Calibrating using a smartphone? (hear me out) - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By moyanous
post #1 of 11 Old 04-18-2013, 06:01 PM - Thread Starter
Psythik's Avatar
I was poking around in my S III's diagnostics menu (dial *#0*# if you own a Galaxy) and noticed that its light sensor gives me not only readings in lux, but individual RGBW values from 0 to 65,536. Could this in any way be useful for calibrating a projector, and if so, how?
Psythik is offline
post #2 of 11 Old 04-18-2013, 07:46 PM
nodixe's Avatar
There are aps that do this as well but a few photographers said they weren't accurate enough for their use in reviews
Sent from my DROIDX using Tapatalk 2
nodixe is offline
post #3 of 11 Old 04-18-2013, 08:28 PM
e08
e08's Avatar
I think part of why calibration is so fun and addictive is know your colours are correct and by putting trust in your meters and software. Would knowing the setting from a smartphone app aren't very accurate bug you? I know it would for me.
Hayden.
~ Hayden
Sorry for any typos or bad grammar, I am Dyslexic.
Sony XBR-HX929, Sony Playstation 3 (Slim 160GB), i1 Display Pro OEM, CalMAN Enthusiast.
e08 is offline
post #4 of 11 Old 04-19-2013, 12:34 AM
sillycargt4cs's Avatar
Surly it's worth a go.how would you use it though
sillycargt4cs is offline
post #5 of 11 Old 04-19-2013, 01:24 AM
nodixe's Avatar
I played with a bunch on my droid 3 hdmi out. 'Droidsail' 'displaytester pro' 'plasma saver' and 'voodoo test pattern' were a few but it was before I received my i1pro so I couldn't check accuracy...recently I've been playin with deltaE* and Colormath... there is another one called testpatterngene but it is $40!
But if you have an ihone 5 you can download an official ISF app as well as THX and another I think..?....this is due to displaymates glowing review of the retina diaplay which they found needs no calibration.
nodixe is offline
post #6 of 11 Old 04-19-2013, 09:37 AM
derekjsmith's Avatar
Liked: 116
The light sensor is a TAOS chip that has 4 channels WRGB. Yes it does give you relative RGB values but they are non-linear. So for this to work you would need to calibrate the sensor with a 3D matrix not just a 3x3 transform. The cost to do this is more than an affordable tristim.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #7 of 11 Old 04-20-2013, 02:46 AM - Thread Starter
Psythik's Avatar
Half of you don't even know what I'm talking about. I don't care about calibrating my phone, I meant using my phone as a colorimeter to calibrate my projector. Read more than just the title, guys.
For the rest of you: You're essentially saying I'm better off eyeballing my calibrations than attempting to get any sort of assistance from my phone? There's no way in hell I'm blowing the cost of my entire home theater on a single colorimeter.
Well considering that I can't afford a colorimeter, I figured using something to help me calibrate is better than nothing, but I guess I figured wrong.
Thanks for input guys. Guess I'm going back to staring at SMPTE patterns...
Psythik is offline
post #8 of 11 Old 04-20-2013, 10:49 AM
PlasmaPZ80U's Avatar
Quoted: 1961 Post(s)
Liked: 559
Derek's post was pretty clear about it... you need to spend more than the cost of a colorimeter like the D3 (aka i1 display pro) to calibrate the sensor on your phone so that it could be used as a color analyzer and then there would be the even harder part of finding a way to use that color analyzer since it wouldn't work with any common calibration software like CalMAN, ChromaPure, or ColorHCFR.
If you want a reliable meter for not too much, see if you can get a used i1pro spectro (Rev D) online. They can go as low as $200-$250 if you're lucky (I think some have even managed to get one for $150). It's a good investment provided it's Rev D and passes the i1 diagnostics since it's very accurate across all display techs and will stay that way for much longer than any colorimeter in a similar price range.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #9 of 11 Old 04-20-2013, 11:20 AM
nodixe's Avatar
All you can do is throw up some colors using avshd disc and see what it says. You can try apps like colormeter that use the camera to id colors and/or light intensity. If you have phone with an hdmi out (motorolla) you can use an app like droidsail to be a pattern generator or to fix burn in. The problem is I'm not sure what standard video is output to (rec709,sRGB etc) or if they meet specs of standard? Maybe somebody could here could test for us! Oh yeah this is mostly in reference to android smartphones as idk much about apple products but I read on displaymate site that retina display was the best display of any consumer electronics with almost perfect color accuracy out of box so the iphone5/ipad w/retina can be used as reference for color and greyscale comparitor (or sump like that).
nodixe is offline
post #10 of 11 Old 06-01-2016, 08:34 AM
moyanous's Avatar
I don't know about calibrating projectors, but you can calibrate monitors with an Android phone using the following apps
"Display Calibration" on a Windows 10 PC/tablet
https://www.microsoft.com/en-us/store/apps/display-calibration/9nblggh4wd9s
"Camera Colorimeter" on an Android phone
https://play.google.com/store/apps/d...ft.colorimeter
The Android phone's camera acts as a color metering device for measuring the color output of the display of the Windows's device. The two devices communicate via Bluetooth.
TrueDis likes this.
moyanous is offline
post #11 of 11 Old 06-14-2016, 02:48 PM
Brian Hampton's Avatar
Quoted: 572 Post(s)
Liked: 302
I used to be very interested in using my phone or my camera to calibrate displays.
It only made perfect sense to me to photograph the screen and compare the digital photo to the content of the test patterns. Sounds easy and practical.
These days you can get a very good color meter for under $200. If you are wiling to use other people's calibration offsets (profiles) for the meter then you are ready to go. You can use freeware (though if you love it it makes sense to support it when you can.)
I have a i1D3 and an i1pro spectro and I think it's the way to go. I use HCFR (for initial setup) and DisplayCal (to make 3DLUT file)
There is a large learning curve ... I personally find the learning enjoy-able. But trying to skimp on the first part (getting a reputable metering device) is really not the best place to start.
-Brian
Brian Hampton is offline
Reply Display Calibration
