DPG-2000 Digital Pattern Generator and CalMan v4 - AVS Forum | Home Theater Discussions And Reviews
Old 04-15-2013, 12:28 AM - Thread Starter
Leinad's Avatar
Hi, I'm new to the AVS forums, and what brings me here is that I'm looking for a generator that is compatible with CalMan V4 that is not way too expensive. I'm wondering if I can use the DPG-2000, or if I can't which one would you recommend? Thanks.
Leinad is offline
Old 04-15-2013, 05:15 AM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
DPG 2000 is not supported on V4. A good BRP and disk are your only other options as far as I know.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 04-15-2013, 08:53 PM - Thread Starter
Leinad's Avatar
Thanks for the info. Which one would you recommend?
Leinad is offline
Old 04-15-2013, 09:51 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Check out this site owned by one of the forum members. I have a Panasonic 210 which was bench marked as having correct output but it is now several years old.. You need to see which of the current players has perfect reference level output.
http://www.hometheaterhifi.com/secrets-product-reviews.html
Doug
Old 04-17-2013, 04:57 AM - Thread Starter
Leinad's Avatar
Thanks, that was very informative.
Leinad is offline
