eeColor Processor - CalMAN - 3D LUTs - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 114Likes
post #181 of 968 Old 03-29-2013, 06:20 PM
sillysally's Avatar
Quoted: 834 Post(s)
Liked: 850
Originally Posted by Iron Mike View Post
regarding the bit-depth of processing and output, here's direct info from eeColor:
> 3D LUT algorithm only supports maximum of 10 bits input so the data will be reduced from 12 bits to 10 bits if needed.
> max bit-depth of internal processing: 10 Bits for the 3D LUT.
> max resolution: 1080P is the offical max supported resolution.
> 12 bits HDMI in will be 12 bits HDMI out but will be rescaled to 10 bits for 3D color table processing.
- M
Thanks Mike.
I didn't know that either, and that will cause me to rethink a setting or two.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #182 of 968 Old 03-29-2013, 07:37 PM
Iron Mike's Avatar
Quoted: 64 Post(s)
Liked: 408
Originally Posted by sillysally View Post
Thanks Mike.
ss
I think this is only important for displays that accept 10-bit or higher and the source is 10-bit or higher, e.g. for a color grading workflow...
if the source is 8-bit 4:2:0 (--> Blu-ray) then processing of the 3D LUT is in 10-bit (so smoother gradations for the corrections) but the box might still output 8-bit, since it was an 8-bit source... not sure, I haven't tested, somebody with a QD 780 could test this...
even if the box outputs 10-bit (upsampled) for a 8-bit source, most commercial TV displays (that can only accept 8-bit or less) would clip the extra bits anyways...
- M
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
post #183 of 968 Old 03-30-2013, 04:14 AM
sillysally's Avatar
Quoted: 834 Post(s)
Liked: 850
- M
Yes, I use 4:2:2/source direct for Blu Ray for my source output, I also set my Mini 3D to output 4:2:2 when generating triplets.. So maybe the box may like 4:4:4 better.
I am probably grasping at straws here, but what the heck its always worth a try.
ss
post #184 of 968 Old 03-30-2013, 10:05 AM
DrFaxe's Avatar
Quoted: 14 Post(s)
Liked: 84
please correct me if I'm wrong. The Radiance uses 12bit by default when set to 4:2:2. If eeColor accepts 10bit for input and processing is 10bit too, I would set the Radiance output fixed to 4:2:2 10bit (or maybe 4:4:4 10bit when results are better) to avoid unnecessary conversions/rescalings.
DrFaxe is offline
post #185 of 968 Old 03-30-2013, 11:23 AM
Aaron Inami's Avatar
This was exactly what I was after when I asked the question if the eeColor supports 10/12 bit deep color. This is completely different than 12-bit 4:2:2 (which has been a standard since HDMI 1.1). The Radiance cannot output 10-bit 4:4:4, which is considered a "Deep Color"' mode. It can only output 8-bit 4:4:4. When you set the Radiance to output 4:4:4, the dithering settings are meaningless and are not used at all (unless you dither all the way down to 6 or 7-bits).
I have come to the conclusion that 4:4:4 is the better output mode (even though it's only 8-bit). I believe that the 8-bit per-pixel chrominance accuracy on 4:4:4 is better than the extended 12-bit color depth on 4:2:2 (because 4:2:2 loses chrominance resolution due to shared chrominance for 2 consequtive pixels).
The exception here is if your projector converts everything to 4:2:2 anyways for its internal processing pipeline (which I have heard the JVCs may do). If this is the case, then it's better to output 4:2:2 so that you can take advantage of the 12-bit color depth. For my Sony VW95ES, it's better to send it 4:4:4 because there is motion blur that occurs with 4:2:2 (due to fluctuating chominance values for an object that moves across the screen). This is fixed if you use 4:4:4.
As far as sending Deep Color to the eeColor, there's no point in doing this if you have a Radiance in the mix, since Radiance does not support Deep Color anyways. You could try running your bluray (set to 10-bit deep color) directly to the eeColor, but your going on the assumption that the deinterlacer/scaler in the bluray player is going to be as good as or better than the Radiance at processing the 4:2:0 that's on the disc. This depends entirely on what bluray player you have (and what video processing chip it contains).
