eeColor processor - ArgyllCMS - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 61Likes
post #271 of 632 Old 06-08-2014, 07:31 AM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
Originally Posted by sillysally View Post
Color Space is what I am measuring.
Yes I know, but what are the measures? If the triangle is not getting mapped to Rec.709 at the dE 0.5 level and your starting point is outside the target gamut then something is wrong in the process. The screenshot I was looking for is this one with your settings:
zoyd is offline
post #272 of 632 Old 06-08-2014, 07:38 AM
sillysally's Avatar
Quoted: 866 Post(s)
Liked: 864
Sorry I know I posted the wrong screen shot.
"Don't worry be happy"
sillysally is offline
post #273 of 632 Old 06-08-2014, 08:13 AM - Thread Starter
zoyd's Avatar
Liked: 1055
First problem I notice is that you used rec709_gamma22.icm as your source profile and also checked BT.1886 offset mapping, that will ruin your LUT. You should have either rec709_gamma22.icm and BT.1886 unchecked or rec_709.icm and BT.1886 checked. Remeasure the gamut edges after making that correction and post results.
zoyd is offline
post #274 of 632 Old 06-08-2014, 10:29 AM
sillysally's Avatar
Quoted: 866 Post(s)
Liked: 864
Sorry about all of this "zoyd". I was rushing to correct my first posted image, that I just made the second image up.
Below is the real image.
[IMG
reloaded that profile and mad a LUT, loaded it into eecolor. Below is what LS reported about the new LUT, I have the VT60 in Native mode.
As it turned out madVR was locking my video card at 0-255, so when I ran a test using LS and its inturnal genorator my video card was locked at 0-255 and therefore LS was not reading correctly. That is also the reason why LS made a poor Profile/LUT, Sorry Steve.
Now I have to figure out what the problem with CM and using my Lumagen as a pattern generator is, but not know.
Thanks, and again sorry about this zoyd and Steve.
ss
post #275 of 632 Old 06-08-2014, 11:36 AM - Thread Starter
zoyd's Avatar
Liked: 1055
A trick you can use in LS if you want to keep your video card at 0-255 but still profile or verify in video levels is to load a unity lut into LS and then video scale it. After that use that as a virtual LUT to run your patterns and it will behave the same as your madVR flow. (also equivalent to the -E switch in dispread).
ConnecTEDDD likes this.
zoyd is offline
post #276 of 632 Old 06-10-2014, 06:24 AM
sillysally's Avatar
Quoted: 866 Post(s)
Liked: 864
Any Idea how I can correct Magenta @ 100% Luminance, I am getting about dE of 2.7.
Also Triplet: 235,104,16 is giving a dE 2.5
Other wise my avg dE across the board is around .6 and high if I take out the one triplet is around 1.3
These numbers and report are being generated by CM QC SG.
Below is my testchart I am using.
I am not complaining, but just trying to squeeze ever bit I can out of my LUT's.
Also both Rec 709 2.2 and BT 1886 2.4 are being mapped well from the same profile. I am using a second PC to run my test and leaving the PC I use to run ArgyII/madVR locking my video card a 0-255, so I don't have to play around getting madVR to put my video card back to 16-235. Working well. smile.gif
ss
post #277 of 632 Old 06-10-2014, 07:24 AM - Thread Starter
zoyd's Avatar
Liked: 1055
hmmm....2.7 at one point on the gamut edge would not keep me awake at night. wink.gif The first thing I'd want to know at that level is if it's real. In order to do that you should run verification tests using exactly the same hardware and software as was used to create the LUT. That will eliminate variables not related to the display performance. So you should use the measurement report feature of dispcalGUI to do your first pass at verification and proceed from there.
zoyd is offline
post #278 of 632 Old 06-11-2014, 02:10 AM
DrFaxe's Avatar
Liked: 86
To get a 2.2 power law you have to replace rec709.icm with rec709_gamma22.icm in the collink command.
yes, use TV encoding in and out if you are running YCC or limited RGB through the box.
You do not need to do anything with the 1d files if you use TV encoding
So your command line should look like:
collink -v -qh -G -ia -3e -et -Et Rec709_gamma22.icm display.icm display_link
if I want to have a 2.25 or 2.3 power law, how can I create a .icm file for that?
(as "only" .icm files for 2.2, 2.35 and 2.4 power law are available)
DrFaxe is offline
post #279 of 632 Old 06-11-2014, 03:03 AM - Thread Starter
zoyd's Avatar
Liked: 1055
zoyd is offline
post #280 of 632 Old 06-11-2014, 06:01 AM
DrFaxe's Avatar
Liked: 86
Thanks Zoyd! I already thought about that but was not sure, because of the different file extension and which settings to use.
I assume I just have to load the Rec709 RGB preset, change tone curve to gamma, enter the desired value and leave white / black level at default (120 / 0 cd/m²). Afterwards rename the icc file to icm extension.
And for BT1886, using IB or Ib switch with any value in the collink command, I have to use the REC709.icm, correct?
DrFaxe is offline
post #281 of 632 Old 06-12-2014, 09:15 AM
fhoech's Avatar
Quoted: 414 Post(s)
Liked: 275
No need to change the extension.
Yes.
fhoech is offline
post #282 of 632 Old 06-12-2014, 10:02 AM
DrFaxe's Avatar
Liked: 86
Thanks for confirmation Mr. Hoech.
