Mascior's Calibration Disc - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #361 of 387 Old 06-01-2014, 01:26 PM
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Originally Posted by JimP View Post
On the Panasonic VT50, I've found that the 5% APL with 18% surround to work best. With the VT50, using a 5% window pattern at 10% level, the pattern is presented lighter probably having something to do with how the panel' power supply works. That causes corrections to be made to lower it. Switch to a 5% APL pattern and you see a significant difference. It translates into content by either crushing or not crushing darker shades before going into black. Some calibrators will still use a windows pattern yet lower the gamma for 10%.
What do you recommend for the Samsung F8500?
rickardl is online now
post #362 of 387 Old 06-01-2014, 02:21 PM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
Originally Posted by mascior View Post
My disc will work with any software that utilizes a round nearest method and/or software that assumes integer percentages. ChromaPure falls into this category and HCFR can be setup for compatibly. However, I am not sure if CalMAN's engine is adjustable to match my disc's RGB triplet rounding method.
Ryan
That is for patterns at full saturation and CalMAN uses the same rounding assumption. For less then full saturation (saturation sweeps and the ColorChecker) the patterns match what ChromaPure is using.
zoyd is offline
post #363 of 387 Old 06-01-2014, 02:33 PM
Quoted: 1392 Post(s)
Liked: 587
I've been using a 7.5% pattern as the resulting gamma of 2.3 is almost identical to the native gamma.
With that said, I'm not certain that there isn't a better pattern. I've heard 5% with a 25% surround but that seemed a bit extreme.
JimP is offline
post #364 of 387 Old 06-01-2014, 02:50 PM
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
ok, but are there 7.5% windows on Mascior's disk somewhere? I see 2, 4, 6.5, 10 and 15% windows and 2, 4, 5 and 10% APL windows.
post #365 of 387 Old 06-01-2014, 03:07 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 228 Post(s)
Liked: 274
7.5% patterns do not exist on my disc. However, your are really splitting hairs between 7.5% and the 6.5% patterns that I have available on my disc.
Ryan
mascior is online now
post #366 of 387 Old 06-01-2014, 03:15 PM
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Ryan
Yes, I would have assumed the same but...
Jim, do you see any difference at all between using 6.5 and 7.5% windows?
Also, what Cell Light setting do you use on the Samsung?
post #367 of 387 Old 06-01-2014, 04:01 PM
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
How do you do that?
So I guess it is either round down or round normal.. what should it be for this disc?
I found this comment by zoyd: "Round down is what AVSHD,DVE use and round normal is what GCD and the internal generator use."
post #368 of 387 Old 06-01-2014, 05:27 PM
Liked: 587
I'm using a signal generator and used the 7.5% since it was one of the standard sizes.
I wouldn't expect to see any difference between 6.5 and 7.5%.
JimP is offline
post #369 of 387 Old 06-05-2014, 05:30 PM
Stereodude's Avatar
Quoted: 3085 Post(s)
Liked: 2236
No package deals if you want several of the "disc" options? What format is the H.264/MPEG-4/AVC option? Is that MP4 files?
Stereodude is online now
post #370 of 387 Old 06-05-2014, 08:14 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 228 Post(s)
Liked: 274
Hi Stereodude,
Sorry, I currently offer no package deal options. However, I might consider an iso and mp4/mkv combo in the future. Yes, the H.264/MPEG-4/AVC is the mp4 file version(no chapters). The newest addition are mkv files with chapter navigation.
P.S. You can pm me or contact me via email from the contacts page of my website if you have any further questions:)
Ryan
post #371 of 387 Old 12-28-2014, 03:54 PM
bilditup1's Avatar
Quoted: 58 Post(s)
I suppose prepackaged Blurays aren't happening? There's still no option for them on the site.
bilditup1 is offline
post #372 of 387 Old 01-01-2015, 12:28 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 228 Post(s)
Liked: 274
Hi bilditup1,
I will be releasing a Bluray disc version and updating my website soon. Unfortunately, it was bumped to the bottom of my priority list as I have other projects in the works.
Ryan
post #373 of 387 Old 01-02-2015, 03:08 PM
bilditup1's Avatar
Quoted: 58 Post(s)
Hi bilditup1,
Ryan
LOL, you gonna tell us what it is, or just hint?
post #374 of 387 Old 12-09-2015, 10:19 PM
Liked: 0
Hello Ryan, just read through the entire thread here, and your finished product sounds exactly the solution to dial in the calibration on my Samsung 60" F5300. Do you still offer it? Could not access your linked website. An AVSHD .iso file would work best as a download option for me; otherwise a pre-burned blu-ray disk though the mail is okay also.
If so, please kindly advise how best to arrange an exchange of material value for your work.
Thank you!
