CalMAN 5 Tutorial for Novice Calibrators - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #31 of 140 Old 02-05-2014, 07:32 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
Originally Posted by rrussell50 View Post
So it is ok to have a DeltaL of 1 Delta -11.4 and a DeltaH -0.2 ? Or should I continue adjusting until I get the DeltaC lower?
Nope sounds like you've done your best.
If the TV is undersaturated, like yours is, there is nothing you can do to increase the saturation.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #32 of 140 Old 02-05-2014, 09:04 AM
Quoted: 108 Post(s)
Liked: 49
I want to calibrate my Epson 8700ub would this work.
jsil is offline
post #33 of 140 Old 02-05-2014, 09:52 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
The C3 isn't designed for use with projectors, you'd need an i1 Display Pro at a minimum to calibrate a projector. Other than that CalMAN tutorial or basic can walk you through calibration.
Joel Barsotti
SpectraCal
sotti is offline
post #34 of 140 Old 02-06-2014, 10:23 AM
rrussell50's Avatar
thanks, one last question, what should my goal be for setting gamut luminance under CMS? I know your workflow does not have it but I had seen it on a custom workflow and was wondering what the goal was for gamut luminance
thanks
rrussell50 is offline
post #35 of 140 Old 02-06-2014, 11:15 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
thanks
Gamut Luminance is just another way of looking at detlaL, you can look at gamut luminance in absolute terms, green's target is 72%, or in a relative way where the target is 0%.
It's just different ways of visualizing the same information.
Joel Barsotti
SpectraCal
sotti is offline
post #36 of 140 Old 02-07-2014, 08:25 PM
jwertz10's Avatar
This might be a stupid question but how does step 5 change if I don't have a 10 point white balance control on my Samsung? I do have an independent gamma control though. So do I still follow the first part of step 5 and take all of the readings regardless, just to see my unadjusted gamma curve and then just use my gamma control to set it as close as possible to 2.2? Or can I not even take those initial readings you mention without a 10 pt control? And if not, how do I go about adjusting my gamma?
jwertz10 is offline
post #37 of 140 Old 02-16-2014, 01:40 AM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
Great post! So why do plasmas need the Window instead of Field patterns? And if you only do a 2pt, can you choose absolute or does it have to be on relative greyscale?
ZKACAL is offline
post #38 of 140 Old 02-16-2014, 07:38 AM
chunon's Avatar
Quoted: 2253 Post(s)
Liked: 1975
Window patterns are used to mitigate ABL(auto brightness limiter), you can choose either absolute or relative but absolute factors in gamma in the de calculation.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #39 of 140 Old 02-16-2014, 09:43 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
Plasma Displays start to dim, the more fully lit pixels it displays. Using windows minimizes this dimming. Using constant APL patterns is even a step better.
If you are only doing a 2 point, you only have relative control, so we'd recommend only looking at relative RGB balance.
Joel Barsotti
SpectraCal
sotti is offline
post #40 of 140 Old 02-18-2014, 03:01 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
Sweet
ZKACAL is offline
post #41 of 140 Old 02-19-2014, 01:57 AM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
Just completed first calibration using C3 meter with Calman 5 Tutorial Advanced. I only did a 2pt calibration because I couldn't understand the multi point instructions. Or maybe I couldn't adjust them on my TV. But despite that, only 50% and 90% were above 3. However I was able to fully adjust my color. Other than graph properties and advanced settings under the options, I am missing the fL reading. But my TV doesn't have a cell light option, it had a panel brightness option. Luckily my gamma was 2.2 so I think I did a decent job.
For the fL reading which Calman do I need to upgrade to?
ZKACAL is offline
post #42 of 140 Old 02-23-2014, 11:26 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
"Now, click over to workflow advanced options. We want to leave these at default, including use measured white level (we want to set our gamma based on the white level your meter actually measures), and leave target black at 0."
Why do we leave target black at zero?
ZKACAL is offline
post #43 of 140 Old 02-24-2014, 04:51 AM
chunon's Avatar
Liked: 1975
^^^That really depends on your meter and the display you are calibrating, if the mll of the display exceeds the limits of your meter then you would want to specify the reported mll instead of the measured black level
65C6 OLED
post #44 of 140 Old 02-24-2014, 07:14 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
OK so if one only owns a C3 meter, should the workflow settings be left at default? And is there a way to reset the settings without having to reinstall CalMAN?
ZKACAL is offline
post #45 of 140 Old 02-24-2014, 10:23 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
All the important settings should load with the workflows, unless you overwrote the original workflows (which would require changing their readonly status).
For PC calibrations we use sRGB as the EOTF (electro-optical transfer function) since it is the part of the color standard for the internet. The sRGB EOTF basically has a black offset baked into the formula since it came from a time when meters couldn't measure black level. For Home Theater calibration we recommend using BT.1886, which is designed to use the displays actual black level as part of the formula. For HT workflows the EOTF (gamma formula) should be set to BT.1886 and the black level setting to "use measured".
