First time calibrating Sharp 70le847u. Grade my work... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-02-2013, 10:29 PM - Thread Starter
acrvp's Avatar
Liked: 30
First time calibrating ever. Did a lot of reading. Spent a good 3 hours calibrating. I spent forever on the primaries and secondaries and that was as close as I could possibly get them.
Used HCFR, Control Cal, and the AVSHD disc. I've attached my controlcal config as well. isfDay.xml 3k .xml file
acrvp is offline
post #2 of 6 Old 02-03-2013, 03:36 AM
sodaboy581's Avatar
Quoted: 27 Post(s)
Liked: 39
Good job, man! Very proud of you.
I am assuming you did your calibration in the Standard Gamut as opposed to the Expanded Gamut, right? I remember when I did my calibration on the SHARP I had, Standard Gamut was the only way to get the colors to get near correct and an accurate picture.
Extremely nice Gamma you got going on there too.
I remember Chad B he prefers to target a gamma of 2.3 on SHARP displays. If you ever get bored, you should try a calibration with a 2.3 gamma and compare the results.
Cheers!
Sony XBR-65X900E, Denon AVR-X2300W, Polk CS20 Center, Polk Monitor 75T Fronts, Polk TSI300 Rears, Power Sound Audio S1500 Subwoofer.
sodaboy581 is offline
post #3 of 6 Old 04-09-2013, 03:59 PM
ocsscott's Avatar
I just got my 847, care to share your settings? Sounds like you did a great job
thanks
ocsscott is offline
post #4 of 6 Old 04-09-2013, 06:19 PM
GeorgeAB's Avatar
Location: Denver, CO metro area, www.cinemaquestinc.com
Quoted: 152 Post(s)
Liked: 260
thanks
'Sharing display menu settings?'
http://www.avsforum.com/avs-vb/showthread.php?t=1055906
http://www.tlvexp.ca/2012/12/the-fruits-of-copying-settings-the-pioneer-lottery/
http://forums.hdtvtest.co.uk/index.php?topic=7202.0
GeorgeAB is offline
post #5 of 6 Old 04-29-2013, 04:57 PM
OCedHrt's Avatar
The point is that it is still probably better than whatever comes out of the box.
OCedHrt is offline
post #6 of 6 Old 04-29-2013, 08:56 PM
GeorgeAB's Avatar
Quoted: 152 Post(s)
Liked: 260
As demonstrated in the links provided: maybe.........maybe not. The point is that you would be wishing, hoping, guessing. Not reliable display calibration principles.
GeorgeAB is offline
Reply Display Calibration
Sharp Lc70le847u 70 Inch 3d Led Tv
