ee/ColorBox, LightSpace, and 3D LUT Calibration - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 64Likes
post #481 of 489 Old 12-05-2015, 04:01 AM
Pres2play's Avatar
Quoted: 470 Post(s)
Liked: 260
Thanks Ted. I'll try that, but I think my 2 point white balance is to blame. I restored the values at 20% and now the black background is black again with low-light patches. What this means, I think, is that I won't be able to balance the low end of my greyscale without raising minimum light levels.
Pres2play is offline
post #482 of 489 Old 12-05-2015, 05:16 AM
Light Illusion's Avatar
Quoted: 320 Post(s)
Liked: 627
What you have to remember is that with blacks you can only balance by 'adding' colour, as reducing will cause clipping.
As a result, the 'black level' will lift.
But, there should be no difference in black level with different sources.
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #483 of 489 Old 12-05-2015, 12:09 PM
Pres2play's Avatar
Quoted: 470 Post(s)
Liked: 260
That makes a lot of sense, but I'm a bit surprised finding out that adding color at 20% can lift blacks at 0%.
Perhaps a more targeted approach using the 10 point can help? I will see later today.
post #484 of 489 Old 12-05-2015, 02:53 PM
Quoted: 320 Post(s)
Liked: 627
I too am surprised that 20% changes are affecting black, but some TVs have poor internal colour management controls.
As we do suggest, you can often get superior results by not using any internal colour management controls.
Just place all the TV settings to their basis settings, to give the best overall image consistency, with black and white clipping correctly set.
Image constancy means the most constant readings across the gamma and gamut, regardless of what the actual readings (colours) are.
Then let LightSpace CMS do the rest wit the 3D LUT.
This is the approach we use with many displays - and the results are near perfect.
See: http://www.lightillusion.com/calibra...omparison.html
The initial display set-up is far removed from the final calibration via the LightSpace 3D LUT - but the results are near ideal.
Steve
Steve Shaw
LIGHT ILLUSION
post #485 of 489 Old 06-02-2016, 02:40 PM
Pres2play's Avatar
Quoted: 470 Post(s)
Liked: 260
When replacing a single 3D LUT using the Truvue app, the instructions are: Select 'Display Type'>Standard Non-RGB LED Display>General Media
Would it make a difference if I selected "RGB LED" instead? My Samsung is RGB "OLED" type.
wl1 likes this.
post #486 of 489 Old 06-03-2016, 09:25 AM
Quoted: 320 Post(s)
Liked: 627
No, it will make no difference at all.
You are specifically replacing the LUT with the one you have generated - the eeColour settings such as Standard Non-RGB LED Display, RGB LED are nit used in any way.
They were only of any value when using the (non-calibration based) original eeColor settings.
Steve
Steve Shaw
LIGHT ILLUSION
post #487 of 489 Old 06-03-2016, 03:42 PM
Pres2play's Avatar
Quoted: 470 Post(s)
Liked: 260
Thank you Steve!
post #488 of 489 Old 01-29-2017, 07:31 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
I'm a bit confused...
I used DisplayCAL to generate a LUT for my projector. I then selected save and the software generated 7 files: 3 were first1d-red/green/blue and then 3 that were second1d-red/green/blue and a single text file.
What do I do with them now? I believe I saw in the thread to rename to 3DLUT_# with # as the memory slot. Do I name the non-color file to this?
Then what? I see in post #2 what to select in the TrueVue software, but how does it know to use the file I saved? Do I need to put it in a certain folder?
Brian
Edit: Okay...I see these RGB files are not needed, but still need to know what to do with the single text file...
Edit#2: Does it go in TruVue Application/Data/3dtable/standard nonrbg led/General Media/3DLUT_# ?
Brian B is offline
post #489 of 489 Old 01-29-2017, 07:56 PM
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
Brian
Brian,
read this, should clear everything up ;-)
http://displaycalibrationtools.com/d...orkflow-guide/
- M
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
Reply Display Calibration
