eeColor processor - ArgyllCMS - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 55Likes
post #571 of 590 Old 01-15-2016, 05:00 PM
gwgill's Avatar
Quoted: 212 Post(s)
Liked: 171
Originally Posted by fhoech View Post
Seems to be a quirk in Argyll CMS 1.8.3. I'm inclined to think the warning has no further implications though.
DispcalGUI shouldn't be using the colprof -f flag for a display - it's only applicable to print profiling.
Yes, I probably added this warning message in V1.8.3. The flag will be ignored.
gwgill is offline
post #572 of 590 Old 01-15-2016, 05:31 PM
fhoech's Avatar
Quoted: 398 Post(s)
Liked: 247
The warning seems to appear irrespective of the -f flag (I think you already fixed this in the 1.8.4 development version of Argyll ).
Code:
Command line:
11:46:22,726   colprof.exe
11:46:22,726     -v
11:46:22,726     -qh
11:46:22,727     -aX
11:46:22,727     -bn
11:46:22,727     -C
11:46:22,729     "No copyright. Created with dispcalGUI 3.0.6.3 and Argyll CMS 1.8.3"
11:46:22,729     -M
11:46:22,729     madVR
11:46:22,730     -D
11:46:22,730     "madVR 2016-01-14 2.35 (absolute) M-S XYZLUT+MTX"
11:46:22,730
11:46:23,273 dispcalGUI: Waiting for EOF
11:46:23,276 Argyll 'V1.8.3' Build 'MSWin 64 bit' System 'Windows V10.0 SP 0'
11:46:23,276 C:\Users\Sillysally\AppData\Roaming\Argyll_V1.8.3\bin\colprof.exe: Warning - -f
11:46:23,276 FWA compensation ignored for emissive reference type
DisplayCAL - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 3.1.4 released 2016-07-11
Previous development snapshot (OUTDATED): 3.1.3.2 Beta (Windows/0install) released 2016-04-23 | Standalone | Changelog
DisplayCAL on Facebook
fhoech is offline
post #573 of 590 Old 01-15-2016, 06:01 PM
gwgill's Avatar
Quoted: 212 Post(s)
Liked: 171
Sorry - yes, you are quite right.
gwgill is offline
post #574 of 590 Old 01-17-2016, 02:46 PM
fhoech's Avatar
Quoted: 398 Post(s)
Liked: 247
Originally Posted by 10k View Post
I've never been able to upload a ccss file to the website from inside dispcalgui either. It just gives a generic error like "unable to connect"
Are you using a 3rd party firewall? The most recent CCSS file was uploaded some hours ago, so I can confirm it's working.
fhoech is offline
post #575 of 590 Old 02-21-2016, 11:13 AM
wl1
wl1's Avatar
Quoted: 73 Post(s)
Liked: 51
Eecolor - is it normal for the eecolor to raise black levels by just being connected.
wl1 is offline
post #576 of 590 Old 02-21-2016, 11:28 AM
-Hitman-'s Avatar
Quoted: 134 Post(s)
Liked: 106
Probably because it comes pre-loaded with LUTs, you need to either press the eeC off button (display shows 0) or load up unity lut/s.
-Hitman- is offline
post #577 of 590 Old 02-21-2016, 11:42 AM
wl1
wl1's Avatar
Quoted: 73 Post(s)
Liked: 51
Yes, I have been using it for a while. I haveUnity LUT stored, and switching it OFF is the same. But Black levels are higher than when the unit is not in the circuit. I.e. I set the Projector Brightness to 50 to se 16 on the black bar tests. With eecolor in circuit, I can reduce the Brightness value to as much as 34.
Doesn't seem right. I have it out of the circuit at the moment.
wl1 is offline
post #578 of 590 Old 02-21-2016, 01:21 PM
10k
10k's Avatar
Quoted: 1006 Post(s)
Liked: 818
Sounds like an issue with mismatched hdmi levels. Somewhere in the chain you have mismatch of 0-255 and 16-235. Is the eecolor 0-255 only? And the rest of your components are set to 16-235?
Calibrated settings for: Sony x930d (update: 4/8/16) | LG 65EF9500
4k60hz fanless HTPC build
10k is offline
post #579 of 590 Old 02-21-2016, 02:30 PM - Thread Starter
zoyd's Avatar
Quoted: 1285 Post(s)
Liked: 1027
With a unity LUT loaded it passes everything as-is so it doesn't matter if you use PC or video levels it should be transparent. If it's lifting levels and you are sure you have a unity 3D LUT loaded then it must be the 1d LUTs. These can also be reset to unity using either CalMAN or the truvue app.
10k likes this.
zoyd is offline
post #580 of 590 Old 02-21-2016, 03:05 PM
wl1
wl1's Avatar
Quoted: 73 Post(s)
Liked: 51
Ok, I'll have to give this another go. My HDD failed on the PC, and I lost the LUT files. I think I'll start again. Thanks for the help....
wl1 is offline
post #581 of 590 Old 03-03-2016, 04:18 AM
wl1
wl1's Avatar
Quoted: 73 Post(s)
Liked: 51
Hmm. If the output from the other sources does not match the HTPC, then this may introduce errors. Could still be better than no 3D LUT though.
