Samsung service menu question. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 31 Old 02-08-2013, 07:58 AM - Thread Starter
kbeam418's Avatar
Location: 41.7080574, -83.5911255 N41° 42.4834', W083° 35.4675'
Liked: 47
First of all I know I messed up by going into the service menu but I did this when I had little knowledge of tv settings and I saw an article saying you need to go into the service menu. Like all the other people who made this mistake I also did the HDMI calibration I got lucky and the image was just a bit sharper than usual so I used 8x8 1080p checkerboard pattern and did the test again and it was successful. But now I have to yank the brightness all the way up to 56. Kind of annoying because the preset brightness looked good to me is there anyway I can fix this issue?
"Then one day you find ten years have got behind you no one told when to run you missed the starting gun."
kbeam418 is offline
post #2 of 31 Old 02-08-2013, 09:41 AM
Otto Pylot's Avatar
Quoted: 1359 Post(s)
Liked: 852
Did you write down the settings before you changed anything in the SM?
Otto Pylot is online now
post #3 of 31 Old 02-08-2013, 11:42 AM - Thread Starter
kbeam418's Avatar
Liked: 47
No I didn't see the need to since I used the 8x8 figure at 1080p which I knew would make the test successful. It was successful it's just that I know have to yank the brightness to 56 where as I didn't even have to touch the brightness or the contrast setting. I
kbeam418 is offline
post #4 of 31 Old 02-08-2013, 11:47 AM
PlasmaPZ80U's Avatar
Quoted: 1962 Post(s)
Liked: 559
at this point you really have only two options: try to find a way to redo the ADC calibration that gives you an acceptable result or get your TV serviced (most likely main board swap will do the trick, since the ADC calibrations are only done in the factory and no service tech will do that when they can just replace a board and leave)
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #5 of 31 Old 02-08-2013, 12:22 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
The problem with trying to get Samsung to replace the board is that if the tech detects that the problem was caused by the owner diddling with the service menu (and Samsung is VERY well-aware that this is an issue), it could be very difficult to get Samsung to pay for the "repair" and the owner will be out the substantial cost of replacing the circuit board.
By the way... the problem this owner described could not be fixed if he had written down every setting in the service menu... once you begin the calibration process he mentions, you'd BETTER be a technician in the assembly factory or you are screwed.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #6 of 31 Old 02-08-2013, 01:00 PM
Otto Pylot's Avatar
Liked: 852
I was hoping for a positive spin on his situation but I can see now that once you venture into those waters, there's no return frown.gif
post #7 of 31 Old 02-08-2013, 05:07 PM
Liked: 559
yeah, the board may need to be replaced at the owner's cost
though if the OP had copied the values in the ADC Target and ADC Result area, it's possible the changes could have been reversed
post #8 of 31 Old 02-09-2013, 09:43 AM - Thread Starter
kbeam418's Avatar
Liked: 47
Ok guys the problem that I was having is that I was sending the checkerboard pattern at PC levels (0-255) which caused the tv to lower the brightness alot, I put the pattern on my Xbox 360 set the Xbox to standard reference levels (16-235) re-did the calibration and voila' problem solved now my brightness and contrast look like it did when I bought the TV. For anyone that has the HDMI Calibration fail send a 100 ire checkerboard pattern AT 16-235 LEVELS or else your brightness and contrast will be off.
kbeam418 is offline
post #9 of 31 Old 02-09-2013, 09:18 PM
Liked: 559
good to know, sounds like you got lucky
post #10 of 31 Old 02-10-2013, 06:05 PM - Thread Starter
kbeam418's Avatar
Liked: 47
Ya I don't why anyone needs to go into the service menu these days.Since you can control everything from the user menus.
kbeam418 is offline
post #11 of 31 Old 02-11-2013, 06:31 PM
Tyrone Burton's Avatar
I ventured in my Samsung PS51E6500's service menu, just to see what it looks like and to see how esy it may be to calibrate using it.............couldn't understand most of the settings available lol. Dangerous wink.gif
Hopefully this TV has all the settings necessary for a full calibration without going into the deadly service menu.
Tyrone Burton is offline
post #12 of 31 Old 02-11-2013, 06:37 PM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1772
Nothing in there for you but trouble your set has sufficient controls to get a great cal without going there
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #13 of 31 Old 02-11-2013, 09:14 PM
Liked: 559
the only thing I go in the SM for on a Samsung is to enable the N/D modes (CAL-NIGHT and CAL-DAY, which are like two extra Movie modes) and then lock the settings post-cal to avoid accidental changes
one more plus is that I can have the settings from one input copy to all the others, which means if I want multiple HDMI inputs to use the same settings, I only need to enter them once
post #14 of 31 Old 02-11-2013, 10:43 PM
good to know.
post #15 of 31 Old 02-12-2013, 04:48 AM
Phase700B's Avatar
Liked: 25
It does have ALL an owner needs for calibration and getting all the picture quality it is capable of.