CloseHauled is offline
post #375 of 387 Old 12-10-2015, 07:10 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 228 Post(s)
Liked: 274
Thank you!
I am in the process of revamping my entire website and I have other things in the works. However, this is a side project for me and I have other obligations that take priority. I will send you a PM with download instructions for the AVCHD.iso at some point today. Thank you.
Ryan
post #376 of 387 Old 12-21-2015, 07:46 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 228 Post(s)
Liked: 274
I have finally updated my site and now offer a prepackaged Bluray disc option. I am still working on future side projects moving forward into 2016!
Ryan
post #377 of 387 Old 01-28-2016, 11:55 PM
daMaster's Avatar
I see that there's now a $5 charge on the website for the mkv download. This is no longer being offered for free?
Turrican4D likes this.
daMaster is offline
post #378 of 387 Old 09-17-2016, 10:03 AM
Turrican4D's Avatar
Quoted: 718 Post(s)
Liked: 414
Appearently not.
Prof. Dr. Turrican M.D.
Turrican4D is offline
post #379 of 387 Old 09-17-2016, 10:42 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 228 Post(s)
Liked: 274
Originally Posted by Turrican4D View Post
Appearently not.
The mkv version was never free??...it has always been $5 usd since its final release years ago. However, if $5 is out of your budget...there are a few free option including AVSHD 709 disc iso and files here on AVS.
-Ryan
cadett likes this.
post #380 of 387 Old 09-22-2016, 10:21 AM
Quoted: 43 Post(s)
Liked: 5
Hi,
Just wondered, what is the APL and AL of the 4% APL patterns?
iSeries is online now
post #381 of 387 Old 09-22-2016, 06:58 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 228 Post(s)
Liked: 274
Originally Posted by iSeries View Post
Hi,
Hi iSeries
My 4% APL "EE" style patterns average around 22%. Here are two good threads to reference "APL primer" and "Patterns to measure MLL as a function of APL"
-Ryan
post #382 of 387 Old 09-23-2016, 12:34 PM
Quoted: 43 Post(s)
Liked: 5
Hi iSeries
-Ryan
Thanks Ryan. The maths in some of these threads flies straight over my head lol. Would you happen to know the ARL of the 4% pattern? Background story is, I used this pattern with great results on my plasma using my bluray player, and I'd now like to generate a 3dlut to calibrate from my HTPC using MadTPG, but I'm not sure what % linear light background to choose with the 4% window to achieve a consistent result.
post #383 of 387 Old 09-24-2016, 09:39 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 228 Post(s)
Liked: 274
Hi iSeries
Utilizing MadTPG I would start with a 25%-30% background at 0% stimulus and step down incrementally towards a 13%-18% background until you reach 100% stimulus.
-Ryan
iSeries likes this.
post #384 of 387 Old 12-03-2016, 05:50 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 228 Post(s)
Liked: 274
Originally Posted by hungro View Post
Sorry this is a bit off topic. I am using the 5%APL grey scale and color patterns off of Masciola's calibration disk REV 009. I was calibrating color on my ST60 plasma using 75%a/75%s color patterns. I then did a color sweep using 75% amplitude but when I get to the 75%a/75%s pattern of the sweep my delta E is much higher then when I calibrated using only 75%a/75%s . Example: Red dE 0.1 using only 75%a/75%s but for the 75%a saturation sweep error is over 3dE same goes for the other primaries.Shouldn't the error in the sweep for 75%a/75%s be the same as in just calibrating to 75%a/75%s color patterns?
Hi hungro
The 75% amplitude/75% saturation patterns within the color sweep are the same patterns used within the 75% amplitude saturation sweep. I pulled out the archives last night to double check triplets in both sweeps. What calibration software are you utilizing? Thanks!
-Ryan
post #385 of 387 Old 12-03-2016, 08:34 PM
hungro's Avatar
Quoted: 164 Post(s)
Liked: 111
I am using ChromaPure. I just thought of this, do you think the patterns I was using is for CalMAN and not Chromapure? This disk specifically says "optimized for Chromapure". So then it's not likely the case.
hungro is online now
post #386 of 387 Old 12-05-2016, 03:55 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 228 Post(s)
Liked: 274
Hi hungro,
Prior to measuring your saturation sweeps, did you select 75% vs 100% under "Select Pattern Intensity" shown below? This would cause what you're describing. Thanks!
-Ryan
post #387 of 387 Old 12-17-2016, 09:33 AM
hungro's Avatar
Quoted: 164 Post(s)
Liked: 111
Hi hungro,
-Ryan
I had another go at it. By default pattern intensity was at 100% then I switched it to 75% and back to 100% .Closed the ACM window reopened set it to 75% intensity and it worked the sweeps were now dE accurate. I am thinking the setting didn't stick the first time around.
Reply Display Calibration
