eeColor processor - ArgyllCMS - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 69Likes
Old 09-28-2015, 04:28 PM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
Originally Posted by |Tch0rT| View Post
I'm not even interested in 4K until Rec2020 becomes standard and then I'd like to get a projector. Anyway I'm geeked to get the eeColorbox. I had been using madVR to correct my Mits DLP but it bugs me that my other sources are wrong so no more of that (hopefully lol).
believe me, u won't be disappointed ;-)
supported by all major apps: Argyll, LS, CM... highest LUT resolution available on the market.
Reliability is A+++++
|Tch0rT| and W3Rman like this.
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
Old 09-28-2015, 05:11 PM
ConnecTEDDD's Avatar
Quoted: 1288 Post(s)
Liked: 1802
Hi, MadVR is using the same file format with eeColor (TXT extention file with 65-Point RGB Input-Output data's)
This is a useful setup guide: 3D LUT creation workflow for madVR or eeColor
And later you will have to upload the correction 3D LUT tables to eeColor via USB cable and eeColor's ''TruVue eeColor Application''.
|Tch0rT| likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
Old 09-30-2015, 04:41 PM
wolf18t's Avatar
Quoted: 27 Post(s)
Originally Posted by Iron Mike View Post
Argyll users...
as has been announced in other threads: there is currently an eeColor special promo that just started which brings the 3D LUT box down to US$299 incl. domestic shipping (US$349 incl. internat'l shipping). Limited stock, promo good while supply lasts.
Now it's very tempting to get an eeColor + i1 display pro to fully calibrate (CMS) my 55ec5300 oled using ArgyllCMS/dispcalGUI ! Does someone finally had good success with this combo and LG oled???
As I understand, it would need a special test pattern for i1 display pro to have time to read some color patterns because of LG agressive ABL...
wolf18t is offline
Old 09-30-2015, 04:48 PM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
SillySally would be the one to ask...
Old 09-30-2015, 07:43 PM
wolf18t's Avatar
Quoted: 27 Post(s)
IIRC SillySally use a Klein K-10 which is faster than the i1display pro.
wolf18t is offline
Old 09-30-2015, 07:47 PM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
yes, sorry, correct.
Old 10-01-2015, 05:28 PM
sillysally's Avatar
Quoted: 873 Post(s)
Liked: 874
argyllCMS/dispcalGUI, will probably have a solution for using a D3 and ASBL.
zoyd has posted that GW.Gill (argyll) is working on that.
ss
wolf18t likes this.
"Don't worry be happy"
sillysally is offline
Old 10-01-2015, 06:43 PM
wolf18t's Avatar
Quoted: 27 Post(s)
ss
Thanks! Now it's decision time...
wolf18t is offline
Old 10-01-2015, 10:17 PM
10k
10k's Avatar
Quoted: 1664 Post(s)
Liked: 1791
I'm pretty sure you can defeat ASBL by yourself. Make it so madvr isn't fullscreen, make the window around 90% of the desktop size. Set window size 8% and APL 20%. Then download a handful of darkish backgrounds that all look different from eachother, I google image searched a bunch of space nebula pictures. Make sure these arent bright enough to trigger ABL.
Set windows to change background between these every 10seconds. Then do your argyllcms run.
It's pretty obvious when ASBL has triggered as you will get horrible contouring in your 3dlut. If you dont immediately notice the contouring then you've gotten a good result.
wolf18t likes this.
10k is online now
Old 10-02-2015, 12:15 AM
dlj11's Avatar
Quoted: 43 Post(s)
Hi guys, yesterday I played around with dispcalgui & madVR. I have an i1Pro and an EODIS3, I know that the argyll drivers are different.
So now that is my problem, with the i1Pro I can change the driver whenever I want (via Device Manager) so this is OK. BUT the EODIS3 only is accepting the argyll-driver. It is recognized as USB-Device, but I cannot install the original driver, the software says that the actual drivers are already installed. So my i1Display is not recognized in CalMAN, that sucks.
I tried everything, deinstalling the argyll-drivers did not help. I hope you guys can help me...
dlj11 is offline
Old 10-02-2015, 03:36 AM
Quoted: 1497 Post(s)
Liked: 612
Originally Posted by dlj11 View Post
...snip...
Seems like you have to do something counter intuitive to do that on Windows 7.
Which windows version are you running?
JimP is online now
Old 10-02-2015, 03:47 AM
dlj11's Avatar
Quoted: 43 Post(s)
Windows 10, I have to say that I dont know if the EODIS3 was working under WIN10 before I tried argyll and dispcalgui. Have Win10 for two weeks now and I did not do anything with CalMAN ind this 2 weeks.
I have no idea what the problem is, the argyll-drivers work flawless. Normally you can see the EODIS3 under X-Rite devices (I think) in the Device Manager, but now it is a standard USB-Device and can only be found when you search for it and try to change drivers. Doctor Google did not help either...
dlj11 is offline
Old 10-02-2015, 07:13 AM
fhoech's Avatar
Quoted: 417 Post(s)
Liked: 277
Normally the i1D3 does not use vendor drivers (there are no X-Rite drivers for it), it is by default a standard HID (human interface device). In Device Manager, this should show as "HID compliant vendor-defined device" under the "Human Interface Devices" sub-category, and that's the driver you need to switch to (right-click, "Update driver...", "Search for drivers on this computer", "Pick from list". Under Win10 the correct entry will be "HID compliant vendor-defined device", not "HID-compliant device").
Note that this driver should also work with Argyll CMS.