Very risky and makes no sense just to "try and see " what is there. In some TV service menus, merely stepping through the service menu items or entering a menu item can permanently alter the factory setup.
Phase700B is offline
post #16 of 31 Old 02-12-2013, 03:22 PM - Thread Starter
kbeam418's Avatar
Liked: 47
I defiantly agree with you. Most sets these days have every setting you need for a calibration.
kbeam418 is offline
post #17 of 31 Old 02-12-2013, 03:22 PM - Thread Starter
kbeam418's Avatar
Liked: 47
kbeam418 is offline
post #18 of 31 Old 02-12-2013, 04:11 PM
When I buy a TV or projector. I make sure it has a full CMS system. So I know it has all the controls I need to do a good calibration.
post #19 of 31 Old 02-12-2013, 09:52 PM
Otto Pylot's Avatar
Liked: 852
So you recommend going into the Service Menu to make changes?
post #20 of 31 Old 02-13-2013, 06:09 AM
Phase700B's Avatar
Liked: 25
^ ^ ^ Apparently so. Not necessary though. This is not stated in an owners manual to do so and a TV owner would risk voiding a warranty. We read all too many times here on AVS that some imply or advise to go onto a service menu "just to enable" something or look at settings.
post #21 of 31 Old 02-13-2013, 06:52 AM
praz's Avatar
Liked: 26
Unfortunately having full CMS and a working CMS are not always mutually inclusive.
praz is offline
post #22 of 31 Old 02-13-2013, 09:44 AM
Liked: 559
you activate the modes in the service menu and use them in the user menu
there are only two parameters in the SM that are changed
Service Menu -> Expert ->
N/D Adjust: OFF to ON or FIX (whether you want the modes activated or not and settings locked or not)
Source: Current or All (whether you want the settings to be independent by input or not)
Of course, if you don't know how to navigate the SM properly or are uncomfortable with doing something like this, you shouldn't. And you certainly shouldn't do anything else while you're in there.
post #23 of 31 Old 02-13-2013, 10:00 AM
Liked: 559
also, these modes can be fully reset in the user menu and are adjusted in the user menu only... the only part that requires the SM is enabling them
post #24 of 31 Old 02-14-2013, 10:18 AM
Otto Pylot's Avatar
Liked: 852
I don't know. I think suggesting someone go to the SM for anything is not good advice. Not everyone who frequents these forums are as knowledgeable as others and different firmware versions may affect SM settings, so unless someone has the exact same model/build number and firmware version, and even that's not a guarantee, it would probably be advisable to not venture there at all. Just a thought.
post #25 of 31 Old 02-14-2013, 12:07 PM
Liked: 559
I understand your viewpoint and I'm not recommending everyone goes out and does this, just that there are two extra modes on certain Samsungs (usually the mid range to high end ones) for calibration purposes. Having a separate day and night mode per input can be useful to some and I know in the past pro calibrators have used these modes too (when they work properly).
Also, it's not uncommon to go into the service menus of some sets like the Panasonics to do grayscale and/or unlock certain picture modes. On the other hand, you wouldn't want to go into the service menu of an LG since there nothing useful for calibrators there and it's very easy to mess things up by just entering certain portions of the menu (think ADC/White Balance calibrations performed in the factory when the TV was made).
post #26 of 31 Old 02-15-2013, 12:16 AM
charlesDean's Avatar
Hello,
Because to make a square two will need 2vertical and 2 horisontal line. in a checker board there are 9 vertikcal and 9 horisonatl line each. so from 9 lines available we pick 2 and the combinations of the two lines can be calclauted as C(9,2).
charlesDean is offline
post #27 of 31 Old 02-15-2013, 06:05 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Only reason I had to go into samsung service menu is for a older 32" LCD. Dynamic contrast and some other post processing was enabled, even if you disable it in the menus.
But I agree there is no need to go into service menu in modern TV's.
fatbottom is offline
post #28 of 31 Old 02-19-2014, 10:17 AM
sashimiso's Avatar
Hi,
I really need help (in more ways than one of course, but lets stick to the TV problem)
I was having some problems with my Samsung UE40D65. So, I did a google search, and in the first thread I read about the Service menu and resetting everything.
I thought, this will be great and easy and I will be ok when all over. As you all already know, just the opposite has happened.
No, I did not write anything down as I thought it was getting reset to how I purchased it.
Is there anyone anywhere who has documented what the menu items mean so I can step by step try to correct things?
Thanks in advance
sashimiso is offline
post #29 of 31 Old 08-25-2014, 10:16 PM
darkvader001's Avatar
What do you mean, with 16-235 levels? How can I do that?
darkvader001 is offline
post #30 of 31 Old 08-25-2014, 10:44 PM
Otto Pylot's Avatar
Liked: 852
16 - 235 are video luminance levels, black at 16 to white at 235.
0 - 255 are computer luminance levels, black at 0 to white at 255.
Ph8te likes this.
Reply Display Calibration
