Increase gamma by lowering brightness - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-02-2013, 04:34 AM - Thread Starter
ndaa75's Avatar
Just a general question really. Is it wise to usenthe brightness setting to increase gamma?
For example I have a Panasonic VT30. Using a pluge i have set the correct brightness level accordingly. However to calibrate to 2.28 which gives better image pop over 2.2 i have to lower the brightness setting by 5 clicks. The set itself has 10pt gamma settings but playing with these can lead to undesired screen artifacts. So the question is have i followed the correct process in which to increase gamma ?
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #2 of 10 Old 02-02-2013, 04:48 AM
Bond 007's Avatar
Quoted: 2370 Post(s)
Liked: 1906
You would be better served by posting that here:
http://www.avsforum.com/t/1408338/official-panasonic-vt50-owners-thread/9840#post_22913104
Licence to Kill
Bond 007 is online now
post #3 of 10 Old 02-02-2013, 05:54 AM - Thread Starter
ndaa75's Avatar
Why is that? Its the process im after clarification on regardless of brand.
ndaa75 is offline
post #4 of 10 Old 02-02-2013, 06:04 AM
Bond 007's Avatar
Liked: 1906
I see. You are correct.
Licence to Kill
post #5 of 10 Old 02-02-2013, 06:05 AM - Thread Starter
ndaa75's Avatar
Thank you sir!
ndaa75 is offline
post #6 of 10 Old 02-02-2013, 06:45 AM
ThePrisoner's Avatar
Quoted: 221 Post(s)
Liked: 149
I remember reading that brightness should be set correct using the proper pattern and shouldn't be altered to influence gamma. I'm sure someone with more knowledge than me will reply.
Dolby Atmos/DTS:X 5.2.4
Samsung 65JS8500 (calibrated by Gregg Loewen); Marantz SR6010 + Onkyo M-5010; Oppo UDP-203; Apple TV (4th Gen); PS4; Definitive Technology BP-8060ST, CS-8060HD, SR-8040BP, Pro-Monitor 800; SVS PC-12NSD (2)
ThePrisoner is offline
post #7 of 10 Old 02-02-2013, 06:47 AM
Chad B's Avatar
Quoted: 492 Post(s)
Liked: 1179
You should not use the brightness adjustment to change gamma. It will lead, in this case, to crushed blacks. You want to be able to see (or at least have the TV display, whether you will see it or not depends on lighting conditions, APL, distance, etc) all the picture content above black. Reducing the brightness to raise gamma will sink that pic detail down into the black.
Chad B is online now
post #8 of 10 Old 02-02-2013, 07:52 AM - Thread Starter
ndaa75's Avatar
Ok.
So how do i increase gamma without touching the brightness ?
Presumably the process then would be.
1. Set brightness using pluge.
2. Set target gamma in tv menu, ie 2.2, 2.4 etc.
3. Measure gamma from 0-100 lum.
4. Use 10pt gamma controls to fine tune to desired gamma level.
ndaa75 is offline
post #9 of 10 Old 02-02-2013, 02:35 PM
Chad B's Avatar
Quoted: 492 Post(s)
Liked: 1179
I would swap #2 and #1. Changing the TV menu gamma selection often necessitates recalibrating the brightness adjustment.
Your correct options for increasing gamma would be the 10 point control and the 2.2, 2.4 etc gamma selection.
You know, you should be able to avoid major artifacts from the 10 pt control on your VT30, even the EU model that is stuck in low panel brightness. The VT30 has some visible banding in a gradient grayscale ramp even in THX mode, which doesn't have a 10 point adjustment. Basically, any mode that is not calibrated way too blue to cover up the problems is going to have at least some artifacts in a gray ramp. Now, misadjustment of the 10 point controls will certainly add to the problem; however, careful and meticulous calibration of them should give you a decent result with minimal artifacts and banding. If you have access to 5% increment windows where you can read in between the 10 point adjustments, use that as a tool to minimize errors in between bands.
post #10 of 10 Old 02-02-2013, 03:34 PM - Thread Starter
ndaa75's Avatar
Thank you for the in depth answer Chad. Sometimes these things can get a little confusing when youre learning! Cheers again. Have a great weekend.
ndaa75 is offline
Reply Display Calibration
