eeColor Processor - CalMAN - 3D LUTs - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 114Likes
Old 04-24-2013, 06:11 PM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 850
Originally Posted by ConnecTEDDD View Post
Hey SS, the results that counts to check/compare any LUT are the Grayscale/Saturation etc. Charts of the Final LUT Loaded @ eeColor.
Other charts of Virtual Cube Generator etc are useless at this point. Use eeColor connected at Unity LUT while performing AutoCal.
Hello Ted.
Check also Grayscale/Color Ramps / Clipping Patterns for any problem with the LUT loaded.
Yes the last LUT I ran with 21 point GS is using eecolor, however the two problems I am seeing is when using the Mini as a pattern generator and its 21 step grayscale pattern, there are some small hint's of color at a few of the steps. Also using S&M disc it seems to show color clipping, of-course this could be caused by my Oppo 95, however the color clipping never showed up when I used the Mini as the processor for a 125 LUT/21 GS.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
Old 04-24-2013, 06:35 PM - Thread Starter
buzzard767's Avatar
Quoted: 1621 Post(s)
Liked: 2395
Pardon my ignorance but does the S&M clipping for those tiny inside squares equal 235 or 255?
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is online now
Old 04-24-2013, 08:09 PM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 850
Come on Buzz you know what it means, 255.
All I am saying is comparing the results of a Lumagen Radiance 3D to eecolor and a LUT calibration. I am not saying there is a problem only trying to lessen the effect in those squares .
ss
Old 04-24-2013, 08:46 PM
Iron Mike's Avatar
Quoted: 64 Post(s)
Liked: 408
Originally Posted by sillysally View Post
Ted as you know I ran a 21 step RGB balance with a 3375 LUT, however to be able to run a 21 point grayscale/RGB you do need (I am sure you know this) to have the eecolor in your video loop when calibrating. I am not sure if having the eecolor in the video loop is the best way to go, and therefor keeping the eecolor out of the video loop and doing a ruff 10 point grayscale or even a 2 point GS using the display controls in my VT50 maybe the better way to go.
ss
u need to have the eeColor in your chain at all times... we found a very tiny distortion with brightness, so you need to setup your display (brightness / contrast / etc) with the eeColor in the chain (with a UNITY LUT)...
- M
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
Old 04-24-2013, 09:15 PM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 850
- M
Thanks Mike, as usual from you that is what I needed to know.
ss
Old 04-24-2013, 10:08 PM
Iron Mike's Avatar
Quoted: 64 Post(s)
Liked: 408
ss
If I remember correctly, on the VT50 it comes down to one click difference in brightness - that might differ on other TV sets.
- M
Old 04-24-2013, 11:58 PM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 850
- M
Yes I have dropped brightness down one click from non eecolor use. But still its something more than just that for my video chain, all be it part of the solution.
On the bright side, I am not really seeing any more motion jitter / stuttering on my VT50, after I started using eecolor and the larger LUT's.
I didn't reply to your post about this because I didn't do extensive testing, It just happen, and I use 24p direct in at 96Hz and source direct on my Oppo for Blu Rays. .
ss
Old 04-25-2013, 02:13 AM
ConnecTEDDD's Avatar
Quoted: 1077 Post(s)
Liked: 1544
anta1974 likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
Old 04-25-2013, 04:09 AM
Iron Mike's Avatar
Quoted: 64 Post(s)
Liked: 408
ss
yeah same here... need to do some testing to see if any of the LUT boxes introduce or boost motion jitter... I did experience it on the eeColor... will report back...
- M
Old 04-25-2013, 05:35 AM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 850
- M
When I used my Radiance Mini 3D and a 125 point LUT I did get a little jitter and motion blur, but not with a 3375 LUT using eecolor, at-least not yet. I calibrate the same way for both the Mini and eecolor, no enhancements and 96Hz. As you may know I use calman. and there 1:1 mapping software in the eecolor.
I would say it could be that are VT50's handle jitter/.motion blur differently except for what i saw using my Mini.
iow I don't have a clue to why the jitter/.motion blur seems to be gone now, I am just guessing.
btw, I only use the VT50 for Blu Ray's.