DrFaxe is offline
post #283 of 632 Old 06-12-2014, 05:35 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
sorry, wrong thread
spacediver is offline
post #284 of 632 Old 06-15-2014, 09:21 PM
sillysally's Avatar
Quoted: 866 Post(s)
Liked: 864
hmmm....2.7 at one point on the gamut edge would not keep me awake at night. The first thing I'd want to know at that level is if it's real. In order to do that you should run verification tests using exactly the same hardware and software as was used to create the LUT. That will eliminate variables not related to the display performance. So you should use the measurement report feature of dispcalGUI to do your first pass at verification and proceed from there.
Here is the test results from a 9270 patch profile, using BT 1886 2.4.
Sorry I can't seem to post the full html report.
Any suggestions.?
ss
post #285 of 632 Old 06-16-2014, 03:06 AM - Thread Starter
zoyd's Avatar
Liked: 1055
zoyd is offline
post #286 of 632 Old 06-16-2014, 03:31 AM
ConnecTEDDD's Avatar
Quoted: 1242 Post(s)
Liked: 1761
Can you link or upload the html file, it's not very readable as plain text. Why does your white Luminance say 403.6 cd/m^2?
I have seen that strange reporting of SS's peak white again to another thread I believe.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #287 of 632 Old 06-16-2014, 11:47 AM
sillysally's Avatar
Quoted: 866 Post(s)
Liked: 864
I don't think AVS will let me upload the file. I could link but that would be to me PC and I don't think that is very safe. If you have a way let me know.
In the mean time here are some screen shots from CM's QC SG reports. I did the CM report in the same session.
See link below in my post to spacediver
ID:	120930   Click image for larger version
ID:	120938   Click image for larger version
Name:	ColorChecker SG zoyd.jpg
post #288 of 632 Old 06-16-2014, 11:59 AM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Try a free online file host - I think this one would work well:
http://tinyupload.com/
sillysally likes this.
post #289 of 632 Old 06-16-2014, 12:59 PM
sillysally's Avatar
Quoted: 866 Post(s)
Liked: 864
Thanks, here is the link.
http://s000.tinyupload.com/index.php...27319035335079
ss
post #290 of 632 Old 06-16-2014, 02:53 PM - Thread Starter
zoyd's Avatar
Liked: 1055
well I don't understand that white luminance value and it showed up in your previous LS screenshot as well, close to 400 nits. In any case the normalized values appear to work and it looks like you might be clipping slightly in red when using the native gamut.
zoyd is offline
post #291 of 632 Old 06-16-2014, 03:12 PM
sillysally's Avatar
Quoted: 866 Post(s)
Liked: 864
I am using Rec. 709 gamut, with this LUT.
ss
post #292 of 632 Old 07-19-2014, 10:29 PM
sillysally's Avatar
Quoted: 866 Post(s)
Liked: 864
dispcalGUI has been updated to 2.1.0.9
ss
post #293 of 632 Old 08-05-2014, 02:33 PM
sillysally's Avatar
Quoted: 866 Post(s)
Liked: 864
I see on the latest update for dispcalGUI, there is a note about "(requires Argyll CMS 1.7 beta development code 2014-07-10 or newer)".
Is there a update for ArgyCMS 1.7 beta 2014-05-21.???
If so can you point me to the download and any special instructions on installing it.
ss
post #294 of 632 Old 08-05-2014, 03:03 PM
fhoech's Avatar
Quoted: 414 Post(s)
Liked: 275
Not as binary release, only in source code form as far as I know (thus the phrasing in the changelog).
fhoech is offline
post #295 of 632 Old 08-22-2014, 08:47 AM
ACappo's Avatar
Quoted: 47 Post(s)
Liked: 45
in madvr in the setting "the display expect the following RGB output levels" what is the correct setting when my TV will show btb and wtw with my laptop as source?
is there any issues using Argyll CMS 1.6.3 with the latest dispcal 2.1.1.6 Beta?
ACappo is offline
post #296 of 632 Old 08-23-2014, 04:51 AM
fhoech's Avatar
Quoted: 414 Post(s)
Liked: 275
None that I'm aware of at least.
fhoech is offline
post #297 of 632 Old 09-02-2014, 03:47 AM
Liked: 1761
Originally Posted by assm0de View Post
This looks fascinating. In theory you could get very accurate colour on any display. Do you get any banding on the end result? What is the bit depth of the LUT on the eeColor box? Does it use a dithering LUT like AMD GPUs? Where is the best place to buy the eeColor box? Thanks.
Hi, The eeColor 3D LUT Box features 16-bit internal signal processing and 6 memory slots (selectable via the infrared remote control) for 65-Point Cube 3D-LUT Tables (274.625 Color Points) with 10-bit color depth per color channel (30-bit) for color management (10-bit 3D-LUT Table Depth).
post #298 of 632 Old 10-24-2014, 04:55 PM
sillysally's Avatar
Quoted: 866 Post(s)
Liked: 864
How do I change the interpolated lookup table size from the default 33x33x33?
ss
post #299 of 632 Old 10-24-2014, 07:34 PM
gwgill's Avatar
Quoted: 249 Post(s)
Liked: 186
On the command line, it's the either -q for general sizes, or -r for a specific size.
See http://www.argyllcms.com/doc/collink.html#r
gwgill is offline
post #300 of 632 Old 10-29-2014, 08:34 PM
sillysally's Avatar
Quoted: 866 Post(s)
Liked: 864
Any tips on how to setup advanced Gamut mapping for my 65VT60 Plasma.
ss
ID:	339793   Click image for larger version
Reply Display Calibration
