Brightness divergences between Calibration Discs and BD Players - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 03-19-2013, 08:16 AM - Thread Starter
KeitaroSan's Avatar
Hello my friends,
i'm having a strange problem with brightness setting using different calibration disks with different BD Players.
My TV is a 64E8000 and I'm calibrating using 2 BD Players, 1 Samsung C7000 and 1 Oppo BDP103.
On Samsung C7000 i set 51 on brightness setting, this setting works fine on DVE and AVS HD disk, no problems. But when i use the Oppo, i set 39 on brightness setting with DVE and 44 with AVS HD.
This Oppo behaviour is normal? The brightness setting not should be equal in the 2 discs? like the BDP C7000.
KeitaroSan is offline
post #2 of 16 Old 03-19-2013, 09:36 AM
Rolls-Royce's Avatar
Quoted: 314 Post(s)
Liked: 480
Originally Posted by KeitaroSan View Post
Hello my friends,
What you're seeing is not at all unusual. For a number of reasons, discs and players can vary in their output levels. Discs can vary due to the encoding suite used to produce the discs, and players can vary because of how their programming handles the different filetypes involved among other things. Make sure both players are set to output the same, i.e., YCbCr 4:2:2, RGB low, RGB high, etc. Whatever you prefer, just make sure both players are set that way. I would personally trust the Oppo's output more than the Samsung's.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #3 of 16 Old 03-19-2013, 10:05 AM - Thread Starter
KeitaroSan's Avatar
Originally Posted by Rolls-Royce View Post
What you're seeing is not at all unusual. Discs and players are known to vary in their output levels. I would personally trust the Oppo's output more than the Samsung's.
Hello Rolls-Royce,
thanks biggrin.gif, but the brightness variance don't should be less (maybe equal) between discs in a same Player?
I want understand the causes for this big difference. What the disc can i trust to calibrate with the Oppo?
post #4 of 16 Old 03-19-2013, 10:45 AM
willieconway's Avatar
Quoted: 148 Post(s)
Liked: 148
7 clicks is a huge difference. I'v seen a one click difference between my PS3 and my Panasonic BDT 220 using AVS HD when the players were on different color space settings. So you're sure that everything e.g. HDMI level etc. matches up?
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D. Currently boxed up: Denon 1713, Klipsch SW-450,
NHT Absolute Center, Energy Veritas 5.1s, 5.2C, V-Mini-C.
willieconway is offline
post #5 of 16 Old 03-19-2013, 10:48 AM
alluringreality's Avatar
Quoted: 57 Post(s)
Liked: 65
I understand what you are saying, and I have no guess at what could be going on. If there's ever a question about the disc, go with DVE Blu-ray, since it's similar to how other Blu-rays are sold. Personally all my electronics can use standard video levels, which result in the same setting at the TV, so the described behavior is not what I would typically expect.
alluringreality is offline
post #6 of 16 Old 03-19-2013, 11:20 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 41 Post(s)
Liked: 144
Greetings
Oppo has all these video settings like 422 and 444 and rgb and auto ... they will change where the black level ends up depending on what is selected. The Samsung likely does not have these options.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #7 of 16 Old 03-19-2013, 12:05 PM
Quoted: 314 Post(s)
Liked: 480
Samsung's website doesn't list a C7000 BDP. But there is a D7000, and its manual says HDMI color formats can be set at Auto, YCbCr 4:4:4, RGB Standard, and RGB Enhanced.
...Royce...
post #8 of 16 Old 03-19-2013, 12:58 PM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
What
Originally Posted by Michael TLV View Post
Greetings
regards
Which setting would you recommend when using the oppo 103?
Wouter73 is offline
post #9 of 16 Old 03-19-2013, 06:02 PM
jimed1's Avatar
I am pretty sure you want to use 444 or auto. I think 422 lacks some chroma data and you dont want to throw that away by telling the oppo to output 422.
Jim Ed
jimed1 is offline
post #10 of 16 Old 03-19-2013, 06:10 PM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
4:2:2 is fine. BD is 4:2:0 on the disc, but HDMI doesn't have a 4:2:0 option, so either way you have to let the OPPO upsample. 4:2:2 has more bit depth/lower bandwidth, but it maybe that the OPPO does a better job converting 4:2:0 to 4:4:4 than your TV does, so from a technical stand point either could be better depending on your equipment.
That's why discs like spears and munsil have patterns to try and validate that you are getting the optimum chroma resolution.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #11 of 16 Old 03-19-2013, 11:42 PM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
I have the oppo 103eu going through the lumagen mini ending in the panasonic 65vt50eu. Would 4:4:4 be better then?
Wouter73 is offline
post #12 of 16 Old 03-19-2013, 11:53 PM
gtgray's Avatar
Quoted: 225 Post(s)
Liked: 146
Not if you believe in what the Lumagen people say. They are emphatic the preferred color space is 4:2:2 as that is what the Radiance uses internally and will receive the best and least processing. Clearly, that is not always an option.
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
post #13 of 16 Old 03-20-2013, 12:13 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
To be honest, I tried both on multiple occasions and cannot say I saw a difference...
Wouter73 is offline
post #14 of 16 Old 03-20-2013, 05:21 AM
dsinger's Avatar
Quoted: 316 Post(s)
Liked: 320
I use 422 on HDMI 1 Source Direct and can't see a difference vs. 444 or RGB video. HDMI 2 output has a color up sampling problem with the Radiance. It fails all the chroma mulitburst upsampling tests on S&M when fed to the Radiance. Oppo has acknowledges that the source of the problem is Oppo not Lumagen. Oppo may fix with a firmware update.
dsinger is offline
post #15 of 16 Old 03-20-2013, 08:04 AM - Thread Starter
KeitaroSan's Avatar
Thanks for answers my friends, i'll try all suggested advices .
post #16 of 16 Old 03-20-2013, 11:44 AM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
You don't have to see a difference. 4:2:2 gives the best result, period... if there's no reason to use RGB. 4:2:2 is natively 12-bits unless you change it in the disc player settings (which you should not do), when you select 4:4:4 or RGB you'll get 8-bits or 8-bits expanded to 10 or 12 bits (with zero benefit to image quality, just a bunch of unused bits). That said, some TVs or projectors just plain look better when you send RGB due to some internal design anomaly (shouldn't make a difference, but it does for SOME TVs... maybe 5% to 10% of various models and it changes every year new models come out... I've seen a Sony XBR look better when receiving RGB one year and the next year, YCbCr and RGB look the same.
4:2:2 makes the best use of the data path in the Lumagen processors... use it ALWAYS when sending video to the Radiance processor from any source. The output of the Radiance processor... you can set it to whatever looks best on your TV... if there's no diff between 4:2:2 and RGB, send 4:2:2. If RGB looks better, send RGB.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
Reply Display Calibration