Aaron Inami is offline
post #186 of 968 Old 03-30-2013, 11:51 AM
DrFaxe's Avatar
Quoted: 14 Post(s)
Liked: 84
Originally Posted by Aaron Inami View Post
When you set the Radiance to output 4:4:4, the dithering settings are meaningless and are not used at all (unless you dither to 6-bits).
didn't know that. Weird that the Radiance offers this in the menu without having an effect. Thanks a lot for all explanations!
DrFaxe is offline
post #187 of 968 Old 03-30-2013, 01:09 PM
Iron Mike's Avatar
Quoted: 64 Post(s)
Liked: 408
ss
another question is if the Mini - when used as pattern generator - actually uses the settings of the CMS slot u have set up and was last used... it could be it is in a default, neutral state when being used as a pattern generator and NONE of these settings apply - that is likely when R(eference) patterns are used, u'll see a little "R" in the upper right corner...
if there's an "A", it is in adjustable pattern mode and the the LUT sitting in the CMS slot will have affect, not sure again if the settings will have an effect on the test patterns in this mode...
post #188 of 968 Old 03-31-2013, 02:18 PM
Ranger's Avatar
Guys, since Calman supports the eeBox now, all I need to buy is Calman5E, i1Display pro, and eeBox. Is that correct ? Do I need any other hardware/ software ?
Ranger is offline
post #189 of 968 Old 03-31-2013, 04:38 PM
ConnecTEDDD's Avatar
Quoted: 1078 Post(s)
Liked: 1546
A Pattern Generator that can display any RGB Triplet combination.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #190 of 968 Old 03-31-2013, 04:57 PM - Thread Starter
buzzard767's Avatar
Quoted: 1624 Post(s)
Liked: 2398
And that would include Calman internal patterns.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #191 of 968 Old 03-31-2013, 05:06 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
And in the 5.1.1 release the internal pattern gen also has multiple window sizes and APL levels.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #192 of 968 Old 03-31-2013, 05:19 PM
Ranger's Avatar
I don't understand this. With LightSpace CMS I don't need a pattern generator but with Calman5E I do ? I cannot connect directly with laptop's HDMI output or use Ted's calibration disk ? What do I need to spend on a pattern generator ?
Ranger is offline
post #193 of 968 Old 03-31-2013, 05:27 PM
praz's Avatar
Liked: 26
Did you miss posts 190 and 191?
praz is offline
post #194 of 968 Old 03-31-2013, 05:36 PM
Liked: 1546
Ted's LightSpace Calibration Disk can only be used as a Source for LightSpace Users only, for Automated 3D Cubes with a single initial mouse click, not other user prompt.
post #195 of 968 Old 03-31-2013, 05:39 PM
Ranger's Avatar
No, I read them but don't understand as I am new to this. This pattern generator, is it a hardware or software solution I need to buy ?
Ranger is offline
post #196 of 968 Old 03-31-2013, 05:44 PM
Nudgiator's Avatar
Quoted: 31 Post(s)
Liked: 35
CalMAN and LightSpace include a software pattern generator. But you can also use external pattern generators.
Source: Samsung UBD-K8500 (UHD), Panasonic BDT-110 (BD), Toshiba HD-XE1 (HD-DVD), Vantage VT-1S (SAT), Kathrein UFS-924 (SAT)
Calibration: LightSpace CMS, SpaceMan, SpaceMatch, CalMAN 5 Prof., Chroma Pure, Lumagen Radiance Pro 4446, Chroma 5, SpectraCal C6, EODIS3, i1 pro 2, Klein K10-A
Target: JVC-X7000 (Beamer), Panasonic TX-P65VTW60 (Plasma TV)
Sound: Yamaha RX-V2067 (AVR), Teufel Theater LT 3 (Speaker)
Nudgiator is offline
post #197 of 968 Old 03-31-2013, 05:55 PM
Ranger's Avatar
Thanks ! That was my original question. So with a eeBox, Calman Enthusiast, and D3 I can start calibrating immediately and don't need to buy anything else.
