Difference between eliminating color clipping via contrast control vs. color control - AVS Forum | Home Theater Discussions And Reviews
Old 04-19-2013, 08:10 PM - Thread Starter
PlasmaPZ80U's Avatar
Quoted: 1964 Post(s)
Liked: 560
When using color clipping patterns like the ones on the AVSHD709 disc and also the GCD disc, I've noticed color clipping can be eliminated/reduced by either lowering 'contrast' or 'color'.
My question is the following: if I see no clipping or discoloration on a white clipping pattern and the dynamic range tool in CalMAN5 shows no clipping in any channel but I do see color clipping on a pattern that shows shades of RGBCMY near digital 235, can I use the color control to fix this instead of the contrast control? Reducing either setting will fix the issue but what are the pros and cons to each means of eliminating the color clipping? Does each control (contrast, color) affect color clipping in a unique way? Or do they both do the exact same thing in this case?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
Old 04-19-2013, 10:29 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Contrast does one job,
Color does a different job.
You want red, green, blue and white to track the same.
The contrast control typically moves white, red, green, and blue together.
The color control typically moves red, green, blue relative to white.
The best way to analyze which control to tweak would be to look at gamut luminance.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 04-20-2013, 10:34 AM - Thread Starter
Liked: 560
thanks, that makes sense
