Ps3-Onkyo nr609- samsung un55es7100 - AVS Forum | Home Theater Discussions And Reviews
Old 03-30-2013, 08:00 AM - Thread Starter
droseofc's Avatar
Quoted: 12 Post(s)
Before I get the link to the ps3 settings i promise I've looked plus countless others. I am trying to calibrate this Samsung with the ps3 as main source and I've got about 50/50 results on what to use. First of all, I'm running the ps3 via hdmi to onkyo which is then running to tv via hdmi direct or pass through basically untouched mostly, I've noticed when I am playing a game regardless of what settings i have ps3 on when I press info on the onkyo it shows RGB 36 bit in and out. Same thing with a blu ray movie except Ycbcr 36 bit. So ideally if that's the case shouldn't I calibrate it for a game mode using the settings on ps3 rgb full and hdmi level normal on tv and a designated movie mode using the super white funtion to on via the ps3 being that once the Ycbcr 36 bit is being directly fed from the ps3 to the tv the hdmi level is grayed out as is rgb level on ps3. I'm not an expert but to me it'd make sense to have it calibrated for the mode its pushing through. To my understanding from numerous forums and guidelines if the tv supports it then it is better to use rgb full with hdmi level to normal.
droseofc is offline
Old 03-30-2013, 06:07 PM - Thread Starter
droseofc's Avatar
Quoted: 12 Post(s)
droseofc is offline
Old 03-30-2013, 06:39 PM
willieconway's Avatar
Quoted: 121 Post(s)
Liked: 130
Paragraphs are your friends. I have a very similar setup to yours and should therefore be able to follow but I had to read your post several times to find out what you were asking. Break it up to make it easier to read.
Here's a discussion of calibration for video games: http://www.avsforum.com/t/1412468/should-i-use-calibrated-preset-for-tv-channels-and-videogames.
PS3 picture settings info: http://www.avsforum.com/t/931796/official-ps3-faq-master-thread#user_video
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D. Currently boxed up: Denon 1713, Klipsch SW-450,
NHT Absolute Center, Energy Veritas 5.1s, 5.2C, V-Mini-C.
willieconway is offline
Old 03-30-2013, 07:22 PM - Thread Starter
droseofc's Avatar
Quoted: 12 Post(s)
Sorry about the grammar errors, I have been writing everything on my phone so its hard not to type everything as if im texting. But thank you ill deff check those out
droseofc is offline
Samsung Un55es7100 55 Inch 1080p 240 Hz 3d Slim Led Hdtv Black