Looking forward to your report.
ss
Old 04-25-2013, 09:16 AM
DrFaxe's Avatar
Quoted: 14 Post(s)
Liked: 84
- M
You may already know, but the VT50 has a precision regulator for brightness in the service menu, named SUB-BRT. I always use it to fine tune the brightness setting on my TV.
DrFaxe is offline
Old 04-25-2013, 10:18 AM
eghill1125's Avatar
That is something I have not seem much talked about. I also have access in the SM to Sub Contrast and Sub Bright, but never really knew how to use these to my advantage. On my set up now, I have brightness at the default of 50 as that gives me the best on screen material look compared to 51 when watching blu-rays. But this also does show that I am only seeing 19 on the black clipping screen ( possibly 18 a little )
If I raise my brightness to 51, I then can see 17 flash a bit, but the real world pictures look a little washed out and not as good. I think from what I am seeing on the AVSHD disk, that 51 is the correct setting, if I could make it a bit darker than it is, but not quite as dark as 50 would be.
Is there any how to's on what patterns to use and things to look for when adhusting the subs in the SM?
Ed
PSN - eghill1125
eghill1125 is offline
Old 04-28-2013, 12:19 AM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 850
Just finished a 3375 LUT, took about 3 hours 20 min, 6600+ reads. Starting to get a feel for the larger LUT.
ss
Old 04-29-2013, 03:12 AM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 850
This is done using quick checker and about 24 hours after i ran the above calibration. The only difference is I forgot to turn on reference mode for my Mini when I ran QC, but my mini has no calibrations in it
ss
Old 04-29-2013, 05:12 AM - Thread Starter
buzzard767's Avatar
Liked: 2395
Nice results.
If I remember correctly, even if you have calibrations in the Radiance, you can do a factory reset and get reference patterns even though the pattern has an A instead of an R. Then, as long as you don't do the Save function, recycle the Radiance power and the original settings will be there.
Buzz
Old 04-29-2013, 06:59 AM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 850
Nice results.
Thanks Buzz,
Yes that is what should happen with reset, but I am not sure about the patterns. And then there is the output settings to consider, but the output settings (4:4:4,:709 1080P@24), where the same for the calibration and the QA.
Anyway I have everything backed up on my HD just encase, using the Radiance's back up tool.
ss
Old 05-16-2013, 12:18 AM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
I haven't posted here in a bit. I recently just performed another 3375pt cube on my Kuro. I used a c6 profiled against a colormunki spectro. I used the latest CalMan load. The results came out pretty good.....
1forsnow is offline
Old 05-16-2013, 06:59 AM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 850
On the charts it sure looks a lot better than the 17^3 (4913) profile I just ran using Lightspace.
btw your 4 hour time using your meters is pretty good.
ss
Old 05-16-2013, 07:23 AM
derekjsmith's Avatar
Liked: 116
ss
How does the ColorChecker SG measure on the LS 17^3 cube?
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
Old 05-16-2013, 07:45 AM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 850
Not sure what you are asking.
I use CMB 5 (latest beta) to run the test, after I have installed the LUT in eecolor that I just made using LS. I use the Klein still at the same placement that it was at for the 17^3 profile.
Use the Mini 3D in reference mode for the patterns, then via a 6' HDMI cable out to the eecolor set at LUT 3 (That's where the newly made LUT was sent to from TurVue software).
So everything is done the same, except I used a different laptop to run CM's ColorChecker using Teds charts.
btw, I had my VT50 set to color space wide and used 2.4 for the Gamma setting, I did the 17^3 profile in LS and after the profile was done and I made the LUT I set it at 2.16 Gamma.
ss
Added.
If you want to see what QC looks like on a 17^3 LS LUT here is a link. http://www.avsforum.com/t/1437739/lightspace-cms-now-supports-lumagen-eecolor-3d-lut-4-all/180#post_23295202
The differences here are that when I made the LUT in LS I use a 2.2 Gamma setting, but I used the same 2.4 Gamma setting.