Joel Barsotti
SpectraCal
sotti is offline
post #46 of 140 Old 02-26-2014, 09:47 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
Why is it that when I select BT.1886 the target level for gamma becomes 2.4 in the workflow? You know the yellow target line is around 2.4. Am I just supposed to ignore it and aim for 2.2?
And I've set black level to "use measured" just like the white level.
ZKACAL is offline
post #47 of 140 Old 02-26-2014, 09:50 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
The formula uses the measured black level and white level.
Once you measure 0% and 100% you'll get the target curve for your display.
Joel Barsotti
SpectraCal
sotti is offline
post #48 of 140 Old 02-26-2014, 10:04 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
OK so if the target curve says 2.4 for instance. Your TV may be set to 2.2 gamma but the meter's reading find it too low, so you have to bump it up to meet the target curve?
So CalMAN tells you to make it 2.4 so that it will really look like 2.2 because your TV is incorrect?
ZKACAL is offline
post #49 of 140 Old 02-26-2014, 10:06 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
BT.1886 isn't a single number. It's a transfer function.
If you have 0.0 for your black level, then it's exactly 2.4, but your TV's black level isn't 0. So do a series read, see what numbers it pulls in, then calibrate from there. Make sure the data points you have selected include a 0% reading, otherwise, you'll need to manually enter your black reading.
Joel Barsotti
SpectraCal
sotti is offline
post #50 of 140 Old 02-26-2014, 10:27 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
If the TV only has a 2pt then you only adjust gamma if needed. If the TV has a 10pt, do you adjust the grays first or the gamma first?
Edit: Just read through Marvin's post. He said to adjust gamma first then tweak it with the grayscale.
ZKACAL is offline
post #51 of 140 Old 02-26-2014, 10:44 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
What TV do you have?
Do brightness and contrast first.
With 2 point, you only worry about white point, do that first.
If you have a gamma control adjust that to get the closest fit.
Double check brightness and contrast, double check 2 point.
Then do 10 point. Technically a 10 point should only have RGB controls, so they all go up or down to get gamma correct. Panasonic in all their wisdom did it differently, so you really have to adjust all 4 at the same time for each point. I mean obviously you can only adjust one control at a time, but you'd check and then maybe gamma comes down a click and blue goes up a click.
But make sure to read your black and white points to set your BT.1886 curve before you dive into the adjustments.
Joel Barsotti
SpectraCal
sotti is offline
post #52 of 140 Old 02-27-2014, 04:17 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
I have multiple TVs in the house but I am starting out with Panasonic tc p50s60 calibration because that is my gaming TV (very low input lag).
When you say adjust gamma to get the closest fit, you mean making it meet the target line? Even if the target is not 2.2?
Last time I did a calibration on the same TV, with the default workflow settings, the gamma was 2.2 with dE of 0.7 I believe but the BT. 1886 formula was telling me to set gamma at 2.4. That is the only thing I am confused about.
ZKACAL is offline
post #53 of 140 Old 02-27-2014, 04:20 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
I don't know any other ways to talk about this.
Read black, read white, you'll get something that isn't a flat line, calibrate to that.
ZKACAL likes this.
Joel Barsotti
SpectraCal
sotti is offline
post #54 of 140 Old 02-27-2014, 04:25 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
Cool. I will post my results when I'm done. Thanks for the help.
ZKACAL is offline
post #55 of 140 Old 03-11-2014, 08:12 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
I was having trouble with the BT.1886 because my C3 can't read the darkest gray or 0%. I will have to upgrade my meter once it shifts.
ZKACAL is offline
post #56 of 140 Old 03-15-2014, 12:33 AM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
How do you delete saved sessions from CalMAN?
ZKACAL is offline
post #57 of 140 Old 03-15-2014, 05:42 AM
prsut's Avatar
Liked: 57
Go into C:\Users\name_of_user\Documents\SpectraCal\CalMAN 5 Home Theater\CDFs, find session and delete using windows explorer (total commander etc...)
ConnecTEDDD likes this.
Panasonic TX-P42GT50E, Oppo 103, Schiit Vali, Denon AHD2000 + Moon Audio Blue Dragon V3, Phonak Audeo 121, Vsonic GR07, Fiio E17, Cowon S9, XLO cables :: CalMAN 5 Enthusiast,Chromapure Standard, i1D3, i1Display 2, TED's Calibration Blu Ray Disc v1.0 & v1.1
prsut is offline
post #58 of 140 Old 03-15-2014, 03:04 PM
ConnecTEDDD's Avatar
Quoted: 1246 Post(s)
Liked: 1761
Correct, but if you delete all files there, you will still see your sessions @ CalMAN's list when you will click to load a saved session.
This bug has been reported from 2012, it's still unfixed.
PlasmaPZ80U likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #59 of 140 Old 03-15-2014, 03:17 PM
PlasmaPZ80U's Avatar
Quoted: 1999 Post(s)
Liked: 570
I agree it should be fixed.
Current Setup REW measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #60 of 140 Old 03-16-2014, 04:24 AM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
I did this but now I can't even open the sessions I that didn't delete. However, all the sessions still show up like Ted said.
ZKACAL is offline
Reply Display Calibration
