Mascior's Calibration Disc - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #181 of 387 Old 06-09-2013, 07:18 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 231 Post(s)
Liked: 285
Originally Posted by gadgtfreek View Post
Thanks! Im gonna update so I can try the 5% window patterns with Chromapure on my VT50. Tom Huffman seems to be pretty keen on this vs 10%.
Sounds good! Was Tom referring to 5% standard window patterns or APL? The 5% windows on my disc are APL or C(constant)PL patterns. I personally bounce between my 4% standard and 4% APL patterns on my VT50 with phenomenal results! Let me know how it turns out!smile.gif
Ryan
mascior is online now
post #182 of 387 Old 06-10-2013, 08:46 AM
Quoted: 1394 Post(s)
Liked: 589
Ryan
mascior
Does your 4% standard look a little greenish?
JimP is online now
post #183 of 387 Old 06-10-2013, 10:00 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 231 Post(s)
Liked: 285
Originally Posted by JimP View Post
mascior
Hi JimP,
No, it looks pretty balanced on my VT50. I have trouble deciding whether to use 4% APL or standard...I have my isf day calibrated to 4% APL and isf night calibrated to 4% standard...switching back and forth.smile.gif In the past I had a greenish overcast issues when calibrating both my Panasonic and Pioneer, but found out my meter was the culprit. I then upgraded to my Display 3 Pro and revealed I was about 5 -10% too high on green compared to red and blue. What display are you calibrating? Meter?
Ryan
post #184 of 387 Old 06-10-2013, 11:02 AM
Liked: 589
Ryan,
I'm calibrating a 65VT50 using an i1pro2 and an i1display3pro.
What are you seeing as the difference between 4% standard and 4% APL windows?
Which gamma are you using? One thing that seems to be working for me is the use of BT1886 gamma over 2.22.
As for the meters, I do get a difference between the two and think the i1pro2 is more correct. I'm even seeing a difference between using the i1pro2 with and without a powered hub but not sure which of those two are the most correct. Need to wait till dark to test.
JimP is online now
post #185 of 387 Old 06-10-2013, 09:05 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 231 Post(s)
Liked: 285
Ryan,
I would have to say gamma being the biggest difference between my 4% standard patterns vs the 4% APL patterns on my VT50. I try to aim for a gamma of 2.22 - 2.28 when calibrating. I have noticed on mostly dark movies that the 4% standard patterns seem to make the picture look more accurate and natural over the 4% APL patterns. However, my 4% APL patterns seem to work great on just about everything else. I like having the option of switching between both sets of calibrated settings as needed.smile.gif
anta1974 likes this.
post #186 of 387 Old 06-12-2013, 12:01 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 231 Post(s)
Liked: 285
I just released the MP4 version of my pattern disc. All of the file folders are separated and categorized similar to how my pattern disc menus are arranged. Please let me know of any issues and or problems in regard to the playback of these files. Thanks.smile.gif
Ryan
rahzel and fairchild99 like this.
post #187 of 387 Old 06-12-2013, 12:13 PM
cadett's Avatar
Quoted: 38 Post(s)
Liked: 98
Sweet. Thank You & good work. I understand that the color checker section was based upon the triplet requested by Chromapure. I own Calman & was wondering if they request the same triplet or is it a different request? Thanks
cadett is offline
post #188 of 387 Old 06-12-2013, 12:28 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 231 Post(s)
Liked: 285
Hi cadett,
Thank You!smile.gif Yes, the triplet integers are different so therefore different requests. My color checker patterns are only compatible with ChromaPure software.
Ryan
post #189 of 387 Old 06-12-2013, 12:44 PM
Liked: 589
Hi JimP,
No, it looks pretty balanced on my VT50. I have trouble deciding whether to use 4% APL or standard...I have my isf day calibrated to 4% APL and isf night calibrated to 4% standard...switching back and forth.smile.gif ...snip...
Ryan
You might want to freeze an image where a person's face is to the right of the screen. Then toggle between ISF day and night modes.
JimP is online now
post #190 of 387 Old 06-12-2013, 12:53 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 231 Post(s)
Liked: 285
post #191 of 387 Old 06-12-2013, 01:30 PM
Liked: 589
My wife doesn't seem to mind me calibrating but I try to limit it to when she's not around.
Luckily, she's out of town a fair amount.
