eeColor Processor - CalMAN - 3D LUTs - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #601 of 621 Old 05-29-2015, 01:06 PM
sspears's Avatar
Quoted: 57 Post(s)
Liked: 100
Originally Posted by sillysally
The APL settings in Calman don't work for madTPG. Only window size.
Can you tell me in what way it is not working for you? We are not aware of any issues with the APL patterns in madTPG. If it is not working, it would be a bug.
sspears is offline
post #602 of 621 Old 05-29-2015, 02:13 PM
sillysally's Avatar
Quoted: 423 Post(s)
Liked: 471
The window sizing works just fine, its the background APL. In madTPG there are three different APL backgrounds, those don't work in the official release of CM. I use split screen, on my PC is the desktop, on my display is madTPG.
There may be some benefit using the "APL Linear" background when calibrating a LG OLED 65EG9600. Because of how the EG9600 has a static ABL or ASBL.
ss
sillysally is offline
post #603 of 621 Old 05-29-2015, 02:15 PM
Zimbalo's Avatar
Quoted: 44 Post(s)
Liked: 274
I confirm problems with APL settings.
sillysally likes this.
Plasma TV: Pioneer Kuro KRP-500A - Pioneer Kuro LX-508D - Panasonic TX-P50VT30E
Sources: Oppo BDP-93 - Popcorn Hour A210 - Video Processor: TruVue eeColor
Probe: i1Display Pro profiled by JETI Specbos 1211-L - Software: Calman 5 Enthusiast
Zimbalo is offline
post #604 of 621 Old 05-29-2015, 02:22 PM
sillysally's Avatar
Quoted: 423 Post(s)
Liked: 471
Originally Posted by BlackJoker View Post
Sorry I don't meant that for madTPG.
First I want to use CM Pattern for my first steps with the eecolor.
And I want to know which APL level I have to set up for my VT60.
The pattern size will be 6%
If you are going to use a background, constant gray of 20 or 25% should be ok.
I never used a background APL when calibrating my VT60, mainly because you probably will get better meter reads if you don't use onscreen for your meter placement.
The bigger the area to a point the meter reads, the more information your meter has about the color.
ss
post #605 of 621 Old 05-29-2015, 04:12 PM
sspears's Avatar
Quoted: 57 Post(s)
Liked: 100
In what way is it not working for you?
I just tested madTPG and constant APL and it is working as expected. If you can tell me how it is not working, that would help. I compared a constant APL 18% to a user defined (Pattern Size = 10 and Pattern APL = 18) and the two match. For a Window at level 16, the background is 60 and the window is 16. For a 235 window, the background is 35 and the window is 235.
Also tried the yellow window from the color checker page. It has a purple-like background vs. black on a normal window.
sspears is offline
post #606 of 621 Old 05-29-2015, 06:16 PM
zoyd's Avatar
Quoted: 955 Post(s)
Liked: 808
linear and gamma light APLs are working as expected but if you choose "constant gray" in the madTPG window, CM patterns always show a black background.
Zimbalo likes this.
zoyd is online now
post #607 of 621 Old 05-31-2015, 10:47 PM
Quoted: 14 Post(s)
Liked: 0
I try it again when I use 6% CM Pattern how I set the APL Level for my VT60? Also 6%?
BlackJoker is offline
post #608 of 621 Old 06-01-2015, 10:06 AM
sotti's Avatar
Quoted: 131 Post(s)
Liked: 220
Typically you want a higher APL. Most content varies between 10-30% on average. You probably want to pick a number based on the content you primarily watch. I'd go in the 12-15% for darker shows and the 20-25% range for brighter content.
The difference between higher and lower APL calibrations are more subtle than moving from variable APL to constant APL.
anta1974 likes this.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #609 of 621 Old 06-01-2015, 11:55 AM
sillysally's Avatar
Quoted: 423 Post(s)
Liked: 471
The problem with the VT60 is the white level keeps shifting, usually it keeps dropping slightly each time it shifts when measuring a white window .
