[Help] Panasonic Viera Dual Monitor Colour Issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-04-2013, 12:59 PM - Thread Starter
doctordarken's Avatar
Hi. I recently set-up a new dual monitor system using a Phillips 21.5" monitor and a Panasonic Viera 32" inch TV. I connected the TV using an HDMI cable, and the monitor using a VGA cable. For some reason the colours on the TV are dark and over saturated. I don't know what to do to fix this. I've tried adjusting the colours using the catalyst control center; as I am using a Radeon HD 7850, but I couldn't get the colours to work. I've heard about colour spaces, but I couldn't find any settings like that. If anyone has any ideas to fix this over saturation and dark colours problem please help.
doctordarken is offline
post #2 of 5 Old 03-04-2013, 03:37 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
You'll need to adjust the colors in the actual displays.
In order to do this correctly you'll need software and a meter.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 5 Old 03-04-2013, 03:45 PM - Thread Starter
What software, and meter would you recommend?
post #4 of 5 Old 03-04-2013, 09:37 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Well I"m quite partial to CalMAN, but that's because I write quite a bit of the software.
There are a lot of different packages and different meters out there.
I would probably only look at X-Rite Hardware in the <$1000 price range.
The current perfomance stair step would be
i1 Display 2 -> colormunki smile (no 3rd party software support) -> C3 (custom SpectraCal smile)-> i1 Display Pro -> C6 (custom SpectraCal i1 Display Pro)
An i1 Display Pro and an i1 Display 2 both work with quite a few different software packages, including free ones. The free softwares have quite a bit of a learning curve, but hey they are free. Software like CalMAN will hold your hand through the process and can even have specific Workflows for matching multiple monitors (depending on your license level). CalMAN was designed to calibrate both Home Theater displays as well as PCs. Feel free to download a trial version if you want to play with it.
Joel Barsotti
SpectraCal
sotti is offline
post #5 of 5 Old 03-05-2013, 02:00 AM
Light Illusion's Avatar
Quoted: 324 Post(s)
Liked: 628
I'm still waiting for the information on the touch-pad type.
I also need instructions on removing the rear cover from the Ultrabook.
There appears to be some trick to it.
Actually, I would look at the basICColor DISCUS as well. A very good probe at that price point.
There are a lot of software options out there as well - and some of the free ones are very good, with this forum supplying a lot of support.
If you want professional level you could look at LightSpace CMS too - but it is a league above other systems, and really aimed at high-end professionals.
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
Reply Display Calibration
