Mascior's Calibration Disc - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #1 of 396 Old 03-18-2013, 11:59 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 270 Post(s)
Liked: 399
     I would like to thank AVS Forum and all it's knowledgeable members, as it took me months of reading multiple threads before I started this project. I created a credits page off of my main menu to give credit dues and thanks. All of my custom patterns were created in Photoshop, converted to YUV (thanks to Ron’s rgbtouyvy utility), combined/created avs files, encoded in MeGUI to H.264, and authored in Adobe Encore. All of my patterns were tested thoroughly, making sure all conversions were done properly, and assuring reference quality. I attempted to make my disc intuitive as possible and section everything alike, together. I have a basic setup section, Misc. section, an advanced setup which includes pattern sizes 2%, 4%, 6.5%, 10%, 15%, Full Field, and 4 different APL selections. My patterns were designed using the round nearest method and will work with any software that utilizes thus method or for any software that assumes integer percentages. I created easy to read and navigable pop-up menus to cut down on time when calibrating. Please let me know if there are any problems, suggestions, or comments. Thank you for your continued support!
mascior is online now
post #2 of 396 Old 03-18-2013, 12:25 PM
ndaa75's Avatar
Congrats mate - looks superb!
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #3 of 396 Old 03-18-2013, 03:00 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
Great JOB!!!
anta1974 is offline
post #4 of 396 Old 03-18-2013, 03:15 PM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 124
Sony OLED XBR-65A1E| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #5 of 396 Old 03-18-2013, 03:15 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 270 Post(s)
Liked: 399
post #6 of 396 Old 03-18-2013, 04:41 PM
Killerbeenl's Avatar
thanks for your free time and effort
creating the disk :thumbup:
great disk
Sometimes you are 1 click away from pulling your hair out and bang your head against the wall
Killerbeenl is offline
post #7 of 396 Old 03-18-2013, 06:49 PM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2438
Excellent work.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #8 of 396 Old 03-19-2013, 05:31 AM
realzven's Avatar
Liked: 84
Originally Posted by PeterLewis View Post
+1:)
realzven is offline
post #9 of 396 Old 03-19-2013, 06:19 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 270 Post(s)
Liked: 399
post #10 of 396 Old 03-19-2013, 06:24 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
As a Chromapure user and plasma owner I am very curious about this disc. Any idea on the ETA for the AVCHD version?
Wouter73 is offline
post #11 of 396 Old 03-19-2013, 06:25 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
I always thought it was possible to write a bluray authored disc to dvd as long as the size was within dvd spec. Is this true?
Wouter73 is offline
post #12 of 396 Old 03-19-2013, 06:25 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
Wouter73 is offline
post #13 of 396 Old 03-19-2013, 06:46 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 270 Post(s)
Liked: 399
That is correct and the current size of my disc will fit on a dvd. However, after speaking with Nathan (the author of the AVSHD709 disc) I will have to tweak my pop-up menus and a few other details to be compatible with the AVCHD format.
post #14 of 396 Old 03-19-2013, 06:46 AM
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
I friend just send me the link for the disc. Looking forward to give it a try.
Thanks Ryan for sharing your efforts.
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
post #15 of 396 Old 03-19-2013, 06:54 AM
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
If reauthored as a AVCHD pop up menus are not supported, and even if it is a true AVCHD some BD players have a problem with hi-bit rate video, PS3 being one of them. As far as burning a BD structure disc to DVD is doable, and most players will play it with out a problem, but here again its a well known fact that Sonys and Panaasonics have a hard time playing these type of discs.
The easiest way to reauthored it as an AVCHD is runing the BDMV folder through MultiAVCHD, it will not reencode the video, it will just change it to the correct folder and file structure, and of course pop up menus will no longer work.
superleo is offline
post #16 of 396 Old 03-19-2013, 07:51 AM
alluringreality's Avatar
Quoted: 57 Post(s)
Liked: 65
I believe AVCHD uses what some people term in-mux menus. Multi-AVCHD has been updated once since I used it, but previously it would not convert the Encore Mpeg2 menus to AVC video to be compatible with certain players. I don't know if Encore has gotten away from Mpeg2 menus on newer versions or if the latest Multi-AVCHD will now convert them, but a couple years ago it was a consideration for widespread compatability.
Actually I think the Multi-AVCHD modified version I identified as AVCHD still has pop up menus on it that will work on some players.
alluringreality is offline
post #17 of 396 Old 03-19-2013, 08:11 AM
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
MultiAVCHD uses in-mux menus if you are creating menus with it, if you are using it in "Bluray re-author mode", it will only put the correct folder and file structure for compatibility, it will not re-encode anything else... video, audio or menus.