Ranger is offline
post #198 of 968 Old 03-31-2013, 06:03 PM
Liked: 1546
Need a tripod also to mount the meter. Good Luck
post #199 of 968 Old 03-31-2013, 06:04 PM
sillysally's Avatar
Quoted: 834 Post(s)
Liked: 850
Good to know.
Because you can back up all your settings/calibrations that are in the Mini, I just simply reset to factory default and set what I want for output.
I try to eliminate any settings I am not sure about.
ss
post #200 of 968 Old 03-31-2013, 07:07 PM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
Joel-
any chance 5% patterns can get added in the future?
1forsnow is offline
post #201 of 968 Old 03-31-2013, 07:09 PM
Nudgiator's Avatar
Quoted: 31 Post(s)
Liked: 35
post #202 of 968 Old 03-31-2013, 08:06 PM
turbe's Avatar
Liked: 95
more horizontal (from display) flexibility
Meter Profiling Kit
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #203 of 968 Old 03-31-2013, 08:16 PM
Nudgiator's Avatar
Quoted: 31 Post(s)
Liked: 35
Oh, my final result "optimization" is:
1. About 48cm forth
2. About 24cm left / right
3. About 24cm upper / lower
That's the 24cm forth version:
post #204 of 968 Old 03-31-2013, 08:40 PM
turbe's Avatar
Liked: 95
hmm, that view looks interesting.. can I see a top view?
it looks like the i1D3 is on the right (from top view) but perhaps may be in the path of the rear, also what are the adjustment ranges?
I do want to say, that pic look so cool..
ControlCAL™
turbe is offline
post #205 of 968 Old 04-01-2013, 12:13 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Originally Posted by 1forsnow View Post
Joel-
Possibly.
The patterns are totally dynamic, so it's just a matter of figuring out how big a list we want to include.
Joel Barsotti
SpectraCal
sotti is offline
post #206 of 968 Old 04-01-2013, 05:16 AM
Nudgiator's Avatar
Quoted: 31 Post(s)
Liked: 35
Yes, the i1D3 is behind the i1 pro 2 (you can see it on the first pic I posted)
The complete construction can be positioned forward for about 24 cm. From this position, both probes can be additionally and independently positioned forward for 24 cm - in sum: 48cm.
Sidewards: 24 cm left and 24 cm right. But, of course, the probe will stay at its place. That's for exact profiling the i1D3 against the i1 pro 2.
Height: I have used a 10 cm macro camera rail. But it's also possible to use a 24 cm macro camera rail.
Oh, complete costs: about 100€ (+ screws etc.). It's especially build for non-contact mode.
post #207 of 968 Old 04-01-2013, 01:40 PM
Nudgiator's Avatar
Quoted: 31 Post(s)
Liked: 35
I have just used the Cal PC Client 2.2.1.18 to have a look at the APL levels. But I can only see: 2, 5, 10, 18, 25, 50 and Full 100%. Where can I find the APL levels ?
Oh, another question: how can I deactivate the autostart of the Cal PC Client when starting Windows 7 ?
post #208 of 968 Old 04-01-2013, 01:59 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
It's not in the client (yet), right now you use the actual built in pattern window. When you're connected to the default manual source, there is a button to open the floating pattern window. When that window is full screen it does all the APL, window sizes.
It's a registry entry.
Probably easiest to run "msconfig" from the start menu to edit the entry.
Joel Barsotti
SpectraCal
sotti is offline
post #209 of 968 Old 04-01-2013, 02:11 PM
Nudgiator's Avatar
Quoted: 31 Post(s)
Liked: 35
Is there a time-line for it ?
Got it !
Got it !
Thx !
post #210 of 968 Old 04-01-2013, 04:57 PM - Thread Starter
buzzard767's Avatar
Liked: 2398
Ctrl Alt Delete - Task Mgr - Processes - disable it there. It'll come back when the PC is restarted.
Buzz
Reply Display Calibration