The other difference is I used a small window in that profile (link).
Old 05-16-2013, 07:55 AM
Liked: 116
ss
when using ColorChecker in CalMAN change the points measured to SG with 100% sats and without black. This will measure over 100 points with 14 flesh tones.
Derek
Old 05-16-2013, 08:29 AM
Liked: 1544
ss
He used C6 with 1 Sample per read whats why the total time is reduced.
When I was using C6 with my KURO, to get acceptable repeatability (not dE repeatability but xyY repeatability) I was using C6 with 5 Samples as a mimimum and LLH @ 10 Samples per read for measurements below 30 cd/m2, after tons of testing to my setup. I'm talking for November-December 2012 Builds of CalMAN.
Old 05-16-2013, 09:15 AM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
you are correct Ted, i used 1 sample. But take a look at my screenshots below. Why would i use more samples? IMO, its near a point that it starts to become a waste of time. The difference between 1 sample and 20 samples is still WELL below the visual threshold(at least in my experiences) and i would never see the difference in moving content.
1forsnow is offline
Old 05-16-2013, 10:50 AM
Liked: 1544
I will come back with more data's when I will have the time.
C6's response is not the same with 1 Sample measuring samething with 10cdm/2 vs. 20 cd/m2 vs. 90 cd/m2 etc....
The differencies are larger in xyY. Ok it small difference for our eyes but thats why we got the meters, to measure these small differencies better wink.gif
More Stable Measurements will give you more accurate calculated corrections, we are talking about 3375 corrections.
Old 05-16-2013, 11:52 AM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
hmmm ok, fair enough. Even if there are larger xyY differences between the samples, i still don't think the differences will be large enough to make any sort of visual difference with content. Yes, i'm sure more samples will give me better CalMan charts, but the added time just doesn't make sense to me. I can see if the dE differences between the points i measured were larger, i might try a different sampling. But it just doesn't make sense to be. All IMO, of course......
i would love to see your xyY differences when you have more time.
1forsnow is offline
Old 05-16-2013, 12:16 PM
Liked: 1544
I have plans to make a C6 vs. iD3 OEM repeatability/speed comparison, but not have enought free time to measure 4-5 different technology displays since i have daily access to over 100 different models @ my work wink.gif
Old 05-16-2013, 12:22 PM
PE06MCG's Avatar
Liked: 51
@1forsnow
Seems to me you have got the best of both worlds, a great PQ verified by almost perfect dE Charts.
Not certain of the history but surely dE values were introduced as a measurement of the 'fit for purpose' use of the Display?
Certainly we can find the meters that are more and more accurate but have we got Displays that are good enough to constantly output that extremely accurate calibration?
PE06MCG is offline
Old 07-08-2013, 03:39 PM
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
Originally Posted by sotti View Post
A Sharp Elite is a totally different animal, so it definitely depends on the design of the CMS, but for 3D LUTs, all changes remain local to their area of effect.
Joel,
Can you elaborate on the above statement please?
avsform1 is offline
Old 07-08-2013, 05:17 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Originally Posted by avsform1 View Post
Joel,
With brightness and contrast at default a 40% stim pattern lines up with the 40% control.
The effect or width of any of the grayscale controls is roughly 20%, for the 40% control by default it would be from 30% to 50% exclusive of the endpoints. When you change brightness and contrast, the center point of the 40% control moves. Now it's maybe 42% or maybe 37%. So as the control points shift around they are not longer discrete adjustments, so when you adjust 40% you need to recheck 30% and 50%.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 09-07-2013, 09:14 AM
ACappo's Avatar
Quoted: 47 Post(s)
Liked: 45
since the eecolor box only support HDMI 1.3 ie no 3D no UHD, how long would you think it is before its totaly outdated?
I dont use 3D and dont think I have any plans of it, not within the next few years anyway,
I guess what im asking is it a waste to go and get it now, or would you wait to an updated version is on the market? baring in mind im on a budget.
ACappo is offline
