.yuv10 file format - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 03-22-2013, 11:48 AM - Thread Starter
ndaa75's Avatar
Anyone know if there is a programme that can convert .yuv10 file to RGB or YUV file format?
I can download some test patterns but cannot open the files!!
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #2 of 23 Old 03-22-2013, 12:46 PM
ConnecTEDDD's Avatar
Quoted: 1533 Post(s)
Liked: 1977
I'm sure you want to open some of the Studio Monitor Measurements - Test Patterns (EBU TECH-3325) Patterns wink.gif
Try Adobe Priemier, but i'm not 100% sure.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #3 of 23 Old 03-22-2013, 12:50 PM - Thread Starter
ndaa75's Avatar
Alas, file format not supported!
ndaa75 is offline
post #4 of 23 Old 03-22-2013, 12:54 PM
Liked: 1977
I tryed to open these files a long time ago (2010) with no luck too... frown.gif
post #5 of 23 Old 03-22-2013, 01:00 PM
visca blaugrana's Avatar
visca blaugrana is offline
post #6 of 23 Old 03-22-2013, 01:18 PM - Thread Starter
ndaa75's Avatar
Originally Posted by visca blaugrana View Post
This will, http://www.offminor.de/vooya_yuv_player.html#downloads
not YUV10 files it wont!
ndaa75 is offline
post #7 of 23 Old 03-22-2013, 02:02 PM
when you try to open the files change the picker to all files, then select the right format, and it should work, just tried it and work fine,
post #8 of 23 Old 03-22-2013, 02:08 PM - Thread Starter
ndaa75's Avatar
To be sure, were talking about .yuv10 file format - its not the same as a standard .yuv file.
ndaa75 is offline
post #9 of 23 Old 03-22-2013, 02:13 PM
smile.gif yes still works
post #10 of 23 Old 03-22-2013, 02:30 PM - Thread Starter
ndaa75's Avatar
Can you tell me what settings your using? have oyu opened up a YUV10 file?
Coudl you please try and load the following image. EBU_3325_1080_3_06.zip 9k .zip file
ndaa75 is offline
post #11 of 23 Old 03-22-2013, 05:23 PM
dr1394's Avatar
Quoted: 150 Post(s)
Liked: 76
Here's a utility to convert yuv10 files to 8-bit bmp or tga files.
http://www.w6rz.net/yuv10torgb.zip
Code:
usage: yuv10torgb <-bv6> <horz> <vert> <infile> <outfile>
Defaults are tga file, 0 to 255 RGB and BT.709 matrix.
-b for bmp files
-v for video levels
-6 for BT.601 matrix
For example:
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is online now
post #12 of 23 Old 03-22-2013, 05:32 PM - Thread Starter
ndaa75's Avatar
Code:
-b for bmp files
-v for video levels
For example:
Ron
Cheers Ron,
Dont suppose theres one that can downsample a 10bit YUV to an 8 bit one? Just might make the process a little simpler!
ndaa75 is offline
post #13 of 23 Old 03-22-2013, 05:42 PM - Thread Starter
ndaa75's Avatar
Works a treat, thanks again Ron.
Neil
ndaa75 is offline
post #14 of 23 Old 03-23-2013, 02:31 AM
Hi Ron,
Just tried to convert a file, and it all seem a bit odd. I have tried the following
1) play the .yuv10 file in Vooya
(out depend on the video format setting)
3) converted the .yuv10 to .yuv converted to .tga
all 3 results bring up a complete different pattern
see below
1
LEAD Technologies Inc. V1.01
2
3
could I get you to have a look at what could have gone wrong?
post #15 of 23 Old 03-23-2013, 02:39 AM
Neil,
Try the following to open the yuv10 file
ensure you change to all files or you will not be able to select yuv10 files
post #16 of 23 Old 03-23-2013, 04:31 AM
dr1394's Avatar
Quoted: 150 Post(s)
Liked: 76
Hi Ron,
For others reading the thread, the patterns can be downloaded from:
http://tech.ebu.ch/docs/tech/tech3325_testpatterns.zip
The only interesting pattern is EBU_3325_1080_7.yuv10
The file format is interleaved 4:2:2 YUV (UYVY) with 10-bit samples in big-endian 16 bit words. This format could handle up to 16-bit YUV, and it's pretty much a waste of space for 10-bit YUV.
Ron
post #17 of 23 Old 03-23-2013, 04:40 AM
Liked: 1977
Hi Ron,
Ron
100% Agree, all other patterns are not something special, most of them are for measuring panel uniformity or topic contrast of different a parts of the screen.
That's the reason i used only this pattern to my 2010 Calibration Disk (unreleased to public) wink.gif
post #18 of 23 Old 03-23-2013, 04:45 AM
dr1394's Avatar
Quoted: 150 Post(s)
Liked: 76
The pattern has below black and above white, so it's more interesting in video level RGB.
Ron
post #19 of 23 Old 03-24-2013, 12:40 AM - Thread Starter
ndaa75's Avatar
Ron
Thanks again Ron for your help, reaaly appreciated.
One more question i have is that im looking at designing a few flashing and moving custom test patterns but alas ive not been able to locate any details or information on how to create these within a .avs script.
Wondering if anyone knows or could point me in the right direction?
Neil
ndaa75 is offline
post #20 of 23 Old 03-24-2013, 01:01 AM
The way I have done it in the past (am sure there is an easier way) was to load the relevant still pictures in the first part of the script (like normal) and then at the bottom clip 3 equal clip1+clip2+clip1+clip2 for as long as required, turns out like a long script.
post #21 of 23 Old 11-25-2014, 09:22 AM
Soulnight's Avatar
Quoted: 272 Post(s)
Liked: 178
Code:
-b for bmp files
-v for video levels
For example:
Ron
Hello,
thank you for the tool.
How do I get RGB 16 235?
Soulnight is offline
post #22 of 23 Old 11-25-2014, 02:49 PM
dr1394's Avatar
Quoted: 150 Post(s)
Liked: 76
Originally Posted by Soulnight View Post
Hello,
With the -v option. For example:
yuv10torgb -v 1920 1080 EBU_3325_1080_3_06.yuv10 test.tga
You can also combine options.
Ron
post #23 of 23 Old 11-25-2014, 02:51 PM
Soulnight's Avatar
Quoted: 272 Post(s)
Liked: 178
Thank you!
Reply Display Calibration
