X-Rite's i1Diagnostics 4.0.0.127 Released - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-03-2013, 01:56 PM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1671 Post(s)
Liked: 2081
i1Diagnostics allows you to test your X-Rite measurement instrument functionality and update licenses on your device. Use of this application by end users is recommended when problems are experienced with the measurement instrument. i1Diagnostics creates a report which can be sent to X-Rite support for further investigation if problems persist.
Download Link
The latest version of i1Diagnostics (4.0.0) supports the following instruments:
• i1Pro
• i1Pro 2
• i1iO
Please use the previous version (2.5) for the following instruments:
• i1iSis
• i1Display 1 & 2
You can download i1Diagnostics 2.5 here: www.xrite.com/support/i1Diagnostics
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #2 of 12 Old 04-04-2013, 05:57 AM
Killerbeenl's Avatar
thanks for sharing :thumbup:
Sometimes you are 1 click away from pulling your hair out and bang your head against the wall
Killerbeenl is offline
post #3 of 12 Old 04-04-2013, 09:17 AM
Rolls-Royce's Avatar
Quoted: 361 Post(s)
Liked: 534
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #4 of 12 Old 04-04-2013, 09:40 AM
PlasmaPZ80U's Avatar
Quoted: 2292 Post(s)
Liked: 706
thanks for the link...
I ran it on my rev d i1pro and it mentions:
"Instrument information
Instrument inspection: Successful
Serial number i1Pro:
Type: i1Pro
Revision: D
Firmware version: 505
CPLD version: 999
Dark measurement count: 244638
Lamp burning time: 1594.9 seconds
Spot measurement count: 3896
Scan measurement count: 282
Factory calibration: 2/17/2010
Spectral Module ID:"
Does this mean my meter is about 3 years old? Or does it just mean it was sent back to X-Rite in Switzerland for factory re-calibration/re-certification on 2/17/2010?
Also what does the following mean?
"Instrument Licenses
Measurement Modes: [Reflectance Spot, Reflectance Scan, Emission, Ambient Light Spot, Ambient Light Scan]
Licensed functionality: [Has Ambient Light, Spectral values, Tristimulus, Density]
Licensed Modules:
i1Match Module "Scanner": NOT licensed
i1Match Module "Monitor": licensed
i1Match Module "Printer": NOT licensed
i1Match Module "Printer RGB only": NOT licensed
i1Match Module "Printer CMYK only": NOT licensed
i1Match Module "Beamer": NOT licensed
i1Match Module "Printer Easy RGB": NOT licensed
i1Match Module "Printer Easy CMYK": NOT licensed
i1Match Module "Digicam": NOT licensed
i1Match Module "Editor": NOT licensed
i1Profiler Module "Display Profiling": NOT licensed
i1Profiler Module "RGB Printer Profiling": NOT licensed
i1Profiler Module "CMYK Printer Profiling": NOT licensed
i1Profiler Module "Printer QA": NOT licensed
i1Profiler Module "Advanced-Mode": NOT licensed
i1Profiler Module "Projector": NOT licensed"
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #5 of 12 Old 04-04-2013, 09:45 AM - Thread Starter
Liked: 2081
Exactly, Only the X-Rite can access the i1PRO1/2 internally to change these informations. I have send mine to Switzerland and that date was updated after receiving it back. Firmware version stayed the same.
post #6 of 12 Old 04-04-2013, 09:56 AM
ElectronicTonic's Avatar
Quoted: 65 Post(s)
Liked: 106
Licensed Modules:
Just download the iMatch software and see what you can use with it. Make sure you start up the software first, then connect your i1Pro.
ElectronicTonic is offline
post #7 of 12 Old 04-04-2013, 10:38 AM - Thread Starter
Liked: 2081
Licensed Modules:
Your Registed Licencies are correct. The 'NOT Licenced' features were for X-Rite's iMatch or iProfiler Software only. You need i1Publish Upgrade A or B to unlock them if you have i1PRO2 or i1Photo Upgrade if you have i1PRO1, If you enable these extra licences when you can use the included accesories of i1PRO, Ruler, ColorChecker etc. No usage for Display Calibrations etc.
post #8 of 12 Old 04-04-2013, 11:05 AM
Liked: 706
so the build date for my meter could be before 2010?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #9 of 12 Old 04-04-2013, 11:09 AM - Thread Starter
Liked: 2081
We can't see the build data, a DEV tool maybe is showing that. This Data shows only your last Factory Calibration Date.
post #10 of 12 Old 04-04-2013, 11:40 AM
Liked: 706
ok, thanks for all the help
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #11 of 12 Old 05-23-2013, 05:23 PM - Thread Starter
Liked: 2081
By Unknown reason, today X-Rite has removed i1Diagnostics 4.0.0.127 from their website and they bring back as the latest version for download the v2.5.1.
post #12 of 12 Old 05-28-2013, 03:33 PM - Thread Starter
Liked: 2081
Today the Download Link for 4.0.0.127 is on-line again, same version with the same digital signature. wink.gif
Reply Display Calibration