JimP is online now
post #192 of 387 Old 06-12-2013, 01:46 PM
cadett's Avatar
Quoted: 38 Post(s)
Liked: 98
Me too. However my 10 month old will have this trade down in about a week. Nothing makes his day more than banging on my laptop keys biggrin.gif
cadett is offline
post #193 of 387 Old 06-12-2013, 01:52 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
sawfish is online now
post #194 of 387 Old 06-12-2013, 02:53 PM
fairchild99's Avatar
Liked: 151
Ryan
Cool beans, anxious to try it out.
I just checked them out and although I haven't used them in a calibration there is one thing that I thought I'd share. When trying to navigate through them, it would be much easier if there were chapter breaks in the file itself which allows you to simply skip to the next chapter/pattern. Although this isn't a big deal, I can simply just pause the pattern then fast forward until I get to the next pattern and take readings. I don't know if this is even do-able with MP4, I know for sure it is with MKV files as this is the way the GCD disc is setup. On the AVS HD709 MP4 patterns, they don't have breaks, but the files themselves are organized so each file is one pattern and then you can just skip to the next file/pattern.
For example the AVS HD709 MP4 file breakdown for the first few patterns in the 10% grayscale window patterns is:
01-0% Black.mp4
02-10% Gray.mp4
03-20% Gray.mp4
etc....
Sony 32" EX400 calibrated settings
Panasonic 50" S60 calibrated settings
HTPC/Sony S5100 to Sony HT-CT660 to Panasonic 55" VT60, Sony 32" EX400, Panasonic 50" S60
fairchild99 is offline
post #195 of 387 Old 06-16-2013, 12:58 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3050
Used the newest revision yesterday for my VT50 (6.5% windows). Works great and flows well for Chromapure users.
65E6P / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is online now
post #196 of 387 Old 06-16-2013, 02:10 PM
PeterLewis's Avatar
Quoted: 128 Post(s)
Liked: 63
After I do a calibration I immediately put on the intro chase scene of Skyfall.
The chase scene shows great detail in color like the fruit stand,the clear sky and clouds,the greens of leaves and grass where Ms Penny sets up for her sniper kill and M's fleshstone is great to judge for red push as she should be pasty white.
So inconclusion the 4% standard gave me the best results on my GT30.I calibrated THX @ 40ftl and Cinema @30ftl... I also Calibrated Custom Mode @ 40ftl with HDMI OFF to use for HDTV viewing to enable the pixel orbitor.
Panasonic engineered the custom mode on these GT30 to be dark in the low end with gamma @ 2.28 at 20ire and Bright at the top end with the gamma in the low 1's in the 90 ire.It produces a nice image but fleshtones can suffer a bit in certain scenes due to the gamma shifts.
Sony OLED XBR-65A1E (In my Future )| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #197 of 387 Old 06-16-2013, 07:15 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 231 Post(s)
Liked: 285
01-0% Black.mp4
02-10% Gray.mp4
03-20% Gray.mp4
etc....
Hi fairchild99,
I wasn't aware that the GCD mp4 files had chapter pointsconfused.gif...then again I've only viewed about half of them. Unfortunately, all of my pattern sweeps were encoded as one video file and chapter point were then added in Adobe Encore. Anything short of re-encoding all of my sweeps to add chapter points or individual chapter pattern encoding...what I have currently is the best I can offer...for now.smile.gif
Ryan
post #198 of 387 Old 06-16-2013, 07:34 PM
Liked: 151
Hi fairchild99,
Ryan
Yep it's cool, it's useable by just pausing then jumping ahead 5 minutes and that pops up the next pattern. I don't remember if the GCD MP4 version has chapter breaks/points, but the MKV version does. Thanks again, I used your 4% APL windows in Custom mode on my S60 and it came out pretty close to my Cinema settings using the AVS HD709 window patterns (15%). Thanks again for providing us with yet another solid calibration disc/media files.
post #199 of 387 Old 06-16-2013, 07:46 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 231 Post(s)
Liked: 285
Good deal! The funny thing is I put 6.5% windows specifically on my disc for Panasonic Plasma calibration(based off of THX) and haven't used them once on my own VT50. I've been using my 4% standard and 4% APL patterns the past few sessions with good results. What was your average gamma with the 6.5% windows...on what gamma pre-selection(i.e. 2.2, 2.4, 2.6)?
