Issue with Disney WOW calib disc - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-17-2013, 02:10 PM - Thread Starter
joeybutts's Avatar
So I ran all the tests and got everything tuned (what seems) correctly except for contrast.
I have a BenQ W1070, light controlled room, and painted the screen on the wall. I'll have to look it up, but it was the most neutral grey sherwin williams paint.
When I do the contrast test, I never see the other set of bars. I only see one set. No matter what extreme I go to. Does that mean my brightness is too high? When I do the advanced tests I see the stars and lowest percentages just fine.
This is more just curiosity than concern. Images look fantastic, but just want to know to cure my own ignorance.....
joeybutts is offline
post #2 of 9 Old 04-19-2013, 05:17 AM - Thread Starter
joeybutts's Avatar
post #3 of 9 Old 04-19-2013, 06:20 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
I think the disk explains what to do if your player or display won't show the Whiter than White bars..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 9 Old 04-19-2013, 07:09 AM
Smackrabbit's Avatar
Quoted: 120 Post(s)
Liked: 296
In the menus for the BenQ W1070 there is an HDMI setting you need to change to allow WTW and BTB content to pass. I can't recall the name of it off-hand,but if you search for it and change it, then you'll see the bars. I believe it's on Auto by default.
Chris Heinonen
Staff Writer, The Wirecutter, a NY Times Company
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Secrets of Home Theater and High Fidelity, AnandTech.com, HDGuru.com and Electronic House
Smackrabbit is offline
post #5 of 9 Old 04-19-2013, 09:49 AM - Thread Starter
joeybutts's Avatar
EXCELLENTTTTTTTTTTT. Thank you sir!
post #6 of 9 Old 05-15-2013, 10:26 AM
Heywould's Avatar
I am having this same issue with an Panasonic 60ST60 and a samsung BD c5500.. I can not get the contrast to show the bars or stars no matter what I do. ive posted the full detail in the plasma display forum..
Where does it tell you what to do? I looked for that. I cant seem to locate anything.. (im sure I just missed it)
Heywould is offline
post #7 of 9 Old 12-12-2013, 09:42 AM
Jon Stokes's Avatar
I have just bough thte Disney WOW disc and my TV cannot see the contrast white bars or the stars when the brightness is turned all the way up.
any help> I am very new to this but learning.
I have a Samsung 6400
ta
Jo
Jon Stokes is offline
post #8 of 9 Old 12-12-2013, 11:31 AM
ConnecTEDDD's Avatar
Quoted: 1733 Post(s)
Liked: 2137
ta
Jo
With Brightness control you set the Black Level, with Contrast Control the White Level, reduce you contrast to see more flashing stars/bars, you are experiencing now White Clipping. Also watch the tutorial videos of your WOW.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #9 of 9 Old 12-12-2013, 11:51 AM
garagenation's Avatar
Usually the hdmi level not being set the same, the display AND the playback have to be set the same level. I made this mistake. My samsung is set to normal (full range) and so is my xbox one, sounds obvious I know. Setting your display to hdmi level low and your playback system to limited should make it more visible
garagenation is offline
Reply Display Calibration
