BenQ W1070 clipping black, White and Color levels? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 03-14-2013, 06:08 PM - Thread Starter
Tyrone Burton's Avatar
Hi all.
I recently bought myself a BenQ W1070 DLP projector and have had it for about 5 days now. It seems that this projector model clips BTB, WTW and the three R G and B levels when in video mode.
However it doesn't do this at all with 0-255 PC level content, everything is perfect. It's the first time ive seen a projector that doesn't do well with 16-235 video stuff. I am not using an AVR, and my PS3 is my bluray player.
Has anyone else with this particular projector had the same results? I found all this out using the Spears & Munsill disc.
Tyrone Burton is offline
post #2 of 20 Old 03-14-2013, 08:57 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Make sure you PS3 is set up like this and see what it does.. audio not important but the last 2 are.
BD/DVD Upscaler: "Normal"
BD/DVD Video Output Format (HDMI): "Y Pb/Cb Pr/Cr" for TVs, "RGB" for PC Monitors
BD 1080p 24Hz Output: "Automatic"
BD/DVD Dynamic Range Control: "Off"
BD/DVD Audio Output Format (HDMI): "Linear PCM"
BD/DVD Audio Output Format (Optical Digital): "Bitstream"
Display Settings
RGB Full Range (HDMI): "Limited"
Y Pb/Cb Pr/Cr Super-White (HDMI): "On"
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 20 Old 03-14-2013, 09:39 PM - Thread Starter
Display Settings
Thanks for that, but my PS3 settings have always been like that.
post #4 of 20 Old 03-18-2013, 10:34 AM
sigma957's Avatar
Quoted: 18 Post(s)
Liked: 34
When I calibrate my W1070, I find the following:
- When I use the PS3 (YCbCr video), BTB and WTW both appear to be clipped.
- When I use my HTPC (set to RGB Full), I see BTB but not WTW.
- I also find that when adjusting the colors, you can only turn up the saturation a few notches before it doesn't have any effect. (I'm using an i1 Display Pro meter.) I think this indicates that the colors are getting clipped beyond a certain point.
BenQ W1070 | Denon AVR-X4200W | Sony XBR75X940D | LG OLED55E6P | Samsung PN51E7000 Plasma | HTPC
sigma957 is offline
post #5 of 20 Old 03-18-2013, 02:00 PM
Smackrabbit's Avatar
Quoted: 120 Post(s)
Liked: 296
Under the options in the BenQ, you can go to HDMI settings, and set the HDMI input from Auto to PC, and that will stop clipping those levels. BenQ and others like JVC do this for whatever reason.
Chris Heinonen
Staff Writer, The Wirecutter, a NY Times Company
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Secrets of Home Theater and High Fidelity, AnandTech.com, HDGuru.com and Electronic House
Smackrabbit is offline
post #6 of 20 Old 03-18-2013, 03:52 PM - Thread Starter
But that setting I'm sure is for 0-255 content. Should I output the movies in 0-255?, even though there 16-235.
post #7 of 20 Old 03-18-2013, 05:19 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Once you can see everything, you should be able to use brightness and contrast to correctly align for video content.
sotti is offline
post #8 of 20 Old 03-19-2013, 12:16 AM - Thread Starter
Even if I'm outputting 0-255?
post #9 of 20 Old 03-19-2013, 12:20 AM
HDTVChallenged's Avatar
Liked: 215
At the very least, I think you would be able to set up one of the "User" modes for 0-255 and another one for 16-235.
HDTVChallenged is offline
post #10 of 20 Old 03-19-2013, 12:34 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
outputting or inputting?
The trick is it sounds like you are clipping your inputs.
You set the output with brightness and contrast, as long as you can turn brightness up and see to 0, and turn contrast down and see to 254, any adjustment for black level is just a course brightness/contrast setting.
If when you change the setting below 16 is completely clipped, then it's changing the signal on input, and is usually the wrong setting to use.
You always want to accept 0-255, then adjust the output to set the levels at the end.
sotti is offline
post #11 of 20 Old 03-19-2013, 01:02 AM - Thread Starter
Yeah I meant set the projector to accept 0-255 (PC Signal), and have the PS3 set to output RGB full range. Thanks.
I forgot to say, so it doesn't matter if I'm using 0-255 if I properly set the brightness and contrast ect?
post #12 of 20 Old 03-19-2013, 08:11 AM - Thread Starter
Ok, just to test. I set the PS3 to output 0-255 and the projector to accept it and also outputting YCBCR and the clipping still occurs. Idid the same again, this time with RGB...still clipping.
It seems the best thing to do is set everything properly, but I still get the clipping.I'm starting to think I should get a new BD player, maybe the PS3 can't accepth BTB or WTW info, or at least doesn't agree with the projector?
post #13 of 20 Old 03-19-2013, 12:02 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
I you tell the PS3 it's outputting RGB 0-255, it will clip the blu-ray because you need to expand it to match the games. with an output of 0-255 nominal black for games is at 0, so the only way for it to match the blu-ray is to clip the BTB and WTW and expand the range from 16-235 to 0-255.
Why not use the PS3 as it was designed. Leave it in RGB limited for games and use YCC with superwhite on?
It takes a lot more work to fit square pegs into round holes.
sotti is offline
post #14 of 20 Old 03-19-2013, 12:21 PM - Thread Starter
Well video games are created in 0-255 right? And so use 0-255. So I think it's only right to output what it is source 0-255, display 0-255. I don't mind switching between the two. If I'm honest, I never really understood what you said in another thread about older consoles graphics being rendered internally in 0-255.
I guess I'll just ave to accept my projector clips black ,White and RGB channels for movies. It's possible an update could be sent to fix it, as it's updateable.
post #15 of 20 Old 03-19-2013, 12:46 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
OpenGL and DirectX for the most part take the range of 0-1 for their color inputs and the exact bit depth and range is defined at render time.
sotti is offline
post #16 of 20 Old 03-19-2013, 01:15 PM - Thread Starter
I see now yes.
post #17 of 20 Old 02-21-2014, 08:18 AM
Desisuperman's Avatar
Quoted: 33 Post(s)
Don't want to start a new thread but I have a similar question for the same projector regarding the PC Signal option under HDMI options.
For my HTPC, I have Dynamic Range set to Full 0-255, Pixel Format YCBCR 4:2:2
Projector HDMI Settings is set to PC Signal
Does this make sense? Do have it setup correctly ? Thanks in advance for the help smile.gif
Desisuperman is offline
post #18 of 20 Old 03-08-2014, 09:53 AM
Quoted: 33 Post(s)
Anyone?
post #19 of 20 Old 03-08-2014, 10:25 AM
Liked: 215
Not really (for video sources,) but close enough that it will "work."
Surely there's a FAQ around here somewhere. ....
post #20 of 20 Old 05-19-2014, 02:17 PM
Feelingblue74's Avatar
depends on the software you use
If you are under windows best settings are always RGB Full. Never use YCBCR because video driver convert internally to RGB and then to YCBCR again. And it is bad
The only different situation is with PDVD or TMT in direct mode.
For example my HTPC is: MADVR in limited, video driver in RGB Full and w1070 in PC mode.
Only in this way i have BTB and WTW.
Then you regulate VPR to cut BTB and cut WTW (or see bar 254)
however unless you don't calibrate colors individually (hue and gain) my projector clips red and blue (but not white and green)
sorry for my english
Feelingblue74 is offline
Reply Display Calibration