My experience when re-authoring for AVCHD compatibility has always being the loss of pop-menus; although with a limited amount of players, so it might well be that some players are capable still using the pop-up feature. It would be worth a shot.
superleo is offline
post #18 of 396 Old 03-19-2013, 08:15 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
Mascior
For a perfect Calibration Disc it's necessary:
1) need to remove all signatures - because they distort the measurement results (for sure Panasonic VT30/GT30/ST30) and insert the same intermediate video ( 30 sec or more) between patterns
2) add 1% pattern size
3) add color checker (as GCD - 12 patterns)
4) add equal energy patterns (Spears & Munsil HD Benchmark Blu-Ray 2nd Edition) for gamma
5) add the right combination constant average picture level (APL) and a constant average luminance (AL) .
6) maybe add 5% pattern size
With great respect for your work, Andrei from Ukraine.
bigapp likes this.
anta1974 is offline
post #19 of 396 Old 03-19-2013, 09:02 AM
ndaa75's Avatar
Originally Posted by anta1974 View Post
Mascior
Actually the Calman 5 colour checker patterns in sequence would be more suited.
These are what i use on my own custom pattern disks.
There are some issues with the colour sequences in the Apl selection, displays white, the magenta, then reverts back to the menu!
ndaa75 is offline
post #20 of 396 Old 03-19-2013, 09:08 AM
ndaa75's Avatar
Hi Anta.
What signatures are you referring to here? The pattern labels presumably?
ndaa75 is offline
post #21 of 396 Old 03-19-2013, 09:11 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
Yes
anta1974 is offline
post #22 of 396 Old 03-19-2013, 09:17 AM
ndaa75's Avatar
As long as theyre small enough they shouldnt make any difference.
ndaa75 is offline
post #23 of 396 Old 03-19-2013, 09:22 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 270 Post(s)
Liked: 399
Nice Catch! I'm all over it and will have an uploaded fix in a few. I am also going to be uploading an AVCHD version later on this afternoon with pop-up capabilities.
post #24 of 396 Old 03-19-2013, 09:41 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
ChadB
The VT30 has some unusual quirks which can easily cause significant measurement problems. It's important to be aware of them and take steps to compensate for them.
1. Variances with measurement window size. It is best to either use windows small enough to not trigger ABL, or use windows that give consistent ABL action such as the APL windows on the AVS 709 disc.
2. Stability issues. Once a window is changed, it takes a couple of seconds to stabilize. However, then if the same window is displayed too long, it will get "tired" and start changing again. It is best to set a slightly longer than normal pattern update delay (2.5 seconds may be sufficient), and don't trust measurements made on a window pattern that has not been changed in a while (perhaps 45 seconds or so, though this has not been determined definitely).
3. Consistency. The image displayed immediately before a measurement run can have a significant influence on the outcome of those measurements. If a gray ramp is displayed immediately before a calibration run, the measurements will be different than if a scrolling bar is displayed immediately before the run. Therefore, it is important to pick what you intend to display before each run, and then display it consistently before EACH MEASUREMENT RUN. A scrolling bar, gray ramp, or DVD menu may work. I do not provide reminders to display your pre-measurement image before each run in this workflow; it is ESSENTIAL that you remember to do it on your own!
Keep these quirks in mind during the calibration session. Forgetting them may cause a great deal of frustration and wasted time.
anta1974 is offline
post #25 of 396 Old 03-19-2013, 09:42 AM
great progress Mascior !!
Also the avchd is great so now i can use my mediaplayer (iconbit3D) and BDplayer (Panasonic) to check inputs.
post #26 of 396 Old 03-19-2013, 09:57 AM
ndaa75's Avatar
ChadB
Yes, these quirks are well known to us VT30 owners! However and as advised, the effect a small corner signature will have on your measurement will at the most be very very minimal if at all.
ndaa75 is offline
post #27 of 396 Old 03-19-2013, 10:09 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
all this will need to create a perfect Calibration Disc - IDEAL
anta1974 is offline
post #28 of 396 Old 03-19-2013, 11:25 AM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 124
Great news Thanks...
I look forward to the avchd as my laptop is the only electronic gear that i never really bothered upgrading and thus have no blu-ray reader capabilities.
post #29 of 396 Old 03-19-2013, 12:26 PM
prsut's Avatar
Liked: 57
+1
Panasonic TX-P42GT50E, Oppo 103, Schiit Vali, Denon AHD2000 + Moon Audio Blue Dragon V3, Phonak Audeo 121, Vsonic GR07, Fiio E17, Cowon S9, XLO cables :: CalMAN 5 Enthusiast,Chromapure Standard, i1D3, i1Display 2, TED's Calibration Blu Ray Disc v1.0 & v1.1
prsut is offline
post #30 of 396 Old 03-19-2013, 12:36 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 270 Post(s)
Liked: 399
I have fixed the issues that were found in the first revision and completed the AVCHD version. I am currently uploading both files to my dropbox account as we speak. I would say both files will be ready for download in the next hour or so.smile.gif
Reply Display Calibration
