latest hcfr fork + display2 and dark reading... - AVS Forum | Home Theater Discussions And Reviews
Old 03-23-2013, 12:28 PM - Thread Starter
fairchild99's Avatar
Liked: 151
I recently got back into calibrating since I purchased a new plasma recently and was wondering if the Display2 still needs to have a dark reading performed upon first starting a calibration sequence. I noticed the new HCFR fork when I go to calibrate the sensor, it asks for a white pattern. What I had been then doing was provide a 100 IRE gray pattern and then hitting calibrate.
Is this totally incorrect and should I have used a 0 IRE pattern or just placed the sensor on a black surface (like a black DVD case)?
If the latter is the case, I guess I'll have to perform my calibrations again on my P50S60 and verify everything is still reading correctly.
Thanks in advance if anybody can lend some assistance.
Sony 32" EX400 calibrated settings
Panasonic 50" S60 calibrated settings
HTPC/Sony S5100 to Sony HT-CT660 to Panasonic 55" VT60, Sony 32" EX400, Panasonic 50" S60
fairchild99 is offline
Old 03-25-2013, 10:38 AM - Thread Starter
Liked: 151
Not much input here, guess most moved on to different calibration instruments. wink.gif
I went ahead and just re-calibrated using HCFR 2.1 and did the black reading initialization and hope my soon to be 2 year old Display2 is still reading accurate. The picture is pretty nice so hopefully it hasn't drifted much.
I'm still debating whether to get a used eye-one pro spectrometer or a colormunki display colorimeter.
Old 03-25-2013, 03:36 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
For the i1D2 and the new HCFR version 3, use the same dark initialization method (meter on a flat black surface) as used with version 2.
HCFR users have moved to this thread: http://www.avsforum.com/t/1393853/fork-of-hcfr-started-whats-needed
Larry
LarryInRI is offline
Old 03-25-2013, 05:46 PM - Thread Starter
Liked: 151
Rightio, thanks Larry. Guess we can just disregard that it's asking for a white panel when you calibrate the meter, and just feed it the black surface.
