eeColor Processor - CalMAN - 3D LUTs - Page 20 - AVS Forum
 2Likes
Old 12-30-2014, 06:37 PM
Quoted: 253 Post(s)
Liked: 228
In the display tab where you can select the eecolor processor, there is an option taht reads "Full DDC Reset"
Is this intended to mean all 6 memory channels or just the one you have selected in the "Selected 3D LUT"?
When retargeting a previous characterization to go into a used LUTs memory, should you reset it first or will the program overwrite it without any problems?
Samsung 64F8500, Panasonic 65VT50, Oppo 95, Tivo Roamio for OTA, Dish VIP722, Marantz AV8801 preamp, Rotel Amps, Atlantic Tech 8200 speakers, Seaton Submersive HP, Calman 5, Chromapure, Accupel DVG-5000, VideoForge HDMI II, i1Display3pro, i1pro2, eecolor colorbox.
JimP is offline
Old 12-30-2014, 11:53 PM
sotti's Avatar
Quoted: 57 Post(s)
Liked: 178
It only clears the selected 3D LUT and both 1D LUTs.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is online now
Old 01-01-2015, 05:56 AM
Quoted: 253 Post(s)
Liked: 228
I noticed that on one of the screens when you go to run 3D LUTs, you're giving an option as to take white to 255 or 235 with the default being 255.
When you retarget a previous characterization it only shows the fixed setting of 235. So even if you used the same targets, your original LUTs will go up to 255 and the second one with the same targets would only go to 235. Is this correct? Or do you get around this by doing a 1D LUTs that does go above 235?
From a previous post... When retargeting a previous characterization to go into a used LUTs memory, should you reset it first or will the program overwrite it without any problems?
JimP is offline
Old 01-01-2015, 12:45 PM
sotti's Avatar
Quoted: 57 Post(s)
Liked: 178
That's not exactly right. When we run the profiling pass, you set what you want to measure, up to 235 or up to 255. Then whenever we write the LUT we take the profiling pass and if it doesn't go up to 255, we interpolate the levels from 235 up to 255 so we can write the full LUT.
Retargeting overwrites the existing LUT.
Joel Barsotti
SpectraCal
sotti is online now
