CalMAN 5 Tutorial for Novice Calibrators - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #121 of 140 Old 09-15-2016, 02:51 PM
slackmack's Avatar
Quoted: 17 Post(s)
Originally Posted by sotti View Post
I believe serial cables are good for almost 50 ft.
USB cables OTOH are only suppose to do 15ft or so.
YMMV
Ok. Thanks.
slackmack is offline
post #122 of 140 Old 09-15-2016, 11:59 PM
chrisc0le's Avatar
Liked: 0
On the CMS page they should have an RGB chart.
So if Red is high and Green and blue are low, lower red and raise green and blue. You may find that there is residual error even when a control is maxed out. That is just a display limitation and not something you can fix.
Thanks Sotti, so basically the aim is to reduce the RGB bars as close to '0' as possible.
chrisc0le is offline
post #123 of 140 Old 09-16-2016, 06:03 AM
Tom899's Avatar
Quoted: 89 Post(s)
Liked: 27
I ended up ordering CalMAN Enthusiast with a C6 HDR meter.
I see the tutorial in the first post, which looks very good! Thanks! is from 2013.
I'm new and a beginner with this software so wondering if it is still valid and up to date for me to use? I want to calibrate my Sony 40ES projector.
I bought CalMAN and an inexpensive meter back in 2009 but could not figure it out and it sat in a drawer. I would really like to put all my effort into it this time around.
-Tom
Tom899 is offline
post #124 of 140 Old 04-02-2017, 07:00 AM
Liked: 0
My TV is a Samsung 46f5500 and using Calman 5 Control and a Xrite I1 display pro retail.
Hi I just finished calibrating and here is the post calibration. Can someone tell me whats else needs fixing and how? Cause I think some of the deltae for some of the colors are high and most of the circles are not inside the box. Thanks.
protege888 is offline
post #125 of 140 Old 04-02-2017, 10:56 AM
chunon's Avatar
Quoted: 2248 Post(s)
Liked: 1970
Does your set have a CMS ? if so use that to minimize the color errors , otherwise use your color control to minimize error for primaries tint to minimize error for secondaries.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #126 of 140 Old 04-02-2017, 03:56 PM
Liked: 0
my tv doesnt have cms
post #127 of 140 Old 04-02-2017, 04:37 PM
chunon's Avatar
Liked: 1970
you can use color and tint then to reduce the errors
65C6 OLED
post #128 of 140 Old 04-04-2017, 04:08 AM
Liked: 0
what colors are the primaries and secondaries? thanks
post #129 of 140 Old 04-04-2017, 04:20 AM
ConnecTEDDD's Avatar
Quoted: 1242 Post(s)
Liked: 1761
Hi, these charts can help you:
Saturation:
Luminance:
Hue:
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #130 of 140 Old 04-04-2017, 04:49 AM
Liked: 0
post #131 of 140 Old 04-04-2017, 04:50 AM
chunon's Avatar
Liked: 1970
red green and blue primaries cyan magneta and yellow secondaries .
65C6 OLED
post #132 of 140 Old 04-04-2017, 05:54 AM
Liked: 0
Based on my pic above which colors needs fixing? Also the primaries should be in the box more than the secondaries?
post #133 of 140 Old 04-04-2017, 06:09 AM
chunon's Avatar
Liked: 1970
your 2 biggest errors are green and cyan. I would try dropping color one or two clicks and move tint towards green. see what that does overall to your errors. does the control version of calman have a mms screen ? If so post your readings from there.
65C6 OLED
post #134 of 140 Old 04-04-2017, 06:36 AM
Liked: 0
what is a mms screen? how can screen capture from calman?
post #135 of 140 Old 04-04-2017, 07:21 AM
chunon's Avatar
Liked: 1970
Sorry typo CMS
65C6 OLED
post #136 of 140 Old 04-04-2017, 09:28 AM
Liked: 0
here is my cms
post #137 of 140 Old 04-04-2017, 09:49 AM
chunon's Avatar
Liked: 1970
here is my cms
Sent you a pm
65C6 OLED
post #138 of 140 Old 04-11-2017, 09:30 PM
lovswr's Avatar
Quoted: 43 Post(s)
Send a message via AIM to lovswr
Just purchased Calman 2016 Control for Home Video. I take it that the AVS709 disc(or any disc at all!) is no longer able to be used as I find no option for Pattern Disc to be selected under source. As a matter of fact, other than manual, all of the options appear to be some kind of external pattern generator. Is this correct?
edit: So I discovered MobilForge. I'll see how this works.
carry on with your HD-Lite Directv loving banter! <--Comedy Gold
Don't fall for the HDMI 1.3 Hype!
PSN = lovswr
XBOX Live = lovswr
lovswr is online now
post #139 of 140 Old Today, 12:41 PM
Liked: 1761
Hi, there no problem to use any calibration disk without selecting anything to the pattern source window of calman.
This function was related with the capability of CalMAN to control your dvd player remote and send commands to go to next chapter etc. using an external IR transceiver the user had to buy for about $100 and configure it according to his brand of player, so CalMAN was sending next or previous chapter commands via IR to the player and CalMAN was measuring Grayscale for example without user prompt....but the supported disks had no correct pattern order for CalMAN 5.
I have posted about this here: Ted's LightSpace CMS Calibration Disk
There is mismatch of Grayscale patches AVSHD has when it's been used from CalMAN users, see more details here: What is the best calibration disc???
post #140 of 140 Old Today, 03:56 PM
lovswr's Avatar
Quoted: 43 Post(s)
Thanks for the info, Ted.
PSN = lovswr
XBOX Live = lovswr
Reply Display Calibration
