Should I adjust my set with the set controls or those on the receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-19-2013, 08:15 PM - Thread Starter
dclark's Avatar
Quoted: 45 Post(s)
Liked: 29
I have a Samsung 72a650 (dlp) set and a denon 4311 receiver. When I am using the Wow disc, should I set the color, brightness with what is on the set, or what is on the receiver (I can pull up a menu with picture adjustments on my receiver).
dclark is offline
post #2 of 2 Old 03-19-2013, 09:15 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
It's accepted as best to do all settings and/or calibration in the display. If there is a problem that you can't fix then it's OK to make adjustments in the AVR or Blu-ray player depending on which one is best.
htwaits is online now
Reply Display Calibration
