eeColor Processor - CalMAN - 3D LUTs - Page 33 - AVS Forum | Home Theater Discussions And Reviews
 114Likes
post #961 of 968 Old 08-27-2016, 03:33 PM
Liked: 0
Originally Posted by sotti View Post
There is no such thing for a displays as an srgb or an adobe icc profile. You measure the displays native performance and then each application decides how to use the displays capabilities.
In CalMAN there is a checkbox to turn ICC profiles on for the internal pattern window or for client3's patterns
Thanks again, though I am more confused. From the SpectraCal website:
"Unlike any other calibration software on the market, CalMAN Client 3 allows users to create multiple calibration profiles for each monitor. Whether you need one calibration each for two different color standards, such as Rec.709 and DCI/P3, or you want to calibrate a laptop to different lighting environments, CalMAN Client 3 is the tool for the job."
I created one profile for sRGB and one profile for Adobe RGB. As best I can tell these are ICC profiles (as I verified using the ICC Profile Inspector), specifically:
SynchMaster_2_sRGB.icm
SynchMaster_3_Adobe RGB.icm
CalMAN Client 3 allows me to switch between these profiles, as well as selecting uncalibrated. There is also a checkbox for Bypass LUT. Visually, images change as I would expect from the switching of the profiles.
Could you help me find the switch you mentioned? Could you also point me to appropriate documentation so that I do not unnecessarily waste your time? (I have been reading the help.)
Lavcat is offline
post #962 of 968 Old 08-28-2016, 10:11 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
It does store different profiles, but those profiles support multiple DDC settings in the monitor as well as the graphics card 1D LUT. The only gamut volume management is the ICC profile and it is applied per application.
attached pic
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #963 of 968 Unread Yesterday, 09:30 AM
Quoted: 37 Post(s)
Liked: 9
On the first few pages I read that a user calibrated 4913 points with CalMAN I often saw that CM crashes if you go higher than 3500 points.
Has anyone good experience with such high pointed LUT's?
BlackJoker is online now
post #964 of 968 Unread Yesterday, 04:43 PM
WiFi-Spy's Avatar
Quoted: 355 Post(s)
Liked: 675
We run 10,000 point LUT measurements in the office without issues. If you're using a network pattern generator, we highly recommend using ethernet, One hick up in the wireless connection and it will cause an error if you were using a networked pattern generator that isn't directly on the same machine running CalMAN.
Tyler Pruitt - Technical Liaison at SpectraCal
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is online now
post #965 of 968 Unread Yesterday, 05:09 PM
Rayjr's Avatar
Quoted: 175 Post(s)
Liked: 214
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
I have run multiple 10,000 - 8,000 - 6,000 and 4,000 point sessions with no issues.
RayJr
Rayjr is offline
post #966 of 968 Unread Today, 05:25 AM
Quoted: 1394 Post(s)
Liked: 589
I recall having some issues along the way but I think you'll find that the current release and a pretty basic connection should work fine. This thread was started about 4 years ago, so I wouldn't take early post to be relevant to today.
This is not to say that you won't come across other issues relevant to your particular display. If its an OLED, then you have to set adjustments accordingly.
What are you wanting to calibrate? What are you using hardware wise?
JimP is offline
post #967 of 968 Unread Today, 06:40 AM
Quoted: 37 Post(s)
Liked: 9
I'm using the latest CalMAN 2016 build and I want to calibrate my LG 65 E6.
I use a eecolor box and a C6-HDR Meter
post #968 of 968 Unread Today, 06:45 AM
Quoted: 37 Post(s)
Liked: 9
I'm aiming 130 nits and use mobileforge for my pattern and 10% window size. My meter is set up to run 10 samples and the low light handler with 10 samples under 30 cd/m2 is also activated. And I'm using the pattern inseration mode every 10s with 75% stim level for 1s
Reply Display Calibration
