CalMAN 5 Tutorial for Novice Calibrators - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #61 of 140 Old 03-16-2014, 05:39 AM
ConnecTEDDD's Avatar
Quoted: 1246 Post(s)
Liked: 1761
Originally Posted by ZKACAL View Post
Originally Posted by prsut View Post
Go into C:\Users\name_of_user\Documents\SpectraCal\CalMAN 5 Home Theater\CDFs, find session and delete using windows explorer (total commander etc...)
I did this but now I can't even open the sessions I that didn't delete. However, all the sessions still show up like Ted said.
Another simple thing also which must be fixed also... when you want to open 'Find Calibration Session'', the CalMAN does not remember the last directory path you used/had, and you have to go through all your drives/folders one by one each time you want to open a File from the same folder.
For example I have 10 saved sessions files saved to another harddrive inside to one folder and each time i want to open each file I have to locate each time that folder, going through every folder one-by-one...
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #62 of 140 Old 03-16-2014, 07:29 AM
prsut's Avatar
Liked: 57
Seems like CalMAN uses sqllite database for storing sessions located here :
!C:\ProgramData\SpectraCal\CalMAN 5 Home Theater\Data
file name is
"Calibrations.s3db"
ConnecTEDDD likes this.
Panasonic TX-P42GT50E, Oppo 103, Schiit Vali, Denon AHD2000 + Moon Audio Blue Dragon V3, Phonak Audeo 121, Vsonic GR07, Fiio E17, Cowon S9, XLO cables :: CalMAN 5 Enthusiast,Chromapure Standard, i1D3, i1Display 2, TED's Calibration Blu Ray Disc v1.0 & v1.1
prsut is offline
post #63 of 140 Old 03-16-2014, 07:50 AM
tucsondave's Avatar
Since we're on the subject or sessions and reports....
I asked this on the Spectracal forum but got no reply.
Why doesn't Calman 5 store the Meter, Source, and Processor info when you save a session?
Or am I doing something wrong?
thanks,
td
tucsondave is offline
post #64 of 140 Old 03-16-2014, 12:06 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
thanks,
td
When I load up calman with my meter plugged in, my meter and blu-ray source show up automatically. I haven't used a DDC yet.
ZKACAL is offline
post #65 of 140 Old 03-16-2014, 12:17 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
thanks,
td
It's just a design decision. For everyone who wants it to work one way, some else wants it to work the other.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #66 of 140 Old 03-16-2014, 02:10 PM
tucsondave's Avatar
Right. It loads whatever meter (or simulated meter) is connected. But what if you want to compare a session done with one meter against one done with another in the past? Or print out the charts without having to connect everything.
td
post #67 of 140 Old 03-16-2014, 05:37 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
td
The reports do store the hardware that was connected at the time.
Joel Barsotti
SpectraCal
sotti is offline
post #68 of 140 Old 03-17-2014, 07:32 AM
hidefpaul's Avatar
Quoted: 124 Post(s)
Liked: 79
Hello,
I was wondering if anyone could help me out.
I am using Calman 5 with a i1Pro meter on a 60" Kuro (no CMS, just a colour slider and a tint slider - for adjustments). I wanted to compare the colour accuracy of my "user" mode vs my "standard" mode. Both modes had been previously calibrated with the color and tint adjusted by use of the color/tint pattern on Spears & Munsil disk using the blue filters.
Yesterday I fired up Calman 5 and went to the "Quick Analysis" template and opened "Colour Checker".
When I compared both my "standard" vs "user" modes it was obvious that the user mode was the most accurate..... I had all colours with errors below 3 with the exception of green and magenta with were just over 5.
So, sticking with the "User " mode, I decide to adjust the colour and tint slider to the 0 position and re- took the readings again. NOW, I saw even better results across all colours.
Leaving the colour and tint slider at 0, I put the S&M colour and tint pattern up and decided to check the pattern again using the blue filter. Reading the colour and tint with the blue filter it was apparent that it was off by +2 on colour and Red3 on tint.
So what do I trust the S&M blue filters or Calman colour checker??
Any insight would be great.
Paul
5.1 Home Theatre
Pioneer 60" Kuro
Integra DHC 80.3 Pre Amp
Parasound Halo A51 5 Ch Amp
Speakers : Elac's FS-247's (L,C,R SR, SL)
Sub: Velodyne SPLR1000
hidefpaul is offline
post #69 of 140 Old 03-17-2014, 09:13 AM
chunon's Avatar
Quoted: 2253 Post(s)
Liked: 1975
Calman is alot more accurate, color filters should only be used if you don't have a meter.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #70 of 140 Old 03-17-2014, 09:31 AM
hidefpaul's Avatar
Quoted: 124 Post(s)
Liked: 79
Thanks chunon, I have read that using the blue filters is not a very accurate way to adjust colour/tint for the most part. I just wanted to share/confirm my findings and make sure that I could leave my settings as they are now.
