ee/ColorBox, LightSpace, and 3D LUT Calibration - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 68Likes
post #61 of 496 Old 03-14-2013, 10:46 AM
turbe's Avatar
Liked: 97
Originally Posted by sotti View Post
My only point is that this flaw exists, even though Steve denied it early in the thread.
Steve mentioned in regards to this in the past with the statement they were working with EE on the issue (nearly 6 months ago)..
Originally Posted by Light Illusion View Post
The eeColor box seems to only work with TV legal level display, and we are working with Entertainment Experience on addressing the issue - adding full range data as well as TV legal capabilities (PC and TV level options).
recent:
We use a 65x65x65 formats with LightSpace and the eeColor LUT box, and the results are far from 'unusable' for PC (data) formats.
Steve
For the vast majority of users posting here, video levels will be it and from the marketing material directly from EE that I've read (not from early Distributor's marketing) for this and their other product, they really targeting the Home Theater market IMO though there may be some that want to use this fed by their PC who haven't been happy with LUT attempts on the PC
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #62 of 496 Old 03-14-2013, 11:08 AM
daewoo's Avatar
Hi
you said that Calman 5.1 will support eecolor box while mine already works with LS and Calman 5.1 Enthusiast. My eecolor box is special or what?
daewoo is offline
post #63 of 496 Old 03-14-2013, 11:18 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Steve
Yes, but the issue is he is impling that it is a 65x65x65 device, when it is not. And no amount of contacting EE is going to fix it. You don't think we contacted them about it as well? We've been working with EE for well over a year. The box is 64^3 with uncalibrated maximum points and we've been told that it is going to stay that way.
All the LUTs are text files, if you crack them open you see that there are only 64^3 lines (262,144).
The point is he came into the thread, made statements that are technically inaccurate and called me out as being incorrect, when all the technical data clearly supports what I was trying to add to the thread. You'll have to excuse be for being upset when I add factual information to a thread and get falsely called out by a competitor who has absolutely no data to support their assertion.
ConnecTEDDD likes this.
sotti is offline
post #64 of 496 Old 03-14-2013, 11:32 AM
turbe's Avatar
Liked: 97
for those not familiar with using the Window's console, you can type the following in your command prompt to get the count:
findstr /R /N "^" filename.txt
EDIT: I checked the LUT files produced by CM and LS with this, Buzz provided me the LS file..
CM: 262144
LS: 274625
ControlCAL™
turbe is offline
post #65 of 496 Old 03-14-2013, 11:40 AM
turbe's Avatar
Liked: 97
Originally Posted by daewoo View Post
Hi
It's a Licensing quirk in the current version of CME, see Here
ControlCAL™
turbe is offline
post #66 of 496 Old 03-21-2013, 08:52 PM
daewoo's Avatar
hi,
could someone please send me his EDID data of eecolor box, i think mine is corrupt because the audio is stuck in 2.0 as you can see below:
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
to do it you can use the prog Monitor Asset Manager (http://www.entechtaiwan.com/util/moninfo.shtm) it will save the data so i can make a driver to override the EDID information.
thanks
daewoo is offline
post #67 of 496 Old 03-22-2013, 02:40 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
yes, I noticed mine would not pass DD as well, great if it could be fixed
my box info:
zoyd is offline
post #68 of 496 Old 03-22-2013, 02:43 AM
daewoo's Avatar
mine worked correctly 4 days before i have this problem, i have manage to correct this in using the edid of my receiver and it 's works but i wanted the original EDID.
daewoo is offline
post #69 of 496 Old 03-22-2013, 02:56 AM - Thread Starter
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2439
Entertainment Experience Technical Support (dealers and consumers) – Support@eeColor.com or (585) 662-8956
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #70 of 496 Old 03-22-2013, 03:01 AM
daewoo's Avatar
i have already contacted them by email 2 week ago, they have send the prob to their manufacturer for a solution
daewoo is offline
post #71 of 496 Old 03-26-2013, 05:56 AM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
Steve
How do you overcome the fact that the 255/1023 points are anchored in hardware and are therefore nonadjustable?
