Shod I trust AVSHD or GCD? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-01-2013, 02:57 PM - Thread Starter
Calby's Avatar
Quoted: 13 Post(s)
Hi,
When I was checking my greyscale I made some discovery.
I have different results if I measure with AVSHD window pattern or GCD Window pattern.
Which one shod I trust?
AVSHD709 Window pattern:
GCD APL pattern, I have the same results at GCD Window pattern:
I have LG 60PA550 Plasma
So which one shod I trust?
Calby is offline
post #2 of 10 Old 02-01-2013, 09:08 PM
wvolpatto's Avatar
try to do multiples measurement with the same pattern to exclude reading errors, undo your setup, re-do it and try again.,..
wvolpatto is offline
post #3 of 10 Old 02-02-2013, 01:30 AM
visca blaugrana's Avatar
One of the things I noticed is you are using GCD APL patterns, all depending on your monitor I would not expect identical results from the 2 patterns. Also avshd709 rounds down to neatest integer, where gcd uses mathematical roundings. What software are you using?
visca blaugrana is offline
post #4 of 10 Old 02-02-2013, 01:33 AM
If you are using generic calibration disk in calman? Then use gcd as calmal uses 50% to calculate gamma so the mathematical rounding would be correct.
post #5 of 10 Old 02-02-2013, 02:11 AM - Thread Starter
Calby's Avatar
Quoted: 13 Post(s)
Yes i use calman.
So gcd is The best disc for me?
Calby is offline
post #6 of 10 Old 02-02-2013, 03:05 AM
prsut's Avatar
Liked: 57
Do you also know what method uses chromapure ?
Panasonic TX-P42GT50E, Oppo 103, Schiit Vali, Denon AHD2000 + Moon Audio Blue Dragon V3, Phonak Audeo 121, Vsonic GR07, Fiio E17, Cowon S9, XLO cables :: CalMAN 5 Enthusiast,Chromapure Standard, i1D3, i1Display 2, TED's Calibration Blu Ray Disc v1.0 & v1.1
prsut is offline
post #7 of 10 Old 02-02-2013, 03:49 AM
Let me clarify as I could be misunderstood. Avshd709 is not wrong its all about how the software works. DVE and AVSHD709 has the same values, and the difference is minimal to gcd. In this instance I think the difference is down to apl vs windows.
I think chromapure uses % aswell but not 100% sure
post #8 of 10 Old 02-02-2013, 04:35 AM
fallengt's Avatar
It's plasma, so you'll get different results by using different patterns.
fallengt is offline
post #9 of 10 Old 02-02-2013, 06:01 AM
ndaa75's Avatar
+1
Eye is the final judge!
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #10 of 10 Old 02-02-2013, 11:15 AM
rahzel's Avatar
Liked: 148
+1.
Most LGs have two ISF modes. I would calibrate one using the GCD windows and one using the AVS windows and compare them. Visually speaking, they will probably look very similar.
rahzel is offline
Reply Display Calibration