So unless Calman has a setting like argyll for white point drift there is not much of a benefit using a APL background..
ss
post #610 of 621 Old 06-07-2015, 02:24 PM
Quoted: 14 Post(s)
Liked: 0
Did anyone know how I can improve my result in combination with an VT60 and a d3 sensor? My first calibration with the latest beta of calman which ss posted and the eecolor we're awful I got an dE of 5.
Did I have to calibrate greyscale and gamma before I create the lut? For some testing I created a quick profile with 879 reads
post #611 of 621 Old 06-07-2015, 08:07 PM
sotti's Avatar
Quoted: 131 Post(s)
Liked: 220
So calibrate the grayscale, but try and leave the gamut as wide as possible.
For Plasma you really need at least 3000 reads.
Joel Barsotti
SpectraCal
sotti is offline
post #612 of 621 Old 06-07-2015, 09:38 PM
Quoted: 14 Post(s)
Liked: 0
Before I start did I have do to a ddc reset of the eecolor over calman? So I calibrate the greyscale with active eecolor one of the 6 memory spaces active right?
How I get better results with time or point based lut?
post #613 of 621 Old 06-07-2015, 10:31 PM
sotti's Avatar
Quoted: 131 Post(s)
Liked: 220
Make sure you've reset the eeColor inside CalMAN, It should do it for you, but doing it manually will make sure. While the eeColor is transparent for the most part doing the calibration with it inline makes the most sense.
Point based gives you the best control. For a plasma 3000-3500 points is the knee where additional points start yielding very small gains in performance. Going from 3000 to 5000 reads gets you about the same increment more performance as going from 2500 to 3000.
Most people see the best results when they've done some level of optimizations inside the display. So while you don't need to do a full calibration in the plasma, at least get the cuts and gains dialed in and make sure the gamut is as wide as possible before starting.
Lastly in terms of range, make sure either your plasma isn't clipping up to 255, or make sure that you limit the profile range to 235.
Joel Barsotti
SpectraCal
sotti is offline
post #614 of 621 Old 06-07-2015, 11:18 PM
Quoted: 14 Post(s)
Liked: 0
Thx sotti for the informations I'am realy confused and I'm sure that I do some mistakes ..
I set the Gammut of the TV to native so the box have some room to work.
Buzz said in his first post that we don't have to use the DDC Reset?
Did I get this right I only try to get a good wight balance with cuts and gains and do not calibrate RGB and Gamma before? Is the colorbox doing this for me?
Can please someone help me out this thing makes me crazy here are my following steps please correct me if something is wrong:
1. connect PC with eecolor HDMI Input and HDMI Output with VT60 (1920*1080@24hz)
2. Load Profile 1 on the eecolor and run a DDC Reset
2. Using CalMAN as pattern generator (Size 11% and 18% APL)
3. Video Levels 16-235 and Target Gamma 2.20 - REC709
4. Whitbalance with guts and gains at 30 and 100 IRE
5. No manually RGB and Gamma calibration
6. Autocal 3D LUT with 4000 Points
I'm using the latest CalMAN beta and a d3 profiled against an i1pro2
post #615 of 621 Old 06-08-2015, 10:16 PM
sotti's Avatar
Quoted: 131 Post(s)
Liked: 220
If you're using 24hz output, make sure the VT60 is in 96hz mode, native 24hz is a little unstable for the d3.
With a PC connected to CalMAN make sure you eiter have the driver correctly configured for full range and uncheck the "expand patterns to PC Levels" box or leave the box checked and run with the driver on RGB limited or YCC mode.
The rest sounds about right.
Joel Barsotti
SpectraCal
sotti is offline
post #616 of 621 Old 06-09-2015, 03:14 AM
Quoted: 596 Post(s)
Liked: 323
I would manually calibrate RGB as close as I can and have the gamma on the VT60 selected to get me 2.2-2.22.
If you've got the time to experiment, try it both ways and notice in the color checker what happens with the grayscale readings and average/max dEs.
