Which calman 5 to buy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-29-2013, 09:13 PM - Thread Starter
uderman's Avatar
Quoted: 91 Post(s)
Liked: 44
Hi,
I want to buy one of the calman5 sw and i1 oem bundles. I am not sure which one I need. None of my hardware is suitable for auto calibration so I am thinking the basic version but if c5 control offer more than just auto adjustments I am willing to pay the extra $100
here is my equipment;
Display:
Pioneer Pro-141FD 9th gen 60" plasma monitor
Video Processor:
Crystalio II VPS-3300 (has test patterns but not listed in sprectral)
Algolith Mosquito HDMI
Source:
Sony Bd-p790 BD player(region A)
Integra dhs-8.8 (toshiba xa2 clone hd-dvd)
Samsung bdp-5300 (region B)
Pioneer dv-420 (multi-region dvd player)
Jvc hm-dh40000u (d-vhs, d-theater)
Pioneer CLD-97( laserdisc player)
Tivo premier X4(has thx patterns)
I have calibration discs(tapes, Lds etc..) for each.
Do I need more than Calman 5 basic?
Wanted:
HD-VMD Discs
Muse/Hi-Vision Discs - Mint/Complete Only!
uderman is offline
post #2 of 10 Old 01-29-2013, 09:35 PM
praz's Avatar
Liked: 26
Originally Posted by uderman View Post
Hi,
Display:
Video Processor:
Source:
Basic should fit your needs. The difference in price of the two bundles is $150.00 You can always upgrade to Control later for the same amount of money.
praz is offline
post #3 of 10 Old 01-30-2013, 08:22 AM - Thread Starter
uderman's Avatar
Quoted: 91 Post(s)
Liked: 44
thank you for the reply
do you think I can use crystalio II as my pattern generator? It has many patterns built into it.
Wanted:
HD-VMD Discs
uderman is offline
post #4 of 10 Old 01-30-2013, 09:36 AM
derekjsmith's Avatar
Liked: 116
Yes the Crystalio II does have built in patterns but unfortunately development stopped on the Crystalio II before they could add support for controlling those patterns. We did ask and it was added to the features requests and we are told it was going to make it in but in the end it never did. So worse case is you just have to manually bring up the patterns as needed.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #5 of 10 Old 01-31-2013, 07:43 PM
Jestered's Avatar
Liked: 38
I'm also looking at getting a meter and CalMAN software bundle. I also don't quite understand what the differences are in the software versions. I'm just wanting to calibrate my Samsung 65" ES8000. What does the "basic" CalMAN software do that the "Tutorial" version doesn't? Also, is the C3 meter any good?
UPDATED: 04/05/2013 - My Colormunki/HCFR calibrated settings for 65" ES8000
LG OLED65E6P * Adcom GFA7000 Amp (FL/FR/C) * Marantz SR6010 AVR (Sur. x4 & FRH/FLH) * Polk RTiA5 (FL/FR) * Polk CSiA5 (C) * Polk FXiA6 (Sur. x4 & FRH/FLH) * SVS PB-1000 (SW) * URC MX-5000 Remote *
Jestered is online now
post #6 of 10 Old 01-31-2013, 09:38 PM
turbe's Avatar
Liked: 95
here is some info about tutorial
Originally Posted by derekjsmith
CalMAN 5 Tutorial is based on CalMAN 5 Basic with access to the Introduction, Tutorial Basic and Tutorial Advanced workflows. The idea is a CalMAN 5 for entry level users but not to limit being able to perform a full calibration. So with the Tutorial Basic workflow we walk you through setting Brightness, Contrast, Color, Tint, Sharpness, Overscan, Color Temperature preset, Gamma preset and a 2 point grayscale balance. Tutorial Advanced workflow picks up with a 2 point grayscale and into multi-point grayscale/gamma and finishes with CMS. The Tutorial workflows are fully functioning calibration processes but with a lot more handholding and information per step. CalMAN 5 Tutorial supports 3 meters the C3 our new entry level tristim, the D3 OEM and our C6. CalMAN 5 Tutorial can be upgraded at a later date to Basic, Control or Enthusiast. CalMAN 5 Tutorial is included with the purchase of the C3.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #7 of 10 Old 04-30-2013, 08:21 AM - Thread Starter
uderman's Avatar
Quoted: 91 Post(s)
Liked: 44
Hi again,
there has been changes to my equipment list and my budget is much larger now. I am going to order calibration gear and software next week. If anyone can direct me into some useful links to research or help me pick gear and software, I would really appreciate it.
Display:
Pioneer Elite Pro-141FD 9th gen plasma monitor
Video Processing:
Crystalio II VPS-3800 Pro (has built in patterns)
Source:
Oppo Bdp-105
Integra Dhs-8.8 (Toshiba Hd-Xa2 clone Hd-dvd player)
JVC Hm-Dh5u (D-Vhs deck with Hdmi)
Mcintosh MLD-7020 (Pioneer CLD-97 clone laserdisc player)
TiVo Premier Xl4 (has built in patterns)
I have calibration discs,tapes,Lds.
My budget is $1000-1200.
I am looking at Calman 5 enthusiast +C6 for $1000 then Calman 5 enthusiast + i1pro 2 enhanced is $1100.
then I read a lot of people use i1pro($250) in addition to one of above. can someone explain the benefit in this?
thank you in advance
Wanted:
HD-VMD Discs
uderman is offline
post #8 of 10 Old 04-30-2013, 11:30 AM
turbe's Avatar
Liked: 95
If you were getting a i1Pro 2 Spectro, you wouldn't need a i1Pro Spectro.... If you can find a used i1Pro Rev D. (they go for $250-$450), you could also add a i1D3 Colorimeter (OEM or Retail) and get CalMAN Enthusiast.....
I always recommend a i1Pro Spectrometer, even a used i1Pro Rev D ($250-$450) is great.
Why a Spectro, see why here:
http://www.avsforum.com/t/1373556/i1-pro-or-d3-if-you-could-only-have-one-meter
http://www.tlvexp.ca/2012/04/do-calibration-tables-really-work-for-tri-stim-devices/
And Read these Threads:
http://www.avsforum.com/t/1449310/eye-one-pro-or-display-3-pro
http://www.avsforum.com/t/1464411/what-would-you-rather-have-for-display-calibration
Chris Norfleet likes this.
ControlCAL™
turbe is offline
post #9 of 10 Old 04-30-2013, 11:36 AM
fairchild99's Avatar
Liked: 151
If you want a spectro, you can also get a brand new Colormunki Photo for around $400. (if getting used makes you nervous)
Sony 32" EX400 calibrated settings
Panasonic 50" S60 calibrated settings
HTPC/Sony S5100 to Sony HT-CT660 to Panasonic 55" VT60, Sony 32" EX400, Panasonic 50" S60
fairchild99 is offline
post #10 of 10 Old 04-30-2013, 11:40 AM
turbe's Avatar
Liked: 95
Here's some info about the ColorMunki Spectro: http://www.avsforum.com/t/1215746/colormunki-how-good-or-how-bad/60#post_18023662
ControlCAL™
turbe is offline
Reply Display Calibration