DisplayCAL - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 3.2.4 released 2017-02-19
Current development snapshot: 3.2.6 Beta (Windows/0install) released 2017-05-05 | Standalone | Changelog
DisplayCAL on Facebook
fhoech is offline
Old 10-02-2015, 10:13 AM
dlj11's Avatar
Quoted: 43 Post(s)
*delete*
dlj11 is offline
Old 10-03-2015, 01:13 AM
|Tch0rT|'s Avatar
Quoted: 185 Post(s)
Liked: 128
I got my eeColor box today! I have dispcalGUI profiling now. I did however find one problem. I do use madVR for a little bit of light upscaling with my AMD APU A8-6500 w/HD8570D and I use Fullscreen Exclusive mode since I seem to get more accurate frame rates, no dropping etc but when my HTPC enters Fullscreen Exclusive mode it knocks the eeColor box "offline". The LED shuts off and will not let a signal pass through for a while. Any ideas? I guess I don't need to use madVR anymore but I understand that it's the best renderer for video even if you don't use the upscaling etc, though correct me if I'm wrong here.
Also I found another problem maybe. Iron Mike had me load the Lightspace 3DLUTs you can download off their site and load it into the eeColor with the TruView software after some other trouble shooting anyway while I'm profiling I turn off the eeColor with the remote so it displays 0 on the LED but during certain times the eeColor box will turn back on to 1 while profiling, won't this throw off my calibration?
My Home Theater/Video Gaming/HTPC/2 Channel rig (Mitsubishi, MartinLogan, Marantz, DIYMA, and others)
|Tch0rT| is offline
Old 10-03-2015, 02:20 AM
Liked: 1802
Hi, when you will send to eeColor's input a signal that is not supported (resolution or refreshing rate) when it's LED will shutdown and the remote will not work.
When there's active connection with supported resolution/refreshing rate then the LED of it's faceplate will be on and the remote will be working with displaying to your TV the OSD of the active memory, when you will swap the memories buttons from it's remote.
Video Formats supported: 1080p, 1080i, 720p, 720i.
V-Sync Frequency: 24/50/60Hz.
Old 10-03-2015, 02:26 AM
madshi's Avatar
Quoted: 517 Post(s)
Liked: 486
As a workaround: If the eeColor doesn't like your HTPC's output in fullscreen exclusive mode, you can simply load the very same eeColor 3dlut directly into madVR. Would still be interesting to find out what problem the eeColor has in FSE mode. Maybe Direct3D switches to a weird refresh rate or something...
madshi is offline
Old 10-03-2015, 03:26 AM
Quoted: 68 Post(s)
Liked: 6
Could it be a 24 vs 23.976 issue? What graphics card / refresh is causing problems?
bobof is offline
Old 10-03-2015, 03:42 AM
Liked: 1802
Hi, eeColor can pass 24 23.976p or 59.94i/p also.
Old 10-03-2015, 04:06 AM
sillysally's Avatar
Quoted: 873 Post(s)
Liked: 874
eecolor will only go back to the last memory you were using when something changes in the HDMI chain.
If you start running your profile and no conection changes, eecolor will stay on 0.
Yes, if you have a 3DLUT installed in the memory that eecolor changes back from 0, you will have a bad profile.
ss
Old 10-03-2015, 04:16 AM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
I run the eeColor/madVR FSE in 1080p24, 1080p23, 1080p60 and 1080p59 without problems. When entering FSE and there is a display rate change, the eeColor will always reset to "enabled" (indicator not equal to 0). This is a limitation to the eeColor whenever it does an HDMI handshake. To avoid ruining your profile load the 3DLUT_UNITY.txt from the calibration subdirectory to one of your memories and use that for profiling.
zoyd is offline
Old 10-03-2015, 04:48 AM
Quoted: 68 Post(s)
Liked: 6
Interesting - does it always reset to the same profile as it was previously on, or to a specific number (eg 1). Just trying to work out how much I need to automate with my Harmony.
bobof is offline
Old 10-03-2015, 05:24 AM - Thread Starter
zoyd's Avatar
Liked: 1055
zoyd is offline
Old 10-03-2015, 05:25 AM
Quoted: 68 Post(s)
Liked: 6
Thanks, that will be easy to work with. Bit of a silly "feature", though...
bobof is offline
Old 10-03-2015, 05:28 AM
Liked: 1802
Hi, 'Reseting' doesn't mean that you are losing any of your uploaded 3D LUT corrections files.
Old 10-03-2015, 05:30 AM - Thread Starter
zoyd's Avatar
Liked: 1055
yes, the EE people were never interested in working out some of the inconveniences of their firmware.
zoyd is offline
Old 10-03-2015, 05:31 AM - Thread Starter
zoyd's Avatar
Liked: 1055
That's right, just the on/off state is reset.
ConnecTEDDD likes this.
zoyd is offline
Old 10-03-2015, 05:38 AM
Quoted: 68 Post(s)
Liked: 6
What else is there to watch out for, out of interest? No point reinventing the wheel when mine arrives... . I guess losing a LUT slot to the unity LUT is an easy (if a little clumsy) way of giving people the option of either behaviour.
bobof is offline
Old 10-03-2015, 05:41 AM
Liked: 1802
Hi, you can have your own 6 custom memories loaded and when you will need to run a new display profiling, while you connect the meters you can load that time a UNITY LUT to the eeColor.
bobof likes this.
Old 10-03-2015, 05:53 AM
Quoted: 68 Post(s)
Liked: 6
Makes sense. I think I will be able to leave it in permanently anyhow as I only have a couple of different lamp modes / ambient light levels to profile.
bobof is offline