Since content is mastered all over the place when it comes to gamma or what they now like to call EOTF, I precalibrate my Samsung plasma to 2.2 (or very close to 2.2) and then run my original LUTs for 2.2. Then I retarget and make a 2.3 and a BT1886. On TV broadcast, I tend to leave it on the 2.3 setting as it has a little more pop without making things look harsh. On movies, if I'm in a picky mood, I'll try all three and settle on the one that looks the best for that movie.
JimP is offline
post #617 of 621 Old 06-09-2015, 03:21 AM
Quoted: 596 Post(s)
Liked: 323
Originally Posted by sotti View Post
With a PC connected to CalMAN make sure you eiter have the driver correctly configured for full range and uncheck the "expand patterns to PC Levels" box ...snip...
Is this only for madVR TPG ?
Do you find any benefit in using madVR over the built in pattern generator?
JimP is offline
post #618 of 621 Old 06-09-2015, 06:29 AM
sotti's Avatar
Quoted: 131 Post(s)
Liked: 220
If you're doing a LUT for madVR then it has the advantage of being able to validate your LUT.
Joel Barsotti
SpectraCal
sotti is offline
post #619 of 621 Old 06-09-2015, 03:03 PM
ConnecTEDDD's Avatar
Quoted: 274 Post(s)
Liked: 714
Hi Jim, since you use eeColor and the 3D LUT correction table will be active to eeColor's memory, the build in pattern generator will have no problem to measure your post-calibration performance.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #620 of 621 Old 06-09-2015, 03:34 PM
sillysally's Avatar
Quoted: 423 Post(s)
Liked: 471
Are you sure the VT60 will stay at 96hz, if using a PC as the pattern generator.
Wouldn't it be best to set your video card to 1080@60hz set at 0-255 and the output set at 16-235 for a VT60 set to legal video (16-235)
I know if using madVR/TPG you would want to set as stated above. You may also have to use madTweaker to force you video card to PC level 0-255.
ss
Last edited by sillysally; 06-09-2015 at 06:07 PM. Reason: Thanks to Teds PM, showing a typo
post #621 of 621 Old Today, 12:04 PM
Liked: 0
Hi All,
I have a few questions regarding the process of creating a LUT and using it successfully on my eeColor/LG 930V OLED TV. So hopefully I'm looking for some advice if possible.
My equipment list is as follows to give you an idea of what I have to work with: -
  • LG 55EC930V OLED 1080p
  • EE Color 3D Cube (not the Spectracal one)
  • i1 Pro
  • i1 Display Pro (Retail)
  • Calman Enthusiast edition v 5.5.0
  • Tesco Hudl 2 android table running Spectracal MobileForge for pattern generation to EEColor
  • IguanaWork IR USB transceiver that I've written a Java program for that simulates 'mute' from the 930V remote control every 30 seconds to suppress the dimming that happens on the 930V with static images
Before I start any kind of calibration or profiling of meters should I first click on Reset DDC for the EEColor to upload the 3D Lut so that the EE Color is basically mapping 1:1 (effectively a bypass) ?
While this is a 930V specific question should I set the TV to be wide gamut and let the EE Color reign in the colors back to D65 Rec HD 709 spec?
When I'm creating a profile (using Raw XYZ) for my i1 Display Pro from the i1Pro should I use 100% primaries or 75% primaries?
Once my i1 Display Pro has the profile should I be looking at fixing up the grey scale IRE points on the TV or should this just be left to the 3D Lut to handle? Additionally should I ignore the gamma tracking and just get the RGB values equal rather than achieving a flat gamma response (calibrating IRE points on 930V is a real pain).
In the Calman session options there is the option for the Luminance Response target with various options. The default is BT 1886: 1, what does the value 1 translate too? Would I be better off just going for Power 2.4?
So far with my experiments I'm getting a bit of posterization with dark colours compared to when the EE Color is in bypass mode. Sorry for so many questions but these are queries that I've not seen answers to in the forums or I've just missed them.
Many thanks
manilala is online now
Reply Display Calibration