Paul
5.1 Home Theatre
Pioneer 60" Kuro
post #71 of 140 Old 05-14-2014, 01:25 AM
Nico Giraldi's Avatar
Hi, first of all thank you for your useful walkthrough. I subscribed to this forum because I have a big issue with the AVS HD pattern disc: the chapter and title of test pattern asked for by calman 5 tutorial doesn't match with those on on the pattern disc. Please help me.
Nico Giraldi is offline
post #72 of 140 Old 05-14-2014, 04:20 AM
chunon's Avatar
Liked: 1975
What kind of display are you calibrating ? LCD or Plasma ?
65C6 OLED
post #73 of 140 Old 05-14-2014, 05:47 AM
prsut's Avatar
Liked: 57
get Ted's calibrations disc. I think it is free, you will pay some bucks for postage :-)
prsut is offline
post #74 of 140 Old 05-14-2014, 03:12 PM
Liked: 1761
Hi, try to watch these calibration videos:
http://color.spectracal.com/calibration-videos
post #75 of 140 Old 05-30-2014, 04:14 AM
pavloPL's Avatar
Thank you mate, thanks to you I have done my 1st calibration and saved a lot of time for learning! I am very pleased with my results biggrin.gif
Sony ZD9 75", Anthem MRX 1120, Dali Zensor 7.1.2, Panasonic UB900 Ultra HD player, Xbox One S, PS4, Apple TV 3, iDisplay Pro3, Calman 5
pavloPL is offline
post #76 of 140 Old 05-30-2014, 08:53 AM - Thread Starter
Mavinwow's Avatar
Quoted: 416 Post(s)
Liked: 473
Samsung 55ES8000
Vizio 70 P Series, Calibration settings
CalMAN 5 Novice Walkthrough
Denon X4200, 5.1.4 setup
Mavinwow is offline
post #77 of 140 Old 06-24-2014, 02:11 PM
Y2JDMBFAN's Avatar
Quoted: 666 Post(s)
Liked: 226
How bad is the original i1Pro? i still have one, and was going to use it on my new XBR-65X900B, but I have been reading that I shouldn't be using a spectrometer for calibration anymore. Wondering is the Spectra Cal Colorimeters are really going to be that much better...
Y2J
Y2JDMBFAN is offline
post #78 of 140 Old 06-24-2014, 02:26 PM
Rolls-Royce's Avatar
Quoted: 265 Post(s)
Liked: 405
Y2J
Where in the world have you been reading this? By all means, get a colorimeter, but use your I1Pro to profile the colorimeter to your display. You'll have the accuracy of the spectro with the low-light sensitivity and speed of the colorimeter.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #79 of 140 Old 06-24-2014, 02:32 PM
Quoted: 265 Post(s)
Liked: 405
Nico, I haven't used the AVS HD disc with CalMAN in quite some time, but at one time you needed a specific version of the disc. CalMAN would make its pattern calls based on that particular version, and newer AVS HD versions didn't match up. I believe 1.3 is the needed version of the disc.
...Royce...
post #80 of 140 Old 06-24-2014, 02:37 PM
Y2JDMBFAN's Avatar
Quoted: 666 Post(s)
Liked: 226
Well, I guess I meant, can I use the i1pro and Calman5 with reasonably good results? Is the only pitfall of the spectrometer the low light measuring abilities?
post #81 of 140 Old 06-24-2014, 03:39 PM
mjodotcom's Avatar
Quoted: 14 Post(s)
Originally Posted by sotti View Post
Quote:Originally Posted by ZKACAL
Great post! So why do plasmas need the Window instead of Field patterns? And if you only do a 2pt, can you choose absolute or does it have to be on relative greyscale?
Plasma Displays start to dim, the more fully lit pixels it displays. Using windows minimizes this dimming. Using constant APL patterns is even a step better.
If you are only doing a 2 point, you only have relative control, so we'd recommend only looking at relative RGB balance.
