side, no box should be visible, because all boxes are from 16 till 8. Only the letters which say 17 has to be visible and flashing.
This is good for checking if a wrong brightness setting will lift black levels.
There also letters which say 'This is 2%/4% below black and should not be visible'' The letters have 16 level fill, so they have to be invisible. (If the user sees a boarder for this letters, this means that he has high it's sharpness.)
When you don't see any flashing box of 16 and below but you still able to see the letters fill ''This is 2%/4% below black and should not be visible (letters fill/color is 16) this means that some enhancement in processing is detecting and boosting that level, so you have to find out which setting is enabling the artifact and disable it.
When you don't see any flashing box of 16 and below but you still able to see the letters boarder (not fill) ''This is 2%/4% below black and should not be visible (letters fill/color is 16)This is reference Black & should not be visible'' flashing (while the letters fill is invisible), this means that your current sharpness setting is not correct and you have to reduce the sharpness slider more.
It has to do with the combination of sharpness setting with the image processing engine of each display, that enable/boosting these fake details that are not supposed to be visible.
This is a good pattern to check near black levels to 3 parts of the screen. not only one as usual. If you imagine an area where a 2.35:1 movie covers, this is inside to the 3 areas where the pattern is flashing. Usually the corners or up-down bars are black to the most of the movies.
mo949 likes this.
Reply Display Calibration
Pioneer Elite Kuro Pro 1150hd 50 Inch Plasma Hdtv