Perhaps by using the usual technique for dealing with cLUTs - ie. setting input curves to scale the cLUT input range so that only the lower 64^3 grid nodes are used.
gwgill is offline
post #72 of 496 Old 03-26-2013, 08:39 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
We just did exactly that for one of our bigger clients.
The fact is the issue exists and requires a special workaround. Regardless of what Mr. Shaw implied earlier in the thread. The box does not support 65^3 cubes.
sotti is offline
post #73 of 496 Old 03-26-2013, 09:51 AM
DigitalFilm's Avatar
Having read his posts I think you will find 'Mr. Shaw' knew exactly what he was saying...
DigitalFilm is offline
post #74 of 496 Old 03-26-2013, 10:13 AM
10k
10k's Avatar
Quoted: 1897 Post(s)
Liked: 2146
my box info:
Is this true for everyone or is something just screwed up w/ Zoyd's box? That is pretty much a showstopper if you cant passthru all audio formats...
10k is offline
post #75 of 496 Old 03-26-2013, 10:46 AM
zoyd's Avatar
Liked: 1064
I called as well and it has been confirmed by the factory and working on solution.
zoyd is offline
post #76 of 496 Old 03-26-2013, 06:02 PM - Thread Starter
buzzard767's Avatar
Liked: 2439
From a fellow LightSpace beta tester:
HDMI test setup: QD780 <--> eeColor Box <--> Denon 4810ci receiver <--> Sony xbr55hx929 TV.
This is what I found out today:
CEC tests indicated that eeColor box says it "only" supports FR and FL audio spkrs ... this
might be the problem ... eeColor Box should also include other audio formats in its CEC
information ... like Dolby 5.1 and DTS-ES 6.1 ... which was confirmed to work. Otherwise,
the other boxes assume only Stereo is available and won't even look to see if other
audio formats are available.
Background: This all has to do with Vesa's Hot Plug Connect. At power up or upon a cable "hot" connection,
each box communicates to all other upstream and downstream Vesa compliant boxes what its
capabilities are. So, if the eeColor box only includes "audio FR, FL" and does not list Dolby 5.1
and DTS-ES 6.1 as part of its CEC info, this is interpreted by other Vesa Compliant devices as
"not being able to do it". In otherwords, because eeColor box only lists "audio FR, FL",
all other HDMI connected boxes assume "stereo only mode" ... so they don't even bother to
check for Dolby 5.1 and DTS-ES6.1 audio formats. I suggest checking all the audio formats and see which ones work then include those
formats as part of eeColor box's CEC infomation. Again, this is what the data is telling me.
Buzz
post #77 of 496 Old 03-26-2013, 06:28 PM
praz's Avatar
Liked: 26
If the eeColor was after the AVR this should be a non-issue.
praz is offline
post #78 of 496 Old 03-27-2013, 02:40 PM - Thread Starter
buzzard767's Avatar
Liked: 2439
1st run - Samsung F8000 LED. Set 100% White only, Color Space Native. Pretty good TV right from the factory but now it's a lot better. Presently watching phenomenal skin tones in Braveheart.
17 point profile - 1.5 hours. Asked for 2.25 Gamma for the LUT. Edit: Oops, forgot to put 2.25 as the target - dE would have been lower.
Buzz
post #79 of 496 Old 03-27-2013, 02:43 PM
turbe's Avatar
Liked: 97
You didn't mention this unless I am blind..
Did you profile/create the LUT with LS and then just use CM for the reporting you posted above?
ControlCAL™
turbe is offline
post #80 of 496 Old 03-27-2013, 02:53 PM - Thread Starter
buzzard767's Avatar
Liked: 2439
Yeah and I think I profiled at 75% lum which makes blue difficult for the i1Pro. I know I did that in ChromaPure which I believe explains the blue lum in this attachment. Other than that, though, really good.
F8000 2.25 LUT AdvancedColorManagementReport.pdf 1627k .pdf file
File Type: pdf F8000 2.25 LUT AdvancedColorManagementReport.pdf (1.59 MB, 155 views)
Buzz
post #81 of 496 Old 03-29-2013, 04:39 AM
That does seem to show the benefits of a full 17^3 profile and calibration - I especially like the comment about skin tones as that has come up before as a potential issue with calibration granularity.