Does anyone have particularly good APL patterns they recommend using? I have heard the AVS709 ones aren't the best for Panasonic plasmas as an example...?
mjodotcom is offline
post #82 of 140 Old 06-24-2014, 08:13 PM
Quoted: 265 Post(s)
Liked: 405
Pretty much. There are some displays with very spiky spectral characteristics that I1Pros have issues with, but for most CRT, plasma, LCD, they work well. When it comes to doing the current 3D cube LUT calibrations featuring hundreds or thousands of readings, profiled colorimeters are preferred for their measuring speed and for the fact that they don't require repeated dark readings the way that the I1Pro does.
...Royce...
post #83 of 140 Old 06-26-2014, 12:17 PM
chunon's Avatar
Liked: 1975
Something in the 5% to 7% range works best IMO, hard to find that size on a disk for Calman. Mascoir's disc has the patterns you need but it optimized for Chrompure. Not sure what software you have ?
65C6 OLED
post #84 of 140 Old 07-04-2014, 05:53 PM
cardoski's Avatar
Quoted: 1263 Post(s)
Liked: 1255
Just got Calman today, been using HCFR with an i1 display pro up until now. I am curious how I can hook my OPPO 103 BD player to my PC for automation when calibrating. I use the AVSHD 709 disc with it.
It's always in the last place you look.
cardoski is offline
post #85 of 140 Old 07-04-2014, 07:42 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
You got to use a USB or wifi connection.
ZKACAL is offline
post #86 of 140 Old 11-18-2014, 08:37 AM
Liked: 0
Originally Posted by Mavinwow View Post
Glad you found it helpful
Thx very helped me to calibrate my sony 55W829B
marcins is offline
post #87 of 140 Old 04-05-2015, 04:26 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
CalMAN 5 Walk-Through for Dummies/Novice Calibrators
Author: Mavin
Our Gamut Target should be default set to D65 HD Rec709, which is what we want. Gamma is somewhat more controversial. By default CalMan is set to a power gamma of 2.2. You will read arguments for setting this anywhere from 2.2-2.4, I have been using 2.25 based on several forum posters.
By now you should be getting the hang of how all this works. In the AVS709 disc, navigate to the 75% patterns. It will first pull up 100% white, take a reading, then 75% white, take a reading. You will not make any adjustments yet as you should already have dialed in your white balance on the last few steps. Now, pull up the 75% red page, and click your red box in CalMAN, take a reading.
Very nice tutorial Mavin! Just one question. On the Advanced settings screen at the top of this quote, the saturation level is set to 100% but then down in the CMS calibration you're using 75% patterns. Does the 100% Saturation here refer to these color patterns or something else? Thanks again for such a great walk-thru.
EDIT: Is it possible to show the x y Y Y Target values as shown in the attached pic in Calman Control or do you need a different version?
Name:	b3fb827d_JVC_X55R_low_standard_24_color_color_manual_AVSHD_3_30_2014_zps848ad83e.png
jkasanic is offline
post #88 of 140 Old 04-06-2015, 12:51 AM
Liked: 1761
Hi, the 100% Color Patterns have 100% Saturation with 100% Stimulus Level while the 75% Color Patterns have 100% Saturation with 75% Stimulus Level.
It's the specific workflow that it's not giving that specific data you want to see. But you can customize it. (not sure if it will work with Tutorial License)
To the Quick Analysis Workdflow, do to the layout page you want to change the chart you are interested and open the properties panel.
Now click to that icon to dock that panel.
Now with right mouse button click to inside to the Datagrid Chart and it will display you the Datagrid Properties.
Now tick the Target_x, Target_y and Target_Unit_Y.
jkasanic likes this.
post #89 of 140 Old 04-06-2015, 02:15 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
That makes sense.
Quick Analysis Workflow is something I hadn't experimented with yet. That's exactly what I wanted to see. I was concerned because it seemed like everyone that was displaying this info was using Enthusiast or some higher version and I only have Control and wasn't sure it was available.
Thanks for your help!
jkasanic is offline
post #90 of 140 Old 06-02-2015, 06:12 AM
mkoreiwo's Avatar
Quoted: 12 Post(s)
I just began calibrating my HU8550 and have both the Get Gray, and AVSHd discs.
I noticed that the Get Gray grayscale patterns are much 'brighter' than the ones on the AVSHD disc. The 0% on the Get gray is clearly visible as a grayish area, while 0% on the AVSHD disc is black....
I am wondering why the big difference. For now I will be using the AVSHD disc.... i have used that in th east with good results, but many people swear by the Get Gray disc.
Has anyone else had this sort of thing happen?
Thanks all.
mkoreiwo is offline
Reply Display Calibration
