Skin tone test patches or RGB to xyY? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-09-2013, 06:03 AM - Thread Starter
Quad5Ny's Avatar
Quoted: 47 Post(s)
Liked: 34
Does anyone know of some good colors (8-bit, 0-255 or 16-235) and their CIE xy counterparts to tweak skin tone tint/saturation with?
I could make my own but I'm unsure of how to convert a PC palate to xy correctly (and each of the online calculators are giving me different results).
Quad5Ny is offline
post #2 of 3 Old 03-09-2013, 08:10 AM
visca blaugrana's Avatar
I will suggest you use the spreadsheat Zoyd developed for GCD and then use the GCD disk.
in the color checker part there is 2 skin patterns, light and dark skin.
What control on the display are you planing on setting? and what display are you using?
visca blaugrana is offline
post #3 of 3 Old 03-10-2013, 03:30 PM - Thread Starter
Quad5Ny's Avatar
Quoted: 47 Post(s)
Liked: 34
That's exactly what I needed, thanks visca.
Oh and I'm adjusting M_Skin_Sat and M_Skin_Hue on a Samsung EH series display. I originally centered the values when I did the grayscale and CMS (it was set really red to offset the 9300k color temperature rolleyes.gif), but now I am curious to see if tweaking it will make any real visual difference.
Quad5Ny is offline
Reply Display Calibration