Ryan
post #200 of 387 Old 06-16-2013, 07:56 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 231 Post(s)
Liked: 285
Thank You!smile.gif It was a lot of hard work...but well worth it in the end! I figured what's the point in making a disc if I couldn't share it with all the people here on AVS forum! I'm glad it worked for your S60 calibration!smile.gif
Ryan
post #201 of 387 Old 06-17-2013, 06:31 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3050
Ryan
2.25 with 2.4 setting.
65E6P / DMP-UB900
post #202 of 387 Old 06-17-2013, 10:58 AM
-Hitman-'s Avatar
Quoted: 134 Post(s)
Liked: 106
Hi Ryan,
I ran a couple of test runs last week to get used to the pattern routine as i'm using Calman at the moment and today ran a full re-calibration of Day/Night ISF and boy what a difference, I found ..
Calibration was a lot quicker
Less re-runs, got to target a lot quicker than usual
Flat Gamma across the board ~2.22
I settled on 35fl for night and 48fl for day and the PQ is the best I've seen from this set, even the wife walked in and said WOW smile.gif
I just want to say thank you for all the hard work you've done to create this disk and will be my preferred disk from now on, thank you so much and keep up the hard work, really appreciate it!
Ty.
-Hitman- is offline
post #203 of 387 Old 06-17-2013, 11:32 AM
cadett's Avatar
Quoted: 38 Post(s)
Liked: 98
Hi cadett,
Ryan
Thanks Ryan! Do you or anyone else for that matter, know of a disk that contain the correct color checker patterns for Calman?
By the way, I never thought a calibration disk could look bada@#, but you pulled it off.
cadett is offline
post #204 of 387 Old 06-17-2013, 12:29 PM
-Hitman-'s Avatar
Quoted: 134 Post(s)
Liked: 106
Thanks Ryan! Do you or anyone else for that matter, know of a disk that contain the correct color patters for Calman?
I used this disk, use 100% white pattern from the 11 point patterns for the CMS reference 100%, then selected the pop up menu, select 75% colour.
You then have to just skip yellow in the routine pattern call and skip back to yellow when it asks for it, quite easy really.
-Hitman- is offline
post #205 of 387 Old 06-17-2013, 12:35 PM
cadett's Avatar
Quoted: 38 Post(s)
Liked: 98
Sorry, I should have not worded that question the way I did. I was referring to the color checker patterns that Ryan created. They were designed to work with Chromapure.
The method you described is the way that I do CMS work also. Thanks for the reply.
cadett is offline
post #206 of 387 Old 06-17-2013, 12:37 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 231 Post(s)
Liked: 285
Hi Ryan,
Ty.
Hi Hitman,
Thank you for the kind words and glad to hear my disc will be your go to pattern source when calibrating!smile.gif
Ryan
post #207 of 387 Old 06-17-2013, 01:04 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 231 Post(s)
Liked: 285
Hi Cadett,
Thank you...I'm glad you like the disc!smile.gif Though you may want to check out Neil's(ndaa75) CMD HD calibration disc...it should have what you're looking for!wink.gif
Ryan
post #208 of 387 Old 06-28-2013, 03:31 AM
miSta1982's Avatar
Is anywhere a good tutorial how to make a Disc like that?
I want to make a disc, especialy for plasma. Who has pioneers washer or Scroling bars included to each Grayscale/Gamut pattern and by the popup menu choisable.
Do i need Photoshop or what else to make the patterns?
Thanks for any advice.
miSta1982 is offline
post #209 of 387 Old 06-28-2013, 07:11 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 231 Post(s)
Liked: 285
Hi miSta1982,
If you reference the first post of this thread, I gave a brief overview of the steps I took in creating my pattern disc. FYI, there is a lot that goes into creating and authoring a calibration disc from scratch! It took me months of research, thread reading, PM's, and that's before I created my very first pattern. If you happen to checkout the credits page on my disc, I list all of the knowledgeable people and software that made my disc possible. This task can be accomplished using numerous methods and since i'm the most comfortable with Adobe products, that's the route I chose. Here is a link to help get you started http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration/1650#post_16837914 and feel free to PM me if you have any further questions.smile.gif
Ryan
miSta1982 likes this.
post #210 of 387 Old 06-29-2013, 11:18 PM
rahzel's Avatar
Liked: 148
Ryan
rahzel is offline
Reply Display Calibration