And 1.5 hours for a 17^3 profile is very fast! Much faster than is being discussed elsewhere eek.gif
post #82 of 496 Old 03-29-2013, 08:34 AM
Nudgiator's Avatar
Quoted: 34 Post(s)
Liked: 37
That's the advantage of PROFILING and CALIBRATING in two steps without read / correct / validate. I also like to press a button in order to generate different 3D-LUTs in 5 seconds instead of 10+ hours.
Source: Samsung UBD-K8500 (UHD), Panasonic BDT-110 (BD), Toshiba HD-XE1 (HD-DVD), Vantage VT-1S (SAT), Kathrein UFS-924 (SAT)
Calibration: LightSpace CMS, SpaceMan, SpaceMatch, CalMAN 5 Prof., Chroma Pure, Lumagen Radiance Pro 4446, Chroma 5, SpectraCal C6, EODIS3, i1 pro 2, Klein K10-A
Target: Panasonic TX-P65VTW60 (Plasma TV)
Sound: Yamaha RX-V2067 (AVR), Teufel Theater LT 3 (Speaker)
Nudgiator is offline
post #83 of 496 Old 03-29-2013, 08:43 AM
visca blaugrana's Avatar
please correct me if im wrong, just trying to under stand this.
when doing it in LS you read all the patches and then based on that you add a correction matrix on top of that, this matrix is solely based on how the calculation algorithm in the software works?
if this is the case is there no validation of the matrix?
visca blaugrana is offline
post #84 of 496 Old 03-29-2013, 08:47 AM
zoyd's Avatar
Liked: 1064
It probably has some noise filtering checks but basically that's correct. LightSpace does not care about deltaE, all it does is calculate the change in RGB for each node point required to match the measurement to Rec709. Any objective validation (in the dE sense) must be done by the user. ArgyllCMS uses the same methodology. CalMAN optimizes it's cube based on dE calculations.
zoyd is offline
post #85 of 496 Old 03-29-2013, 09:06 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Thar's not strictly true.
All dE is used for in our algorithms is for when to sign off for a point being good enough. When looking at how much adjustment any given point needs you need to be in RGB space.
sotti is offline
post #86 of 496 Old 03-29-2013, 09:08 AM
this bring up the question. how do you know the calculated offset is correct? on a display with a bad linearity could such assumptions not be wrong? or does the fact that there are so many points remove this uncertainty?
post #87 of 496 Old 03-29-2013, 09:32 AM
zoyd's Avatar
Liked: 1064
I phrased that poorly, your final product does benefit from minimizing dE though.
zoyd is offline
post #88 of 496 Old 03-29-2013, 09:33 AM
zoyd's Avatar
Liked: 1064
It's just math. It's the same technique used to create a colorimeter matrix against a spectrometer.
zoyd is offline
post #89 of 496 Old 03-29-2013, 09:37 AM
Light Illusion's Avatar
Quoted: 512 Post(s)
Liked: 815
I will answer this, as it is a very important question.
The colour engine in LightSpace is not like other calibration systems, in that each point is not treated in isolation.
True 3-dimensional mathematics is used to assess all 4913 points simultaneously, and assess the linearity of the display before any point is corrected.
This results in different corrections being applied to each and every point, based on the accuracy/linearity for each specific point.
There is no guess-work involved at all - each individual point is accurately calculates as to the off-set required to correct it specifically.
This is also why we recommend full cube profiling for displays with poor linearity, as a Quick Profile lacks the internal colour space volume (points within the cube profile) to be able to accurately define the display linearity, or lack of, when calculating the matrix offset for each and every individual point in the calibration LUT.
Does that help?
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #90 of 496 Old 03-29-2013, 09:47 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
What do you mean their is no guess work involved?
None of the points you measure are your output values, so every single entry in your LUT is guesswork.
It might be a very good, well informed guess, but your output LUT is pure interpolation derived from input data.
If two different process take input data and generate output data, using algorithms to predict the results, their either both are guesswork or neither of them are guesswork.
sotti is offline
Reply Display Calibration