Yes.
You can just create the 3D LUT from the existing profile. To do that, make sure the profile is selected under "Settings", then go to the 3D LUT tab and disable "Create 3D LUT after profiling". The button at the bottom will change to "Create 3D LUT", but change 3D LUT format to eeColor before clicking it.
Edit: I think I misunderstood your question. I think meter profiles from HCFR cannot be used directly with dispcalGUI or Argyll, but you can duplicate an existing correction file and overwrite the values by hand if you dare.
The instructions are a little outdated. When creating a new profile, you can start from the "Video 3D LUT for eeColor" preset under "Settings". Change the amount of patches via the slider on the "Profiling" tab if desired, and set the desired tone curve on the "3D LUT" tab if you don't want to target BT1886.
Plasma, OLED, anything with variable light output depending on picture content (typically not LCD).
I am daring to use the i1 Display Pro correction files attached - how do I go about this with DispCAL?
Name:	meter profile annotated.jpg
ID:	1291369   Click image for larger version
wl1 is offline
post #582 of 590 Old 03-13-2016, 12:32 PM
wl1
wl1's Avatar
Quoted: 73 Post(s)
Liked: 51
Maybe there is no easy way to use a correction file for my meter. Has anyone got experience in the correction files - to put the errors into perspective?
It all takes a while to complete the process - ideally doing it with the best accuracy. Any help appreciated,
wl1 is offline
post #583 of 590 Old 03-13-2016, 12:46 PM
fhoech's Avatar
Quoted: 398 Post(s)
Liked: 247
Here you go (unpack & drag & drop the CCMX file on the main window). This is the 4-color matrix version from the XLS.
File Type: zip wl1.zip (455 Bytes, 14 views)
fhoech is offline
post #584 of 590 Old 03-13-2016, 01:13 PM
wl1
wl1's Avatar
Quoted: 73 Post(s)
Liked: 51
That has gone in OK. I assume that has to be selected before the run? I ask, because it took me a while to realise I could create multiple 3DLUTs from the same data. D'oh.
Thanks for the file :-)
Wayne.
wl1 is offline
post #585 of 590 Old 03-13-2016, 01:19 PM
fhoech's Avatar
Quoted: 398 Post(s)
Liked: 247
Yes.
wl1 likes this.
fhoech is offline
post #586 of 590 Old 03-16-2016, 11:37 AM
Vaan Janne's Avatar
Quoted: 39 Post(s)
i don´t quite get the color correcting thingy.
I have i1 display pro colorimeter
and i1 pro spechtrometer.
if i understood correctly i need to make a correcting file with the i1 pro for the i1 display pro to measure and calibrate my projectors ?
this is done how ?
one other thing, i have color temp mode on my HC5´s kelvins from 5800 -> 9800 and user.
when launching displaycal and the measurement meter should i use the user color settings to get the RGand Blue balanced ? i can, by lowering the gains but should i ?
there is red green blue gain settings and offset setting.
what about the bright. We are talking about my dual projectors passive rig. The other filtter eats up ligh so the light value on
other is 2 on other little over 4 . Should i try to bring it closer with the adjustable iris ? that ofcourse affects the black but on the
other hand there is already filtter plus glasses in between the eye and the projector so the blacks are needed to push up on both.
Let´s say i now have the 2 3dLUT files. one from each projector. How do i manage to get a target that both projectors can do ?
or can i just try to target one of a another untill they match and how do i do that ?
-J
Vaan Janne is online now
post #587 of 590 Unread 05-13-2016, 05:56 AM
Quoted: 31 Post(s)
Liked: 1
I've recently acquired a Lumagen XE-3D, and am interested to test how the 5x5x5 3D LUT compares to the EEColor.
I can generate 3DLUT for the Lumagen via Chromapure Professional with advanced autocal (which I have), and for the EEColor via dispcalgui. I don't have Lightspace, which I guess I could use to generate for both from the same set of measurements.
Question - is it possible to get ArgyllCMS to manually output a 5x5x5 table that I could load into the Lumagen unit? Lumagen have a published serial interface for setting the table values, so I could manage to get them in, if I just had the table.
I do recall reading somewhere that perhaps @gwgill had a Lumagen unit and was looking at adding support to ArgllCMS, but can't find any real detail on it.
bobof is offline
post #588 of 590 Unread 05-13-2016, 09:50 AM
sillysally's Avatar
Quoted: 779 Post(s)
Liked: 814
I talked to Jim Peterson from Lumagen over a year ago and asked him to send a Lumagen to gwgill, he did.
Ask gwgill about 3 months ago if he was going to add support for the Lumagen. He said "That's the plan".
ss
bobof likes this.
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #589 of 590 Unread 05-15-2016, 07:54 PM
gwgill's Avatar
Quoted: 212 Post(s)
Liked: 171
It's still at the top of my "to do" list.
Due to financial necessity, other tasks are currently taking priority.
bobof likes this.
gwgill is offline
post #590 of 590 Unread 05-16-2016, 10:44 AM
Quoted: 31 Post(s)
Liked: 1
I'll be very happy to give it a whirl when something is available. Are you planning on supporting the built-in pattern generator and direct 3DLUT download to the unit?
bobof is offline
Reply Display Calibration
